<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adding material node to menu category]]></title><description><![CDATA[<p dir="auto">I'm creating a new node intended for use in the material node editor. I've made scene nodes before and they all work fine, but I'm having trouble with this one.</p>
<p dir="auto">The problem is that no matter what menu category I specify in the resource editor, the node always goes into the 'Uncategorized' group. As a result I can only use the node in the node editor's 'Scene' mode, not 'Material' mode as the uncategorized section isn't availalble in material mode. The resource editor looks like this:</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1713448787926-node_category.png" alt="node_category.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">So I've selected the Color category and in the .json file for the database it shows this:<br />
<img src="/forum/assets/uploads/files/1713448835128-node_category_json.png" alt="node_category_json.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">So the node should go into the Color group...but it doesn't. What am I doing wrong?</p>
<p dir="auto">Thanks,<br />
Steve</p>
]]></description><link>http://developers.maxon.net/forum/topic/15485/adding-material-node-to-menu-category</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 18:37:24 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/15485.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Apr 2024 14:02:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Adding material node to menu category on Fri, 19 Apr 2024 12:55:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/spedler">@<bdi>spedler</bdi></a> regarding your issue, it's correct all changes done within the resource editor need to be saved, via the menu (file -&gt; Save Database) otherwise change will get lost.</p>
<p dir="auto">Regarding the needs for the double-click, that's a missing refresh in our cache, I've reported to the responsible dev, thanks a lot !</p>
<p dir="auto">Cheers,<br />
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/74168</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/74168</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Fri, 19 Apr 2024 12:55:01 GMT</pubDate></item><item><title><![CDATA[Reply to Adding material node to menu category on Thu, 18 Apr 2024 15:44:12 GMT]]></title><description><![CDATA[<p dir="auto">I think I've solved this one (as so often happens when you write down a question the answer hits you soon after!).</p>
<p dir="auto">When the node category is changed, if I right-click the node in the Uncategorized group, and select 'Create Node' the node is automatically removed from Uncategorized and put into the Color group. As long as I save the database, from then on it always appears in 'Color'. So that's fine.</p>
<p dir="auto">One other thing I've discovered, if you change the node icon in the resource editor, to make it change in the node list just double-click the node and the icon will change. Whether that's the 'correct' way to change the icon I don't know, but it works.</p>
<p dir="auto">Anyway, this one can be marked as closed.</p>
<p dir="auto">Steve</p>
]]></description><link>http://developers.maxon.net/forum/post/74163</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/74163</guid><dc:creator><![CDATA[spedler]]></dc:creator><pubDate>Thu, 18 Apr 2024 15:44:12 GMT</pubDate></item></channel></rss>
