    Help!! C++ SDK, VS 2017 Community [SOLVED]
    Scheduled Pinned Locked Moved General Discussion
    28 Posts 0 Posters 23.2k Views
    • H Offline
      Helper
      On 22/05/2017 at 22:54, xxxxxxxx wrote:
      Did you copy that code from somewhere else? It doesn't compile because R18 doesn't use 'Real' or 'SetReal', it uses Float and SetFloat instead. Likewise gNew and gDelete don't exist any longer. Correct those errors and the missing semicolons errors will go away.
      If you're going to reuse old code fair enough, but you need to read about the changes in the SDK to get it to build.
      Steve
      • H Offline
        Helper
        On 23/05/2017 at 02:27, xxxxxxxx wrote:
        Good morning Lorenzo,
        with reference to your code, as already spotted out by Steve, make it compliant with the API you're supposed to use (in you case R18?) and beware of syntax errors.I warmly invite you to review the full set of examples shipped with Cinema 4D in the cinema4dsdk folder maybe starting with the C++ SDK - Example Dialog or maybe with something even simpler.
        On top of that, i similarly invite to deep dive into our documentation to read about the supported types as well as the instances creation/destruction; all the content found under "Overviews" can be considered of invaluable help for Cinema 4D developers newbie.
        Finally, as stated yesterday, please avoid posting multiple time adding small chips of information; collapse instead everything in a single post where all you questions are properly explained and use an external code dropping services in case you need to share code (rather than a snippet). This will dramatically community's improve issue understanding as well as topic readability.
        Best, Riccardo
        • H Offline
          Helper
          On 23/05/2017 at 06:04, xxxxxxxx wrote:
          Hi there Riccardo
          I correctly configured the sdk sample. The problem when i go to build the project i get these errors ..
          Here My Settings ..
          cinema4dsdk.snl file
          Microsoft Visual Studio Solution File, Format Version 12.00
          # Visual Studio 2013
          VisualStudioVersion = 12.0.30501.0
          MinimumVisualStudioVersion = 10.0.40219.1
          Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "cinema4dsdk", "cinema4dsdk.vcxproj", "{21895B69-DE91-7035-0009-38CB8C5CDEA3}"
          EndProject
          Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "cinema.framework", "C:\Program Files\MAXON\CINEMA 4D R18\frameworks\cinema.framework\project\cinema.framework.vcxproj", "{69BF9B7D-7EB2-7FC5-0009-38CB8C5CDEA3}"
          EndProject
          Global
          	GlobalSection(SolutionConfigurationPlatforms) = preSolution
          		Debug|x64 = Debug|x64
          		Intel|x64 = Intel|x64
          		Release|x64 = Release|x64
          	EndGlobalSection
          	GlobalSection(ProjectConfigurationPlatforms) = postSolution
          		{21895B69-DE91-7035-0009-38CB8C5CDEA3}.Debug|x64.ActiveCfg = Debug|x64
          		{21895B69-DE91-7035-0009-38CB8C5CDEA3}.Debug|x64.Build.0 = Debug|x64
          		{21895B69-DE91-7035-0009-38CB8C5CDEA3}.Intel|x64.ActiveCfg = Intel|x64
          		{21895B69-DE91-7035-0009-38CB8C5CDEA3}.Intel|x64.Build.0 = Intel|x64
          		{21895B69-DE91-7035-0009-38CB8C5CDEA3}.Release|x64.ActiveCfg = Release|x64
          		{21895B69-DE91-7035-0009-38CB8C5CDEA3}.Release|x64.Build.0 = Release|x64
          		{69BF9B7D-7EB2-7FC5-0009-38CB8C5CDEA3}.Debug|x64.ActiveCfg = Debug|x64
          		{69BF9B7D-7EB2-7FC5-0009-38CB8C5CDEA3}.Debug|x64.Build.0 = Debug|x64
          		{69BF9B7D-7EB2-7FC5-0009-38CB8C5CDEA3}.Intel|x64.ActiveCfg = Intel|x64
          		{69BF9B7D-7EB2-7FC5-0009-38CB8C5CDEA3}.Intel|x64.Build.0 = Intel|x64
          		{69BF9B7D-7EB2-7FC5-0009-38CB8C5CDEA3}.Release|x64.ActiveCfg = Release|x64
          		{69BF9B7D-7EB2-7FC5-0009-38CB8C5CDEA3}.Release|x64.Build.0 = Release|x64
          	EndGlobalSection
          	GlobalSection(SolutionProperties) = preSolution
          		HideSolutionNode = FALSE
          	EndGlobalSection
          EndGlobal
          projectsettings file
          <?xml version="1.0" encoding="utf-8"?>
          <Project DefaultTargets="Build" ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
            <PropertyGroup Label="UserMacros">
              <MAXON_ROOTDIR>..\..</MAXON_ROOTDIR>
            </PropertyGroup>
            <PropertyGroup>
              <_ProjectFileVersion>10.0.40219.1</_ProjectFileVersion>
            </PropertyGroup>
            <ItemGroup>
              <BuildMacro Include="MAXON_ROOTDIR">
                <Value>$(MAXON_ROOTDIR)</Value>
              </BuildMacro>
            </ItemGroup>
          </Project>
          Debugger Error ...
          Error	20	error C2065: 'COLOR' : undeclared identifier	c:\program files\maxon\cinema 4d r18\plugins\cinema4dsdk\source\gui\gradientuserarea.cpp	336	1	cinema4dsdk
          Error	21	error C2065: 'COLOR' : undeclared identifier	c:\program files\maxon\cinema 4d r18\plugins\cinema4dsdk\source\gui\gradientuserarea.cpp	337	1	cinema4dsdk
          Error	22	error C2065: 'COLOR' : undeclared identifier	c:\program files\maxon\cinema 4d r18\plugins\cinema4dsdk\source\gui\gradientuserarea.cpp	338	1	cinema4dsdk
          Error	23	error C2065: 'COLOR' : undeclared identifier	c:\program files\maxon\cinema 4d r18\plugins\cinema4dsdk\source\gui\gradientuserarea.cpp	361	1	cinema4dsdk
          Error	24	error C2065: 'COLOR' : undeclared identifier	c:\program files\maxon\cinema 4d r18\plugins\cinema4dsdk\source\gui\gradientuserarea.cpp	362	1	cinema4dsdk
          Error	25	error C2065: 'COLOR' : undeclared identifier	c:\program files\maxon\cinema 4d r18\plugins\cinema4dsdk\source\gui\gradientuserarea.cpp	363	1	cinema4dsdk
          	26	IntelliSense: identifier "COLOR" is undefined	c:\Program Files\MAXON\CINEMA 4D R18\plugins\Cinema4DSDK\source\gui\gradientuserarea.cpp	336	30	cinema4dsdk
          	27	IntelliSense: identifier "COLOR" is undefined	c:\Program Files\MAXON\CINEMA 4D R18\plugins\Cinema4DSDK\source\gui\gradientuserarea.cpp	361	21	cinema4dsdk
          • H Offline
            Helper
            On 23/05/2017 at 06:38, xxxxxxxx wrote:
            Ok I solved the problem, a question, I want to put a dialog box at bottom right in Cinema 4D . How can i do that?
            • H Offline
              Helper
              the GeDialog::Open() method has the optional parameter xpos and ypos to specify the position of the dialog. As stated in the documentation if these parameters are left unset the dialog will be opened at the current mouse position. Beside this small hints please have a look at the User Interface Manuals where plenty of details are discussed.
              Best, Riccardo
              • H Offline
                Helper
                On 27/09/2017 at 23:25, xxxxxxxx wrote:
                since i moved to a new pc i have visual studio 2017 installed (during the installation of unity3d). now i am having a hard time. is there a way to get things working with vs2017?
                i am not able to find a download for vs2013.. they always lead me to newer versions.
                any idea where i find it or a way to make things work in 2017?
                cheers,
                ello
                • H Offline
                  Helper
                  On 28/09/2017 at 01:20, xxxxxxxx wrote:
                  Hi Ello, thanks for writing us.
                  Please note that you can download previous version of VS at https://www.visualstudio.com/vs/older-downloads/.
                  Best, Riccardo
                  • H Offline
                    Helper
                    On 28/09/2017 at 06:11, xxxxxxxx wrote:
                    ah, thank you... finally gon it to install after renaming the installer 🙂 now in need to port the plugin over, guess this will be a nightmare due to the changes
