<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[After calling BaseContainer.Sort(), the stored values are lost]]></title><description><![CDATA[<p dir="auto">Hi,<br />
My requirement is to <strong>rearrange</strong> the basecontainer in order of <strong>id</strong>, so I used the BaseContainer().<strong>Sort()</strong> function. However, there were <strong>two issues</strong> in the simple test:</p>
<ol>
<li>the stored values were <strong>lost</strong></li>
<li>it was <strong>not arranged</strong> in order of id</li>
</ol>
<pre><code>import c4d
def main() -&gt; None:
    bc = c4d.BaseContainer()
    for i in range(4,12):
        bc.SetInt32(i,i)
    for i in range(3):
        bc.SetInt32(i,i)
    for id,v in bc:
        print(id,v)
    print("--------")
    bc.Sort()
    for id,v in bc:
        print(id,v)
</code></pre>
<p dir="auto">Did I misunderstand this function?</p>
]]></description><link>http://developers.maxon.net/forum/topic/16436/after-calling-basecontainer.sort-the-stored-values-are-lost</link><generator>RSS for Node</generator><lastBuildDate>Thu, 06 Aug 2026 06:34:58 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/16436.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Aug 2026 10:00:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to After calling BaseContainer.Sort(), the stored values are lost on Wed, 05 Aug 2026 15:00:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a> Thanks for your detailed explanation and the implementation of the sorting function. It's very helpful！</p>
]]></description><link>http://developers.maxon.net/forum/post/77302</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/77302</guid><dc:creator><![CDATA[chuanzhen]]></dc:creator><pubDate>Wed, 05 Aug 2026 15:00:58 GMT</pubDate></item><item><title><![CDATA[Reply to After calling BaseContainer.Sort(), the stored values are lost on Wed, 05 Aug 2026 13:22:09 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/chuanzhen">@<bdi>chuanzhen</bdi></a>,</p>
<p dir="auto">Thank you for reporting this. Yes, you are misunderstanding this function a bit. But I have to admit that I did too first, because the function is very weird in what it does. But when you look at the C++ docs, there is a warning.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1785933768597-846d8773-a0bf-4ac4-b6b0-6207ca995bf6-image.png" alt="846d8773-a0bf-4ac4-b6b0-6207ca995bf6-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I have just updated the Python docs for the next release to also contain the warning. So, this function is effectively only useable for containers holding strings. As you can see by my example below, it does not only remove all values but turns them into strings (and then leaves them empty when the source was not a string). The function is badly named.</p>
<p dir="auto">Find also a little example below to do what you want: sort a container by values.</p>
<p dir="auto">Cheers,<br />
Ferdinand</p>
<h4>Result</h4>
<pre><code>Root (None , id = -1):
├── 4 (DTYPE_LONG): 4
├── 5 (DTYPE_LONG): 5
├── 6 (DTYPE_LONG): 6
├── 7 (DTYPE_LONG): 7
├── 8 (DTYPE_LONG): 8
├── 9 (DTYPE_LONG): 9
├── 10 (DTYPE_LONG): 10
├── 11 (DTYPE_LONG): 11
├── 0 (DTYPE_LONG): 0
├── 1 (DTYPE_LONG): 1
└── 2 (DTYPE_LONG): 2
├── 1 (DTYPE_STRING):
├── 4 (DTYPE_STRING):
├── 5 (DTYPE_STRING):
├── 6 (DTYPE_STRING):
├── 7 (DTYPE_STRING):
├── 8 (DTYPE_STRING):
├── 9 (DTYPE_STRING):
├── 10 (DTYPE_STRING):
├── 11 (DTYPE_STRING):
├── 0 (DTYPE_STRING):
└── 2 (DTYPE_STRING):
</code></pre>
<h4>Code</h4>
<pre><code class="language-py">import c4d
import mxutils
        bc.SetInt32(i,i)
    for i in range(3):
        bc.SetInt32(i,i)
    print(mxutils.GetContainerTreeString(bc))
    print("--------")
    bc.Sort()
</code></pre>
<h2>Custom Sorting Function</h2>
<h4>Result</h4>
<pre><code class="language-txt">Root (None , id = -1):
├── 2 (DTYPE_LONG): 2
├── 3 (DTYPE_LONG): 3
├── 12 (DTYPE_LONG): 12
├── 13 (DTYPE_LONG): 13
├── 14 (DTYPE_LONG): 14
├── 15 (DTYPE_LONG): 15
├── 16 (DTYPE_LONG): 16
├── 17 (DTYPE_LONG): 17
├── 18 (DTYPE_LONG): 18
├── 19 (DTYPE_LONG): 19
└── 4 (DTYPE_SUBCONTAINER , id = -1):
    └── 19 (DTYPE_LONG): 19
</code></pre>
<h4>Code</h4>
import mxutils
import random
def SortContainer(bc: c4d.BaseContainer, mode: str = "value") -&gt; None:
    """Sorts the given container by ID or value.
    This function reallocates sub-containers but modifies the passed in container in place. It would also be
    possible to modify the sub-container in place, but more work to implement and also more complex to run.
    Due to the fact that we have to copy container data, this is also not the cheapest function.
    def copy(bc: c4d.BaseContainer) -&gt; list[tuple[int, any&rsqb;&rsqb;:
        """Copies the contents of the given BaseContainer to a list of (ID, value) tuples.
        result = []
        for i, v in bc:
            if isinstance(v, c4d.BaseContainer):
                v = copy(v)
            result.append((i, v))
        return result
    def build(bc: c4d.BaseContainer, items: list[tuple[int, any&rsqb;&rsqb;) -&gt; None:
        """Builds a BaseContainer from the given list of (ID, value) tuples.
        bc.FlushAll()
        for i, v in items:
            if isinstance(v, list):
                sub = c4d.BaseContainer()
                build(sub, v)
                v = sub
            bc[i] = v
    def sort_items(items: list[tuple[int, any&rsqb;&rsqb;, mode: str) -&gt; list[tuple[int, any&rsqb;&rsqb;:
        """Sorts the given list of (ID, value) tuples by ID or value. Nested containers are sorted recursively.
        def is_nested(item: tuple[int, any]) -&gt; bool:
            return isinstance(item[1], (list, tuple))
        def sort_key(item: tuple[int, any]) -&gt; tuple[bool, any]:
            item_id, value = item
            # The first key puts nested values after scalar values.
            # The second key is only compared within the same group.
            if is_nested(item):
                return True, item_id if mode == "id" else 0
            return False, item_id if mode == "id" else value
        # Sort nested contents recursively before sorting this level.
        for index, (item_id, value) in enumerate(items):
            if is_nested((item_id, value)):
                items[index] = (item_id, sort_items(value, mode))
        return sorted(items, key=sort_key)
    items: list[tuple[int, any&rsqb;&rsqb; = copy(bc)
    return build(bc, sort_items(items, mode))
    bc: c4d.BaseContainer = c4d.BaseContainer()
    data: list[int] = list(range(20))
    random.shuffle(data)
    for v in data:
        bc[v] = v
    copy: c4d.BaseContainer = bc.GetClone(0)
    bc[4] = copy
    print("--------")
    SortContainer(bc)
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/77301</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/77301</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Wed, 05 Aug 2026 13:22:09 GMT</pubDate></item></channel></rss>
