<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[dip Rig: a parametric robotic arm in Cinema 4D that you direct in plain language]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I would like to share <strong>dip Rig</strong>, a plugin I designed for Cinema 4D. It generates a parametric six-axis robotic arm from a chain described as data (axes, limits, geometry, joints), with its own physics: limits, effort, friction and interaction with objects. You talk to it directly: in the video below (sped up), I ask, and the arm plans, grasps and stacks the cubes.</p>
<p dir="auto">The rig is described once, independently of the native rig: the same arm is handled in Cinema 4D, runs in a browser, trains in simulation, then faces its physical counterpart.</p>
<p dir="auto">One design question I would value your view on: when a plugin runs its own physics step inside Cinema 4D, where would you hook it so that it stays in sync with the timeline and the viewport: a SceneHook, a tag, or the generator itself?</p>
<p dir="auto">More about the suite (dip Rig, dip Chat, dip Cable): <a href="https://dip-ai.io/en/projets/plugins-c4d.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://dip-ai.io/en/projets/plugins-c4d.html</a></p>
<p dir="auto">Best regards,<br />
David Pichot</p>
<p dir="auto"><video class="embed-video-local" controls src="/forum/assets/uploads/files/1792738634227-dip_rig_c4d_720.mp4">
</video></p>]]></description><link>http://developers.maxon.net/forum/topic/16451/dip-rig-a-parametric-robotic-arm-in-cinema-4d-that-you-direct-in-plain-language</link><generator>RSS for Node</generator><lastBuildDate>Fri, 23 Oct 2026 13:59:39 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/16451.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Oct 2026 08:04:45 GMT</pubDate><ttl>60</ttl></channel></rss>
