<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Access Node Material Path Redshift 2026]]></title><description><![CDATA[<p dir="auto">hello.<br />
working on a project where I have 8x materials with 11 texture nodes on a shader switch for a total of 88 textures that are mapped to the indexid of a clone object via a userdata node</p>
<p dir="auto">I have been attempting to script this via python where I can swap the textures based on the material name, then within each texture I mape 1-11 on clone material 01, 12-22 on clone material 02 but I am running into troubles accessing the 2026.1 command to access the Redshift Texture path. I think I have spent more time on this than it would have taken to do this manually, but I am interested in fixiing this. I have seem previous posts on the forum related to this, but in 2025 things seem to have changed and I am not sure where the "Path" is located on a Redshift material and how I can link that path to a user generated name on the material.</p>
<p dir="auto">essentially I am trying to get python to see "cloner_01" material, then within that add textures 01-11 to the textures within it based on the user generated name on the texture node, 01-11. then for "cloner_02" material add textures 12-22 into, and so on and so forth until "cloner_08" 78-88. I was able to do this failry easily on a displacer deformer to swap the shader per clone there. but I am having trouble access Redshift's Path.</p>
<p dir="auto">could I get a few hints as to where I need to be looking to do this, or maybe there is a better logic? thanks.</p>
]]></description><link>http://developers.maxon.net/forum/topic/16376/access-node-material-path-redshift-2026</link><generator>RSS for Node</generator><lastBuildDate>Tue, 13 Oct 2026 12:15:32 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/16376.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Jan 2026 14:41:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Access Node Material Path Redshift 2026 on Fri, 30 Jan 2026 19:24:34 GMT]]></title><description><![CDATA[<p dir="auto">hi there, I actually did sort this out in a very round about way with some "vibe coding". this was for a mapp creation project I am working where I am displaying various eras of map onto 20km grids (so as not to kill the viewport functionality). have a look at the below and let me know if this is a solid approach or if there was a better way:</p>
<pre><code>import c4d
import maxon
    era = "INSERT_YOUR_ERA_HERE"
    basePath = "INSERT_YOUR_PATH_HERE"
    prefix = f"map_{era}_tile_20k_"
    extension = ".tif"
    if doc is None:
    nodeSpaceId = maxon.Id("com.redshift3d.redshift4c4d.class.nodespace")
    textureNodeId = maxon.Id("com.redshift3d.redshift4c4d.nodes.core.texturesampler")
    for mat_index in range(1, 9):
        mat_name = f"column_{mat_index:02d}"
        mat = doc.SearchMaterial(mat_name)
        if not mat:
            print(f"Material {mat_name} not found.")
            continue
        nodeMat = mat.GetNodeMaterialReference()
        if nodeMat is None:
            print(f"{mat_name} is not a node material.")
            continue
        graph = nodeMat.GetGraph(nodeSpaceId)
        if graph.IsNullValue():
            print(f"No Redshift graph for {mat_name}.")
            continue
        textureNodes = []
        maxon.GraphModelHelper.FindNodesByAssetId(graph, textureNodeId, False, textureNodes)
        with graph.BeginTransaction() as transaction:
            for node in textureNodes:
                node_name = node.GetValue(maxon.NODE.BASE.NAME)
                if not node_name:
                    print(f"Unnamed node in {mat_name}, skipping.")
                    continue
                node_name = str(node_name)
                try:
                    local_index = int(node_name)
                except:
                    print(f"Non-numeric node name '{node_name}' in {mat_name}, skipping.")
                    continue
                global_index = (mat_index - 1) * 11 + local_index
                filename = f"{prefix}{global_index:03d}{extension}"
                full_path = basePath + filename
                tex0 = node.GetInputs().FindChild(
                    "com.redshift3d.redshift4c4d.nodes.core.texturesampler.tex0"
                if tex0.IsNullValue():
                    print(f"No tex0 on node '{node_name}' in {mat_name}")
                    continue
                pathPort = tex0.FindChild("path")
                if pathPort.IsNullValue():
                    print(f"No path port on node '{node_name}' in {mat_name}")
                    continue
                pathPort.SetDefaultValue(maxon.Url(full_path))
                print(f"{mat_name} → Node '{node_name}' set to {full_path}")
            transaction.Commit()
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/77030</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/77030</guid><dc:creator><![CDATA[randmcnally]]></dc:creator><pubDate>Fri, 30 Jan 2026 19:24:34 GMT</pubDate></item></channel></rss>
