    how to make parameter stick to position with dynamic parameters hiding?
    Scheduled Pinned Locked Moved General Talk
    programming
    3 Posts 2 Posters 1.3k Views
    • aghiad322A Offline
      aghiad322
      i am struggling to align the cycle button to the bottom , i tried flag "ALIGN_BOTTOM" on both the parameter and the group containing the parameter in the ".res" file, it didn't work, and i am hiding the above parameters using "GetDDescription()" i want the cycle button to stick to the bottom in the red area even when above parameters changed.
      GROUP{
      		COLUMNS 2;
      		ALIGN_BOTTOM;  //causes an error when loading the tag plugin
      		LONG PRESET
      			ANIM OFF;
      			CYCLE
      				ANIMATION_CLONER;
      				SWEEP_PRO;
      				CUSTOM_INPUT;
      • i_mazlovI Offline
        i_mazlov @aghiad322
        Hi @aghiad322,
        You can use some dummy element (e.g. empty STATICTEXT) with SCALE_V directive to keep your dropdown aligned to the bottom. Keep in mind that the parent group also needs the SCALE_V. Try Setup #1 (attached below) in your .res file (based on our atom example).
        The only downside here would be the gap to the top part when scaled all the way down (notice that on gif).
        In case you want to keep your dropdown inside its own group with 2 columns, you can do that as well, but here you again need to make sure all groups use SCALE_V as well. Example Setup #2 is below.
        Ilia
        Setup #1. Simple example:
        CONTAINER Oatom
         NAME Oatom;
         INCLUDE Obase;
         GROUP ID_OBJECTPROPERTIES
           SCALE_V;
           REAL ATOMOBJECT_CRAD { ANIM OFF; UNIT METER; MIN 0.01; STEP 0.01; }
           REAL ATOMOBJECT_SRAD { UNIT METER; MIN 0.01; STEP 0.01; }
           LONG ATOMOBJECT_SUB	{ MIN 3; MAX 1000; }
           BOOL ATOMOBJECT_SINGLE	{ }
           STATICTEXT { SCALE_V; }
           LONG ATOMOBJECT_CYCLE
             ANIM OFF;
             CYCLE
               ATOMOBJECT_CYCLE_1;
               ATOMOBJECT_CYCLE_2;
               ATOMOBJECT_CYCLE_3;
        Setup #1. Result
        Setup #2. 2-column group example:
        CONTAINER Oatom
          NAME Oatom;
          INCLUDE Obase;
            SCALE_V;
            GROUP
              SCALE_V;
              COLUMNS 2;
              STATICTEXT { JOINEND; }
                ANIM OFF;
                CYCLE
                  ATOMOBJECT_CYCLE_1;
                  ATOMOBJECT_CYCLE_2;
                  ATOMOBJECT_CYCLE_3;
        Setup #2. Result:
        aghiad322A 1 Reply Last reply Reply Quote 1
          aghiad322 @i_mazlov
          Thanks a lot @i_mazlov that's exactly what i needed.
          however on one of the options for the dropdown i have a single Text input that spans across the whole attribute manager, now after i added the "STATICTEXT { SCALE_V; }" it eats up half the space in the image below
          i tried to give it a Description id and treat it as any other parameter and hiding it using "c4d.DESC_HIDE", below is the layout of the whole tab
          	GROUP ADVANCED_TAB
          		SCALE_V;
          		STRING CUSTOM_TXT_PARAMETER{ ANIM OFF; CUSTOMGUI MULTISTRING; SCALE_V; WORDWRAP; };
          		GROUP{
          			COLUMNS 2;
          			LONG ANIMATION_CLONER_FROM { MIN 0; ANIM OFF; };
          			LONG ANIMATION_CLONER_TO { MIN 0; ANIM OFF; };
          			LONG ANIMATION_CLONER_SPAN { MIN 1; ANIM OFF; };
          			GROUP{
          				COLUMNS 1;
          				SEPARATOR ANIMATION_CLONER_SEPARATOR{ LINE; };
          				REAL ANIMATION_CLONER_MULTIPLIER { MIN 0.1 ; STEP 0.1 ; ANIM OFF; };
          		GROUP{
          			COLUMNS 2;
          			REAL SWEEP_PRO_RADIUS { UNIT METER ; STEP 0.1 ; MIN 0.1; ANIM OFF; };
          			REAL SWEEP_PRO_MULTIPLIER { MIN 0.1; ANIM OFF; };
          		STATICTEXT UI_FILLER{SCALE_V;}
          		GROUP{
          				COLUMNS 2;
          				LONG PRESET
          					ANIM OFF;
          					CYCLE
          						ANIMATION_CLONER;
          						SWEEP_PRO;
          						CUSTOM_INPUT;
          but when i try to hide it from the "GetDDescription()" the description "description.GetParameterI(paramId)" is empty ! ,in the "GetDDescription()" in my source code i have the hiding for the other parameters implemented as well but didn't copy them to keep the snippet at minimum lines
          def GetDDescription(self, node: c4d.GeListNode, description: c4d.Description,
                                  flags: int) -> typing.Union[bool, tuple[bool, int]]:
                  if not description.LoadDescription(node.GetType()):
                      return False, flags
                  paramId: c4d.DescID = c4d.DescID(c4d.DescLevel(c4d.UI_FILLER, c4d.DTYPE_STRING, 0))
                  evalId: c4d.DescID = description.GetSingleDescID()
                  if (evalId and not paramId.IsPartOf(evalId)):
                      return True, flags
                  paramData: c4d.BaseContainer = description.GetParameterI(paramId)  #paramData for the "c4d.UI_FILLER" is empty
                  if paramData is None:
                      return True, flags
                  # parameter ID_HIDE_CONDITION.
                  paramData[c4d.DESC_HIDE] = True if node[c4d.PRESET] == c4d.CUSTOM_INPUT else False
                  return True, flags | c4d.DESCFLAGS_DESC_LOADED
