    When exporting FBX using c4dpy.exe, there is no texture or material information for the material
    Scheduled Pinned Locked Moved Bugs
    python2024
    6 Posts 3 Posters 1.7k Views 1 Watching
    • Q Offline
      qq475519905
      May I ask how to add material information like the FBX exporter in the menu?
      import os
          # 获取当前文档
          doc = c4d.documents.LoadDocument(r"{c4d_file}", c4d.SCENEFILTER_OBJECTS | c4d.SCENEFILTER_MATERIALS)
          if doc is None:
              raise RuntimeError("No document is currently open.")
          # 定义 FBX 文件导出的路径
          documents_path = os.path.expanduser("~/Documents")
          fbx_file_path = os.path.join(documents_path, "exported_file.fbx")
          # 设置 FBX 导出参数
          export_settings = c4d.BaseContainer()
          export_settings.SetInt32(c4d.FBXEXPORT_FBX_VERSION, c4d.FBX_EXPORTVERSION_NATIVE)
          export_settings.SetBool(c4d.FBXEXPORT_ASCII, False)
          export_settings.SetBool(c4d.FBXEXPORT_CAMERAS, True)
          export_settings.SetBool(c4d.FBXEXPORT_LIGHTS, True)
          export_settings.SetBool(c4d.FBXEXPORT_SPLINES, True)
          export_settings.SetBool(c4d.FBXEXPORT_INSTANCES, True)
          export_settings.SetBool(c4d.FBXEXPORT_SELECTION_ONLY, False)
          export_settings.SetBool(c4d.FBXEXPORT_GLOBAL_MATRIX, True)
          export_settings.SetInt32(c4d.FBXEXPORT_SDS, c4d.FBXEXPORT_SDS_GENERATOR)
          export_settings.SetBool(c4d.FBXEXPORT_TRIANGULATE, True)
          export_settings.SetBool(c4d.FBXEXPORT_SAVE_NORMALS, True)
          export_settings.SetBool(c4d.FBXEXPORT_SAVE_VERTEX_COLORS, True)
          export_settings.SetBool(c4d.FBXEXPORT_SAVE_VERTEX_MAPS_AS_COLORS, False)
          export_settings.SetInt32(c4d.FBXEXPORT_UP_AXIS, c4d.FBXEXPORT_UP_AXIS_Y)
          export_settings.SetBool(c4d.FBXEXPORT_FLIP_Z_AXIS, False)
          export_settings.SetBool(c4d.FBXEXPORT_TRACKS, True)
          export_settings.SetBool(c4d.FBXEXPORT_BAKE_ALL_FRAMES, True)
          export_settings.SetBool(c4d.FBXEXPORT_PLA_TO_VERTEXCACHE, True)
          export_settings.SetBool(c4d.FBXEXPORT_BOUND_JOINTS_ONLY, True)
          export_settings.SetInt32(c4d.FBXEXPORT_TAKE_MODE, c4d.FBXEXPORT_TAKE_NONE)
          export_settings.SetBool(c4d.FBXEXPORT_MATERIALS, True)
          export_settings.SetBool(c4d.FBXEXPORT_EMBED_TEXTURES, True)
          export_settings.SetBool(c4d.FBXEXPORT_SUBSTANCES, True)
          export_settings.SetBool(c4d.FBXEXPORT_BAKE_MATERIALS, True)
          export_settings.SetInt32(c4d.FBXEXPORT_BAKEDTEXTURE_WIDTH, 1024)
          export_settings.SetInt32(c4d.FBXEXPORT_BAKEDTEXTURE_HEIGHT, 1024)
          export_settings.SetInt32(c4d.FBXEXPORT_BAKEDTEXTURE_DEPTH, c4d.FBXEXPORT_BAKEDTEXTURE_DEPTH_16)
          export_settings.SetBool(c4d.FBXEXPORT_LOD_SUFFIX, False)
          # 导出 FBX 文件
          if not c4d.documents.SaveDocument(doc, fbx_file_path, c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST, c4d.FORMAT_FBX_EXPORT):
              raise RuntimeError("Failed to export the document to FBX.")
          print("Export successful! File saved to:", fbx_file_path)
      ferdinandF i_mazlovI 2 Replies Last reply Reply Quote 0
        ferdinand @qq475519905
        Hello @qq475519905,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        Please provide code and a setup which make your claims reproducible for us. Your code contains a non-defined attribute c4d_file. It is also unclear to me what constitutes 'texture or material information' for you. Do you mean that the exported materials do not have materials or textures?
        I do not have any issues when I try to reproduce your claims at face value.
        Result
        For scene: test.zip
        Code
        import os
            doc: c4d.documents.BaseDocument | None = c4d.documents.LoadDocument(
                r"E:\temp\test.c4d", c4d.SCENEFILTER_OBJECTS | c4d.SCENEFILTER_MATERIALS)
            if doc is None:
                raise RuntimeError(f"Could not load the document.")
            bc: c4d.BaseContainer = c4d.BaseContainer()
            bc.SetInt32(c4d.FBXEXPORT_FBX_VERSION, c4d.FBX_EXPORTVERSION_NATIVE)
            bc.SetBool(c4d.FBXEXPORT_ASCII, False)
            bc.SetBool(c4d.FBXEXPORT_CAMERAS, True)
            bc.SetBool(c4d.FBXEXPORT_LIGHTS, True)
            bc.SetBool(c4d.FBXEXPORT_SPLINES, True)
            bc.SetBool(c4d.FBXEXPORT_INSTANCES, True)
            bc.SetBool(c4d.FBXEXPORT_SELECTION_ONLY, False)
            bc.SetBool(c4d.FBXEXPORT_GLOBAL_MATRIX, True)
            bc.SetInt32(c4d.FBXEXPORT_SDS, c4d.FBXEXPORT_SDS_GENERATOR)
            bc.SetBool(c4d.FBXEXPORT_TRIANGULATE, True)
            bc.SetBool(c4d.FBXEXPORT_SAVE_NORMALS, True)
            bc.SetBool(c4d.FBXEXPORT_SAVE_VERTEX_COLORS, True)
            bc.SetBool(c4d.FBXEXPORT_SAVE_VERTEX_MAPS_AS_COLORS, False)
            bc.SetInt32(c4d.FBXEXPORT_UP_AXIS, c4d.FBXEXPORT_UP_AXIS_Y)
            bc.SetBool(c4d.FBXEXPORT_FLIP_Z_AXIS, False)
            bc.SetBool(c4d.FBXEXPORT_TRACKS, True)
            bc.SetBool(c4d.FBXEXPORT_BAKE_ALL_FRAMES, True)
            bc.SetBool(c4d.FBXEXPORT_PLA_TO_VERTEXCACHE, True)
            bc.SetBool(c4d.FBXEXPORT_BOUND_JOINTS_ONLY, True)
            bc.SetInt32(c4d.FBXEXPORT_TAKE_MODE, c4d.FBXEXPORT_TAKE_NONE)
            bc.SetBool(c4d.FBXEXPORT_MATERIALS, True)
            bc.SetBool(c4d.FBXEXPORT_EMBED_TEXTURES, True)
            bc.SetBool(c4d.FBXEXPORT_SUBSTANCES, True)
            bc.SetBool(c4d.FBXEXPORT_BAKE_MATERIALS, True)
            bc.SetInt32(c4d.FBXEXPORT_BAKEDTEXTURE_WIDTH, 1024)
            bc.SetInt32(c4d.FBXEXPORT_BAKEDTEXTURE_HEIGHT, 1024)
            bc.SetInt32(c4d.FBXEXPORT_BAKEDTEXTURE_DEPTH, c4d.FBXEXPORT_BAKEDTEXTURE_DEPTH_16)
            bc.SetBool(c4d.FBXEXPORT_LOD_SUFFIX, False)
                doc, r"E:\temp\exported_test.fbx", c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST,
                raise RuntimeError("Failed to save document.")
        Q 1 Reply Last reply Reply Quote 0
        • Q Offline
          qq475519905 @ferdinand
          I tried to use Python to call c4d.exe within the system. When exporting Redshift materials with FBX, there are no materials or textures. using standard materials, everything works fine.
          [rsTEST.fbx](Invalid file type. Allowed types are: .png, .jpg, .bmp, .c4d, .gif, .txt, .py, .pyp, .vdb, .zip, .mp4, .webm, .cpp, .h, .pdf, .jpeg) rs测试.c4d
          • Q Offline
            qq475519905
            When exporting FBX, is it necessary to use C4DAtom.GetParameter()/C4DAtom.SetParameter() to access parameters for a successful material export?
              Please stop bumping your thread by asking the same question again and again, I have deleted your duplicate posting. We have seen your questions and we will answer soon.
              • i_mazlovI Offline
                i_mazlov @qq475519905
                Hi @qq475519905,
                You issue is likely a bug in the material export code, I've created a ticket (ITEM#530704) in our internal bug tracking system. Thank you for reporting the issue!
                Ilia
                • i_mazlovI i_mazlov moved this topic from Cinema 4D SDK on
