<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[GeUserArea] Click detection selects wrong item when clicking on lower part of cell (image + text area)]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am implementing a custom thumbnail grid browser inside a GeUserArea.<br />
The grid cell contains an image + text label.</p>
<p dir="auto">I calculate the rectangle of each cell using _get_cell_rect(),<br />
and then check whether the mouse click is inside that rectangle.</p>
<p dir="auto">Here is the simplified code:</p>
<pre><code>    def __init__(self, dialog=None):
        super(KidooShotManagerUserArea, self).__init__()
        self.dialog = dialog
        # 我自己的库实例
        self.GetC4dCont = GetC4DContent()
        self.PathPro = PathProcess()
        self.GuiUtils = GuiUtils()
        self.padding = 8  # 每张图片之间的间距。
        self.base_size = 128  # 每张图片的基础大小
        self.min_size = 50  # 最小尺寸
        self.max_size = 256  # 最大尺寸
        self.scale_factor = 1.0  # 缩放因子
        self.col_count = 4  # 列数
        self.cell_size = self.base_size  # 每个格子的实际大小
        self.rounded_radius = 10  # 圆角半径
        self.assets = []  # 存储图片
        self.selected_index = 0 # 用于记录选中卡片
        # 基础颜色变量
        self.bg_color = c4d.Vector(43/255.0, 43/255.0, 43/255.0)  # 背景颜色
        self.bg_color_01 = c4d.Vector(20/255.0, 20/255.0, 20/255.0)  # 背景颜色
    def _calc_grid(
        self,
        width: int,
        base_size: int,
        padding: int,
        min_size: int,
        max_size: int,
        scale_factor: float = 1.0,
        mode: str = "auto",
        fixed_cols: int = None,
        fixed_cell: int = None
        根据区域宽度和配置计算网格列数与 cell 尺寸
        :param width: 总区域宽度
        :param base_size: 基础尺寸（设计稿默认卡片大小）
        :param padding: 内边距
        :param min_size: 允许的最小尺寸
        :param max_size: 允许的最大尺寸
        :param scale_factor: 缩放因子（用户滑块控制，默认1.0）
        :param mode: "auto" | "fixed_cols" | "fixed_cell"
        :param fixed_cols: 固定列数
        :param fixed_cell: 固定格子大小
        if mode == "fixed_cols" and fixed_cols is not None:
            cols = fixed_cols
            cell = (width - (cols + 1) * padding) / cols
            return cols, max(min(cell, max_size), min_size)
        if mode == "fixed_cell" and fixed_cell is not None:
            cols = max(1, int((width + padding) / (fixed_cell + padding)))
            return cols, fixed_cell
        # --- 改进的 auto 模式 ---
        # 用 scale_factor 控制缩放
        scaled_size = base_size * scale_factor
        cell = max(min(scaled_size, max_size), min_size)
        cols = max(1, int((width + padding) / (cell + padding)))
        return cols, cell
def _get_cell_rect(
    self, index, area_width, base_size, padding,
    min_size, max_size, text_height, scale_factor=1.0
    cols, cell = self._calc_grid(area_width, base_size, padding, min_size, max_size, scale_factor)
    total_cell_height = cell + text_height + padding
    row = index // cols
    col = index % cols
    px = padding + col * (cell + padding)
    py = padding + row * (total_cell_height + padding)
    rect_x1 = px
    rect_y1 = py
    rect_x2 = px + cell
    rect_y2 = py + cell + text_height + padding  # &lt;- include text height
    return int(rect_x1), int(rect_y1), int(rect_x2), int(rect_y2)
    def DrawMsg(self, x1, y1, x2, y2, msg):
        # 绘制背景
        self.SetClippingRegion(x1, y1, x2, y2) # 设置裁剪区域
        self.OffScreenOn() # 开启屏幕裁剪
        self.DrawSetPen(c4d.COLOR_BG) #设置背景颜色
        self.DrawRectangle(x1, y1, x2, y2) # 绘制背景
        self.DrawSetPen(1) #设置背景颜色
        # 计算容器大小
        container_width  = x2 - x1
        container_height = y2 - y1
        self.DrawSetFont(c4d.FONT_DEFAULT)
        text_height = self.DrawGetFontHeight()
        for index, (bitmap, _, name) in enumerate(self.assets):
            image_orig_width = bitmap.GetBw()
            image_orig_height = bitmap.GetBh()
            # 获取绘制位置
            # 获取绘制位置（当前索引 index 对应卡片的矩形区域）
            px, py, px2, py2 = self._get_cell_rect(
                index=index,                        # 当前要绘制的卡片索引
                area_width=self.GetWidth(),         # 当前用户区域的总宽度（UI 绘制区域宽度）
                base_size=self.base_size,           # 期望的基础 cell 大小（默认 128px）
                padding=self.padding,               # cell 之间的间距（默认 8px）
                min_size=self.min_size,             # cell 允许的最小尺寸（避免过小）
                max_size=self.max_size,             # cell 允许的最大尺寸（避免过大）
                text_height=text_height, # 当前字体的高度，用于计算文字占位
                scale_factor=self.scale_factor, # 当前缩放因子（用户滑块控制，默认 1.0）
            self.DrawSetPen(c4d.Vector(0.5, 0.5, 0.5))
            self.DrawRectangle(px, py, px2, py2)
            cell = self.cell_size
            padding = self.padding
            # # 缩放计算
            # scale = min(cell / image_orig_width, cell / image_orig_height)
            # dw, dh = int(image_orig_width * scale), int(image_orig_height * scale)
            # ox = px + (cell - dw) // 2
            # oy = py + (cell - dh) // 2
            # 鼠标选中边缘高光绘制
            if index == self.selected_index:
                border_thickness = 2  # 边框线宽，可调整
                border_color = c4d.Vector(1.0, 1.0, 1.0)  # 例如白色边框，可根据需要更改颜色
                self.DrawSetPen(border_color)  # 设置绘制颜色为高亮边框颜色
                # 绘制矩形边框，范围比卡片区域每边扩大2像素
                self.DrawFrame(px, py, px2, py2, lineWidth=border_thickness)
def on_click(self, x, y):
    for index, (_, _, name) in enumerate(self.assets):
            index=index,
        if px &lt;= x &lt;= px2 and py &lt;= y &lt;= py2:
            self.selected_index = index
            self.Redraw()
            break
</code></pre>
<p dir="auto">When I click on the lower part of a cell (in the text label area),<br />
sometimes the next cell below gets selected instead of the one I clicked.<br />
﻿<br />
So visually I click "inside" the bottom of cell A,<br />
but on_click reports cell B (the one below A) as selected.<br />
﻿<br />
Question<br />
﻿<br />
Am I calculating the rectangle wrong?<br />
﻿<br />
Should the text label be excluded from the clickable area?<br />
﻿<br />
Or is this expected behavior of GeUserArea and I need to treat the image and text separately?</p>
]]></description><link>http://developers.maxon.net/forum/topic/16318/geuserarea-click-detection-selects-wrong-item-when-clicking-on-lower-part-of-cell-image-text-area</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 22:15:24 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/16318.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 Aug 2025 08:25:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [GeUserArea] Click detection selects wrong item when clicking on lower part of cell (image + text area) on Tue, 26 Aug 2025 16:34:07 GMT]]></title><description><![CDATA[<p dir="auto">Hey,</p>
<p dir="auto">thanks for the extended code, but I still cannot run this, as it is only a fragment <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /> So, I only have a very rough understanding of what is going wrong.</p>
<p dir="auto">A likely issue apart from you just having a bug in your hit logic, is that you use the wrong coordinate system.</p>
<pre><code class="language-py">if msg[c4d.BFM_INPUT_DEVICE] == c4d.BFM_INPUT_MOUSE \
    and msg[c4d.BFM_INPUT_CHANNEL] == c4d.BFM_INPUT_MOUSELEFT \
    and msg[c4d.BFM_INPUT_VALUE]:
    local_x = msg[c4d.BFM_INPUT_X]
    local_y = msg[c4d.BFM_INPUT_Y]
    scroll_y = self.dialog.get_scroll_offset()
</code></pre>
<p dir="auto">I would have to check myself, but there is some inconsistency with which dialogs send mouse input messages regarding the used coordinate system. Sometimes they send messages in the coordinate system of the dialog and sometimes messages in the coordinate system of the gadget. Just print out your (local_x and local_y) and check if the values make sense as local coordinates as you seem to treat them. On <code>GeUserArea</code> are multiple coordinate conversion methods. I think <code>BFM_INPUT</code> in this context is in local user area coordinates but I am not sure, it could also be that you have to convert them.</p>
<p dir="auto">The other thing is of course that you add this <code>self.dialog.get_scroll_offset()</code> on top of things. I assume this is sourced by something like <code>GeDialog.GetVisibleArea</code>? There you could also unintentionally mix coordinate systems.</p>
<p dir="auto">Cheers,<br />
Ferdinand</p>
]]></description><link>http://developers.maxon.net/forum/post/76784</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/76784</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Tue, 26 Aug 2025 16:34:07 GMT</pubDate></item><item><title><![CDATA[Reply to [GeUserArea] Click detection selects wrong item when clicking on lower part of cell (image + text area) on Tue, 26 Aug 2025 11:40:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a><br />
This is my GeUserArea class</p>
<pre><code>class KidooShotManagerUserArea(gui.GeUserArea):
        # 我自己的库实例
        # 基础颜色变量
    def load_card(self, image_assets: list) -&gt; list:
        input:
        - image_assets: [{path, name}, {path, name}, ...] 需要输入图片的路径和名称列表。
        returns:
        - assets: 返回&lsqb;&lsqb;bitmap, path, name], ...] 的列表，包含加载的图片对象、路径和名称。
        assets = []
        for asset in image_assets:
            path = asset.get('path')
            name = asset.get('name', '')
            default_image = os.path.join(_ICONPATH, 'photo-film_white.png')
            bitmap = None
            try:
                if os.path.exists(path):
                    # 如果路径存在，尝试加载图片
                    bitmap = self.GuiUtils.load_bitmap(path)
                    # 如果路径不存在，尝试加载默认图片(注：确保默认图片可以被正确加载)
                    bitmap = self.GuiUtils.load_bitmap(default_image)
            except Exception as e:
            assets.append([bitmap, path, name])
        self.assets = assets
        self.Redraw()
        return assets
    def GetMinSize(self):
        动态计算最小尺寸，基于卡片数量和布局参数
        if not self.assets:
            return 0, 100  # 没有资产时返回最小高度
        # 获取当前区域宽度（如果还没有初始化，使用默认值）
        area_width = self.GetWidth() if hasattr(self, 'GetWidth') and self.GetWidth() &gt; 0 else 400
        # 计算字体高度
        # 计算网格布局
            area_width,
            self.base_size,
            self.padding,
            self.min_size,
            self.max_size,
            self.scale_factor
        # 计算总行数
        total_cards = len(self.assets)
        rows = (total_cards + cols - 1) // cols  # 向上取整
        # 计算总高度
        total_cell_height = cell + text_height + self.padding
        total_height = (rows * (total_cell_height + self.padding)) + self.padding
        # 确保最小高度
        min_height = max(int(total_height), 100)
        return 0, min_height
    def _calc_grid(
        self,
        width: int,
        base_size: int,
        padding: int,
        min_size: int,
        max_size: int,
        mode: str = "auto",
        :param width: 总区域宽度
        :param padding: 内边距
            cols = fixed_cols
        return cols, cell
    def _get_cell_rect(
        self,
        index: int,
        area_width: int,
        base_size: int,
        padding: int,
        min_size: int,
        max_size: int,
        text_height: int,
        mode: str = "auto",
        获取指定 index 的 cell 坐标区域 (含文字区域)
            area_width,
            base_size,
            padding,
            min_size,
            max_size,
            scale_factor,
            mode,
            fixed_cols=fixed_cols,
            fixed_cell=fixed_cell
        row = index // cols
        col = index % cols
        rect_x1 = px
        rect_y1 = py
        rect_x2 = px + cell
    def set_cell_size(self, size: int = None):
        if size is None:
        self.scale_factor = size
        self.Redraw()
        # 绘制背景
            # 获取绘制位置
            # 绘制背景
            self.DrawSetPen(self.bg_color_01)
            cols, actual_cell = self._calc_grid(
            self.GetWidth(),
            self.base_size,
            self.padding,
            self.min_size,
            self.max_size,
            self.scale_factor
            cell = int(actual_cell)
            # 缩放计算
            # 鼠标选中边缘高光绘制
                expand = border_thickness + 2
                self.DrawFrame(px - expand, py - expand, px2 + expand, py2 + expand, lineWidth=border_thickness)
            # 绘制图片背景
            self.DrawSetPen(1001)
            self.DrawRectangle(px, py, px + cell, py + cell)
            # 绘制图片
            self.DrawBitmap(bitmap, ox, oy, dw, dh, 0, 0, image_orig_width, image_orig_height,
                            c4d.BMP_ALLOWALPHA | c4d.BMP_NORMALSCALED)
            # 绘制文字
            text_width = self.DrawGetTextWidth(name)
            text_x = px + cell // 2 - text_width // 2
            text_y = py + cell + self.padding // 2
            self.DrawSetTextCol(1, self.bg_color_01)
            self.DrawSetFont(c4d.FONT_DEFAULT | c4d.FONT_BIG | c4d.FONT_BIG_BOLD)
            self.DrawText(name, text_x, text_y, c4d.DRAWTEXT_STD_ALIGN)
    def InputEvent(self, msg):
        # 判断事件是否为鼠标滚轮，并且有修饰键按下（QUALIFIER，例如 Ctrl/Shift）
        if msg[c4d.BFM_INPUT_CHANNEL] == c4d.BFM_INPUT_MOUSEWHEEL and msg[c4d.BFM_INPUT_QUALIFIER]:
            delta = msg.GetInt32(c4d.BFM_INPUT_VALUE)  # 获取滚轮的数值（正=向上，负=向下）
            size = self.scale_factor  # 当前缩放因子
            # 根据滚轮方向调整缩放因子
            if delta &lt; 0:
                size -= 0.05  # 滚轮向下 → 缩小
                size += 0.05  # 滚轮向上 → 放大
            # 限制缩放范围在 [0.4, 2.0] 之间
            size = max(0.4, min(2.0, size))
            # 只有在新值和旧值不同的时候才更新（避免重复刷新）
            if size != self.scale_factor:
                self.set_cell_size(self.scale_factor)  # 应用新的缩放因子到 UI
            actual_x = local_x
            actual_y = local_y + scroll_y
            self.on_click(actual_x, actual_y)
            # 使用完整的 _get_cell_rect 公式来计算卡片矩形
                index=index,                        # 当前卡片索引
                area_width=self.GetWidth(),         # 用户区域宽度
                base_size=self.base_size,           # 基础 cell 大小（默认 128px）
                padding=self.padding,               # cell 间距
                min_size=self.min_size,             # 最小 cell 尺寸
                max_size=self.max_size,             # 最大 cell 尺寸
                text_height=text_height,       # 文字高度（需要在类里存好）
                scale_factor=self.scale_factor      # 缩放因子（用户滑动控制）
            # 判断点击坐标是否在当前卡片矩形内
                self.Redraw()  # 触发重绘，显示选中效果
                # 发送点击消息给父级
                magContainer = BaseContainer(ID_MSG_KIDOO_SHOT_MANAGER_IMAGE_CLICKED)
                magContainer.SetInt32(0, index)
                magContainer.SetString(1, name)
                self.SendParentMessage(magContainer)
                break
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/76783</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/76783</guid><dc:creator><![CDATA[Amazing_iKe]]></dc:creator><pubDate>Tue, 26 Aug 2025 11:40:44 GMT</pubDate></item><item><title><![CDATA[Reply to [GeUserArea] Click detection selects wrong item when clicking on lower part of cell (image + text area) on Tue, 26 Aug 2025 11:34:01 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/amazing_ike">@<bdi>Amazing_iKe</bdi></a>,</p>
<p dir="auto">thank you for reaching out to us. I cannot execute your code example like this. Please provide an executable example. And as far as I can see, that also seems to be your own code which fails there and not one of our API calls? We cannot debug your code for you. Or is there a specific API call which is failing for you?</p>
<p dir="auto">My recommendation would be more abstraction, all this function shuffling especially in the context of GUIs gets really confusing really quick. I would write myself a <code>Grid</code> and a <code>GridItem</code> class which encapsulate the items and their hit logic. What matters also is how you feed <code>def on_click(self, x, y)</code>. There are local (e.g. within a user area) and global (e.g., within a dialog or screen) coordinate systems.</p>
Ferdinand</p>
]]></description><link>http://developers.maxon.net/forum/post/76782</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/76782</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Tue, 26 Aug 2025 11:34:01 GMT</pubDate></item></channel></rss>
