<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error compiling R23 framework]]></title><description><![CDATA[<p dir="auto">I've downloaded the latest R23 SDK from here: <a href="https://developers.maxon.net/downloads/Cinema_4D_CPP_SDK_23_107.zip" target="_blank" rel="noopener noreferrer nofollow ugc">https://developers.maxon.net/downloads/Cinema_4D_CPP_SDK_23_107.zip</a><br />
I then ran the Project Tool to generate the project files.<br />
When I compile the math.framework project in VS I get the following error:</p>
<pre><code>2&gt;kdtree.cpp
2&gt;C:\Temp\sdk_check\frameworks\core.framework\source\maxon\utilities\resultbase.h(571,4): error C2079: 'maxon::ResultBase&lt;RESULT_TYPE&gt;::_value' uses undefined class 'maxon::BlendAnimationRef'
2&gt;        with
2&gt;        [
2&gt;            RESULT_TYPE=maxon::BlendAnimationRef
2&gt;        ] (compiling source file ..\source\maxon\blend_animation.cpp)
2&gt;C:\Temp\sdk_check\frameworks\core.framework\source\maxon\utilities\resultbase.h(760): message : see reference to class template instantiation 'maxon::ResultBase&lt;RESULT_TYPE&gt;' being compiled
2&gt;        with
2&gt;        [
2&gt;C:\Temp\sdk_check\frameworks\core.framework\source\maxon\objectbase.h(1287): message : see reference to class template instantiation 'maxon::Result&lt;maxon::BlendAnimationRef&gt;' being compiled (compiling source file ..\source\maxon\blend_animation.cpp)
2&gt;        with
2&gt;        [
2&gt;        ] (compiling source file ..\generated\hxx\register.cpp)
2&gt;        with
2&gt;        [
2&gt;C:\Temp\sdk_check\frameworks\core.framework\source\maxon\objectbase.h(1287): message : see reference to class template instantiation 'maxon::Result&lt;maxon::BlendAnimationRef&gt;' being compiled (compiling source file ..\generated\hxx\register.cpp)
</code></pre>
<p dir="auto">As per this post I understood that this issue was resolved: <a href="https://developers.maxon.net/forum/topic/13244/build-fails-with-r23-sdk/3" target="_blank" rel="noopener noreferrer nofollow ugc">https://developers.maxon.net/forum/topic/13244/build-fails-with-r23-sdk/3</a><br />
However it seems not.<br />
Thanks.</p>
]]></description><link>http://developers.maxon.net/forum/topic/15514/error-compiling-r23-framework</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 16:51:29 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/15514.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 May 2024 00:49:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error compiling R23 framework on Wed, 08 May 2024 13:08:10 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/dgould">@<bdi>dgould</bdi></a>,<br />
Welcome to the Maxon developers forum and its community, it is great to have you with us!</p>
<h4>Getting Started</h4>
<p dir="auto">Before creating your next postings, we would recommend making yourself accustomed with our forum and support procedures. You did not do anything wrong, we point all new users to these rules.</p>
<ul>
<li><a href="topic/15242/" target="_blank" rel="noopener noreferrer nofollow ugc">Forum Overview</a>: Provides a broad overview of the fundamental structure and rules of this forum, such as the purpose of the different sub-forums or the fact that we will ban users who engage in hate speech or harassment.</li>
<li><a href="/topic/15244/" target="_blank" rel="noopener noreferrer nofollow ugc">Support Procedures</a>: Provides a more in detail overview of how we provide technical support for APIs here. This topic will tell you how to ask good questions and limits of our technical support.</li>
<li><a href="/topic/15243/" target="_blank" rel="noopener noreferrer nofollow ugc">Forum Features</a>: Provides an overview of the technical features of this forum, such as Markdown markup or file uploads.</li>
</ul>
<p dir="auto">It is <strong>strongly</strong> recommended to read the first two topics carefully, especially the section <a href="/topic/15244/" target="_blank" rel="noopener noreferrer nofollow ugc">Support Procedures: Asking Questions</a>.</p>
<h4>About your First Question</h4>
<p dir="auto">You are completely right with finding the thread with the answer: Manuel posted in a separate thread the solution for this issue: <a href="https://developers.maxon.net/forum/topic/13249/building-r23-sdk-with-visual-studio-16-9" target="_blank" rel="noopener noreferrer nofollow ugc">Building R23 SDK with Visual Studio 16.9</a>.</p>
<p dir="auto">As he states there inside the R23.107 sdk you need to find the file frameworks/core.framework/source/maxon/objectbase.h and make there two changes. This will allow your solution to build without errors.</p>
<p dir="auto">The issue was later resolved in S24 and onwards, so there's no need in changing this file there.</p>
<p dir="auto">Cheers,<br />
Ilia</p>
]]></description><link>http://developers.maxon.net/forum/post/74292</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/74292</guid><dc:creator><![CDATA[i_mazlov]]></dc:creator><pubDate>Wed, 08 May 2024 13:08:10 GMT</pubDate></item></channel></rss>
