    Open source wrapper for Octane/Redshift/Arnold/Vray/Corona in Cinema 4D.
    Scheduled Pinned Locked Moved General Talk
    programminglearning-resource
    23 Posts 7 Posters 33.4k Views 4 Watching
    • DunhouD Offline
      Dunhou @Dunhou
      Hi again,
      Also another Corona AOV example here .
      Finally preliminarily implemented using this library to approximate the operation of the renderer in Cinema 4D .
      The learning process was very enjoyable, hope you also have fun with it ✌
      Cheers~
      DunHou
      Result:
      Code:
      import Renderer
      from Renderer import Corona
      def modify_corona_aov():
          # Get the doc host the aovs, in this case th active doc vp
          doc: c4d.documents.BaseDocument = c4d.documents.GetActiveDocument()
          vp: c4d.documents.BaseVideoPost = Renderer.GetVideoPost(doc, Renderer.ID_CORONA)
          # Set Corona AOVHelper instance
          aov_helper = Corona.AOV(vp)
          # turn on the mutipass
          aov_helper.enable_mutipass(True)
          # Add the DIFFUSE aov
          diff_aov = aov_helper.create_aov_shader(aov_type = Corona.CORONA_MULTIPASS_TYPE_ALBEDO)
          aov_helper.add_aov(diff_aov)
          # Add some aovs
          aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Corona.CORONA_MULTIPASS_TYPE_EMISSION, aov_name = 'emmision aov'))
          aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_REFLECT))
          aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_REFRACT))
          aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_TRANSLUCENCY))
          aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_ZDEPTH))
          # Remove last aov: volume
          aov_helper.remove_last_aov()
          # Remove specified aov: wire
          aov_helper.remove_aov_type(aov_type = Corona.CORONA_MULTIPASS_TYPE_TRANSLUCENCY)
          # Print current aov info
          aov_helper.print_aov()
          Corona.AovManager()
          Renderer.ClearConsole()
          modify_aorona_aov()
      https://boghma.com
      https://github.com/DunHouGo
      • DunhouD Offline
        Dunhou
        Hi community!
        New Updates here :
        • Fix some Octane and Corona functions (base on layer)
        • Add MaterialMaker and PBRPackage
        PBRPackage means a suite of pbr textures, like a stone texture pack form PolyHaven or Megascan, you can provide the folder and the name to get the slot they should be:
        • we have a texture pack named Rock Stone 01
        • this package had some textures in D:/myTextures ,like Rock Stone 01_albedo.jpg/Rock Stone 01_Normal.png/Rock Stone 01_disp.exr.
        • we can provide the folder like D:/myTextures and its name like Rock Stone 01
        • then we get textures in a dictionary
        data = {"diffuse": Rock Stone 01_albedo.jpg,
                      "normal": Rock Stone 01_Normal.jpg,
                      "displacement": Rock Stone 01_disp.jpg,
                      etc...
        Material Maker can easily add pbr materials from a package, and also you can use it with individuals textures.
        But all of this build with this library, so only node materials on Redshift/Arnold/Vray, Octane and Corona is supported by thier own logics.
        Cheers~
        DunHou
        https://boghma.com
        • DunhouD Offline
          Dunhou
          Hi community!
          Add Basic CentiLeo Material support, also with ConvertPorts data, This a "new" GPU Renderer and in active development. I am very interested in it.
          Not add AOV due to still being in the early stages of development, waiting for this.
          Cheers~
          DunHou
          https://boghma.com
