<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to use ctypes library with Object Plugin properly?]]></title><description><![CDATA[<p dir="auto">Hello guys!<br />
I need to connect an C lang written lib to make some calculation during getting spline object. Here is a raw example with some details in a comments. Important part: cache created inside lib object. It must be existing during livetime of the Object and free before removing. What is best way to implement this approach?  Thx!</p>
<pre><code>
from ctypes import *
class MyPluginData(c4d.plugins.ObjectData):
    """SomeObject Generator"""
    self.Init(node, isCloneInit):
        # It must be called once on object creation and can't be rewritten
        lib = CDLL('my_lib.so') #or dll on Windows
    self.Free(node):
        """ If your class has a destructor it is called as usual after this function. """
        # It must be called on system sleep, app close, object deletion etc.
        # to avoid memory leaks
        lib.cleanup()
    self.GetContour(op, doc, lod, bt):
        """ Here we using lib by calling some lib.foo() and lib.bar()"""
        # During the execution lib object creates some cache that must be cleaned up after object destruction
        data = lib.foo()
        # process data
        return some_spline
</code></pre>
]]></description><link>http://developers.maxon.net/forum/topic/15522/how-to-use-ctypes-library-with-object-plugin-properly</link><generator>RSS for Node</generator><lastBuildDate>Sat, 12 Sep 2026 20:34:30 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/15522.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 May 2024 20:12:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to use ctypes library with Object Plugin properly? on Thu, 09 May 2024 18:56:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a> Thank very much! i'll check what can i do. <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f914.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--thinking_face" style="height:23px;width:auto;vertical-align:middle" title="🤔" alt="🤔" /></p>
]]></description><link>http://developers.maxon.net/forum/post/74311</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/74311</guid><dc:creator><![CDATA[mikeudin]]></dc:creator><pubDate>Thu, 09 May 2024 18:56:16 GMT</pubDate></item><item><title><![CDATA[Reply to How to use ctypes library with Object Plugin properly? on Thu, 09 May 2024 05:13:21 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/mikeudin">@<bdi>mikeudin</bdi></a>,</p>
<p dir="auto">Thank you for reaching out to us. How to use <code>ctypes</code> is clearly out of scope of support. I therefore moved your thread. What to do in the context of Cinema 4D with external libraries is also a very wide field and there are no absolute rules.</p>
<p dir="auto">I would recommend having a look at the Python docs itself because they are pretty good in this context: <a href="https://docs.python.org/3/library/ctypes.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.python.org/3/library/ctypes.html</a></p>
<ul>
<li>I would avoid loading the shared library with each instance of your plugin (you call <code>CDLL</code> in what seems to be meant to be your <code>NodeData.Init</code>). That is not only insanely expensive, you might also run into problems with file access. Cinema 4D allocates and deallocates nodes very often.</li>
<li><code>ctypes</code> has its own threading logic (see docs) which can lead to problems just in standard CPython. The Cinema 4D Python is extra-special when it comes to threading, so you might run there into further problems.</li>
<li>The <code>ctypes</code> docs make it a bit look like that you can just magically convert all data from Python to C and back. This is true for atomic types. But for more complex data you will have to use <code>struct</code> or the tools of <code>ctypes</code> (which are just a wrapper around <code>struct</code> I think). Doing that, converting raw memory manually in Python itself, is not the fastest thing in the world. If you just want to convert a few bytes of data that is okay. But when you have a spline with 2000 points with two tangents each, i.e., 6000 vectors, i.e., 18000 floats, and you want to first push this data into C and then back pull an equally complex result back, AND want to do this in a perfromant manner (the user is scrubbing a parameter slider in your plugin), this can become a bottleneck. Splines are relatively harmless I would say, as it is rare that you produce here truly heavy data, but this could still become a problem.</li>
</ul>
<p dir="auto">Maybe <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/m_adam">@<bdi>m_adam</bdi></a> has something to add here, he knows more about this. But you are on your own here, third party libs and their usage are out of scope of support.</p>
<p dir="auto">Cheers,<br />
Ferdinand</p>
]]></description><link>http://developers.maxon.net/forum/post/74304</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/74304</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Thu, 09 May 2024 05:13:21 GMT</pubDate></item></channel></rss>
