    Drawing a bitmap inside a dialog
    33 Posts 0 Posters 17.8k Views
    • H Offline
      Helper
      On 17/02/2005 at 05:17, xxxxxxxx wrote:
      Well, I'm not getting any errors now, but I'm not getting any picture in the user area either 😞
      This is a snippet of my code:
      class MyUserArea : GeUserArea
           public:
                MyUserArea(id,dialog);
      MyUserArea::MyUserArea(id,dialog)
           super(id,dialog);
      class PluginDialog : GeDialog
      private:
           var bc;
           var userx;
           ContainerToDialog();
           DialogToContainer();
           turn_on_off();
      public:
      PluginDialog();
      CreateLayout();
      Init();
      GetContainer();
      SetContainer(_bc);
      Message(msg);
      Command(id, msg);
      PluginDialog::PluginDialog()
           super(PLUGIN_ID);
           bc = new(BaseContainer);
      PluginDialog::GetContainer() { return bc->GetClone(); }
      PluginDialog::SetContainer(_bc) { bc = _bc->GetClone(); }
      PluginDialog::CreateLayout()
           var retval = LoadDialogResource(ALIGNER, PLUGIN_RES, 0);
           userx=new(MyUserArea,X_PIC,this);
           return retval;
      PluginDialog::Init()
           bc->SetData(NONE_X,     NONE_X_VAR);
           bc->SetData(ALIGN_X,     ALIGN_X_VAR);
           bc->SetData(DISTRIB_X,     DISTRIB_X_VAR);
           bc->SetData(ADJUST_X,     ADJUST_X_VAR);
           bc->SetData(NONE_Y,     NONE_Y_VAR);
           bc->SetData(ALIGN_Y,     ALIGN_Y_VAR);
           bc->SetData(DISTRIB_Y,     DISTRIB_Y_VAR);
           bc->SetData(ADJUST_Y,     ADJUST_Y_VAR);
           bc->SetData(NONE_Z,     NONE_Z_VAR);
           bc->SetData(ALIGN_Z,     ALIGN_Z_VAR);
           bc->SetData(DISTRIB_Z,     DISTRIB_Z_VAR);
           bc->SetData(ADJUST_Z,     ADJUST_Z_VAR);
           bc->SetData(AMIN_X,     AMIN_X_VAR);
           bc->SetData(AMED_X,     AMED_X_VAR);
           bc->SetData(AMAX_X,     AMAX_X_VAR);
           bc->SetData(MIN_X,     MIN_X_VAR);
           bc->SetData(MED_X,     MED_X_VAR);
           bc->SetData(MAX_X,     MAX_X_VAR);
           bc->SetData(SPACE_X,     SPACE_X_VAR);
           bc->SetData(OF_X,     OF_X_VAR);
           bc->SetData(AMIN_Y,     AMIN_Y_VAR);
           bc->SetData(AMED_Y,     AMED_Y_VAR);
           bc->SetData(AMAX_Y,     AMAX_Y_VAR);
           bc->SetData(MIN_Y,     MIN_Y_VAR);
           bc->SetData(MED_Y,     MED_Y_VAR);
           bc->SetData(MAX_Y,     MAX_Y_VAR);
           bc->SetData(SPACE_Y,     SPACE_Y_VAR);
           bc->SetData(OF_Y,     OF_Y_VAR);
           bc->SetData(AMIN_Z,     AMIN_Z_VAR);
           bc->SetData(AMED_Z,     AMED_Z_VAR);
           bc->SetData(AMAX_Z,     AMAX_Z_VAR);
           bc->SetData(MIN_Z,     MIN_Z_VAR);
           bc->SetData(MED_Z,     MED_Z_VAR);
           bc->SetData(MAX_Z,     MAX_Z_VAR);
           bc->SetData(SPACE_Z,     SPACE_Z_VAR);
           bc->SetData(OF_Z,     OF_Z_VAR);
           bc->SetData(USE_GROUP,     USE_GROUP_VAR);
           turn_on_off();
      PluginDialog::turn_on_off()
      {var a_x,a_y,a_z,str;
           var bm_path,bbm;
           bm_path=GeGetRootFilename();
           bm_path->RemoveLast();
           bm_path->AddLast("align_pics");
           bm_path->AddLast("x01.jpg");
           bbm=new(BaseBitmap,82,82);
           bbm->Load(bm_path,0);
           if(!bbm)
           println("Error getting a picture. Make sure the 'align_pics' folder is located in the same folder as the 'Aligner.cob' file.");
           return;
           userx->DrawBitmap(bbm,0,0,81,81,0,0,81,81,BMP_NORMAL);
           userx->Redraw();
           if(NONE_X_VAR)
           Enable(AMIN_X,FALSE);
           Enable(AMED_X,FALSE);
           Enable(AMAX_X,FALSE);
           Enable(MIN_X,FALSE);
           Enable(MED_X,FALSE);
           Enable(MAX_X,FALSE);
           Enable(OF_X_TXT,FALSE);
           Enable(OF_X,FALSE);
           Enable(SPACE_X,FALSE);
           if(NONE_Y_VAR)
      How do I place pictures in there, now?
      You guys are being a great help. Thank you 🙂
      Rui Batista
      • H Offline
        Helper
        On 17/02/2005 at 05:29, xxxxxxxx wrote:
        call your UserArea Draw function and call the member function DrawBitmap(...) to draw your image.
        See the example kuro posted
        • H Offline
          Helper
          On 17/02/2005 at 06:20, xxxxxxxx wrote:
          Know what? Its not working yet. I just have to type:
          userx->Draw(0,0,81,81)
          right?
          Isn't working 😞
          Rui Batista
          • H Offline
            Helper
            On 17/02/2005 at 06:27, xxxxxxxx wrote:
            no, you have to do it like this:
            MyUserArea::Draw(x1,y1,x2,y2)
                 OffScreenOn();
                 SetClippingRegion(x1,y1,x2,y2);
                 DrawBitmap(your_bitmap, 0, 0, 81, 81, 0, 0, 81, 81, BMP_NORMAL);
            • H Offline
              Helper
              On 17/02/2005 at 06:31, xxxxxxxx wrote:
              I did, Samir. But I'm drawing it by calling userx->Draw(0,0,81,81); from inside my dialog routines. Or, how should I draw it?
              Rui Batista
              • H Offline
                Helper
                On 17/02/2005 at 06:36, xxxxxxxx wrote:
                ? you don´t need to call it seperately. Once you call the Draw method as I posted it, it will be drawn. If you change the bitmap, all you need to do is redrawing the userarea with userx->Redraw();
                • H Offline
                  Helper
                  On 17/02/2005 at 06:56, xxxxxxxx wrote:
                  Well, the Draw method is never called. I placed a println in there and nothing is printed to the Console 😞
                  Want me to send you the listing?
                  Rui Batista
                  • H Offline
                    Helper
                    On 17/02/2005 at 07:00, xxxxxxxx wrote:
                    yeah, send it over.
                    • H Offline
                      Helper
                      On 17/02/2005 at 07:30, xxxxxxxx wrote:
                      Thank you. I just send it over to your mail 🙂
                      Rui Batista
                      • H Offline
                        Helper
                        On 17/02/2005 at 07:49, xxxxxxxx wrote:
                        Hey, you guys are having way to much fun without me! 🙂
                        Actually getting the GeUserArea to Draw() is the tricky part. As you can see by my code, I just 'force' a draw in the GeUserArea Init() method.
                        Let me know how it turns out.
                        • H Offline
                          Helper
                          On 17/02/2005 at 14:11, xxxxxxxx wrote:
                          The code works as expected. It doesn´t seem to work for Rui on his MAC though. However, I assumed that the picture files he uses may be "unusable" (maybe due to unsupported compression types or similar). Rui wanted to check if other pic types do work for him. He´ll get back to us when he knows more. 🙂
                          • H Offline
                            Helper
                            On 17/02/2005 at 14:25, xxxxxxxx wrote:
                            Gotcha. Here's hoping that it's unusable image formats and not something more sinister.
                            • H Offline
                              Helper
                              On 18/02/2005 at 04:49, xxxxxxxx wrote:
                              Thank you very much Robert and Samir.
                              It was in fact the file format. I changed it to uncompressed tiff and is working now. I always thought that jpeg was fine but I guess I will go on using uncompressed tiff from now on.
                              Rui Batista
