    ImportSymbols with single file didn't return as expect.
    Scheduled Pinned Locked Moved Bugs
    windowspython2025
    6 Posts 2 Posters 1.9k Views 2 Watching
    • DunhouD Offline
      Dunhou
      Hi community,
      I found the mxutils.ImportSymbols can not work with single file. Is this is a bug?
      win 11 + 2025.2
      Cheers~
      DunHou
      from pathlib import Path
      from mxutils import ImportSymbols
      from pprint import pp
      # replace a file path
      c4d_symbol = r".....c4d_symbols.h"
          # the file is true exists
          print(Path(c4d_symbol).exists())
          symbols_A = ImportSymbols(str(c4d_symbol), output=dict)
          pp(symbols_A) # return {}
          symbols_B = ImportSymbols(str(Path(c4d_symbol).parent), output=dict)
          pp(symbols_B) # return a dict with symbols
          symbols_C = ImportSymbols(str(Path(c4d_symbol).parent))
          pp(symbols_C) # return None
      https://boghma.com
      https://github.com/DunHouGo
        ferdinand @Dunhou
        Hey @Dunhou,
        Thank you for reaching out to us. Sorry for the delay, everything is happening at once here right now and I am rotating on the spot πŸ‘¨β€πŸ­.
        I quickly checked your example, and you are right, some regression happened there. That symbols_C returns None is correct, as passing the default None for output should place the symbols in the enclosing scope of the function call. I.e., when your c4d_symbol (which btw can be any header file, not just a c4d_symbols.h) would contain enum blah { BOB_IS_YOUR_UNCLE = 42}, you should be able to simply write print(BOB_IS_YOUR_UNCLE) and it then printing 42. But that is not working anymore. And symbols_A is also faulty.
        I will have a look what heck broke there, at first glance it is not obvious to me. I think Maxime touched symbol parsing not too long ago, because the parser missed some symbols in the C++ API (this mechanism is used to auto-expose parts of the C++ API to Python), maybe this broke things, I will have to see.
        For now, I would recommend to use the case which is working. I have moved this topic into bugs and hopefully can have a look next week.
        PS: Your MRD weight thingy is not forgotten, I will hopefully cross that off by the end of the week.
        • ferdinandF ferdinand moved this topic from Cinema 4D SDK on
          ferdinand @ferdinand
          Hey,
          sorry for the long turnaround. So, I had a look at the code, and this works as intended.
          path (str) – The path within which header files should be discovered and parsed.
          I got a bit confused by your pathlib shenanigans. So, the bottom line is that the function I myself wrote (lol), does not support passing a file as an input but only directories. I will add a little check to throw a more verbose error, because now this just silently fails when trying to traverse that path.
          We could think about adding the option to parse only a file, but that would be up to Maxime, as he owns the symbol parser backend.
          edit: In future versions (not the next) this will now fail more verbosely when providing a non-directory path or a path that does not exist.
          E:g.:
          c4d_symbol = r"/Users/f_hoppe/git/sdk/plugins/doc.python.github/plugins/py-cmd_gui_resources_2024/res/"
              symbols_C = ImportSymbols(str(Path(c4d_symbol)))
              print(ID_PLUGIN)
          {'__DUMMY__': 2006,
           'ID_PLUGIN': 1065655,
           'IDC_VALUE_A': 2003,
           'IDC_VALUE_B': 2005,
           'IDD_VALUES': 2000,
           'IDS_PLUGIN_HELP': 1001,
           'IDS_PLUGIN_NAME': 1000,
           'IDS_VALUE_A': 2002,
           'IDS_VALUE_B': 2004,
           'IDS_VALUES': 2001}
          {'__DUMMY__': 2006,
           'IDD_VALUES': 2000,
           'IDS_VALUES': 2001}
          None
          1065655
          DunhouD 1 Reply Last reply Reply Quote 0
          • DunhouD Offline
            Dunhou @ferdinand
            Hey @ferdinand,
            Is there any deficiency in pathlib ? I just think its writing style is more convenient and it produces less code. Lazy me🀑
            @ferdinand said in ImportSymbols with single file didn't return as expect.:
            I'm a bit confused, does this mean that ImportSymbols only support directories, but the documentation says that files can be passed for parsing, or did I misunderstand again...
            Cheers~
            DunHou
            https://boghma.com
              You are right, that is a bit odd, either there is regression, or I mixed something up with the code example. In any case, we will either add back singular file support or change the example.
                FYI: This has been fixed and will be shipped in a future version of Cinema 4D.
