<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Multiple unique render files from same file?]]></title><description><![CDATA[<p dir="auto">This concept of rendering multiple unique render paths was touched on here: <a href="https://developers.maxon.net/forum/topic/13061/adding-multiple-cameras-from-a-single-file-to-the-render-queue/22" target="_blank" rel="noopener noreferrer nofollow ugc">https://developers.maxon.net/forum/topic/13061/adding-multiple-cameras-from-a-single-file-to-the-render-queue/22</a></p>
<p dir="auto">The solution works pretty well but duplicates the source file multiple times.</p>
<p dir="auto">My goal is to have a workflow where multiple objects in the same file can be rendered with their object name as their own jpeg.  I am using an In/Ex User data and python generator to achieve this.   The problem is the jpegs get overwritten each time.<br />
I am trying to figure out a way to add a batch render element that waits until the render completes then adds a new file with the next object iteration.</p>
<p dir="auto">I am posting my scene file and python here.     <a href="https://developers.maxon.net/forum/assets/uploads/files/1702449680304-multisavepath_01.c4d" target="_blank" rel="noopener noreferrer nofollow ugc">MultiSavePath_01.c4d</a></p>
<pre><code>import c4d
from c4d import gui, storage
import os
import fileinput
#The goal is to render multiple files with unique render paths from this one file.   I have this code in a python generator
#with and in/ex user data, the code iterates through in/ex updating the render path and starting the render.  The problem
#is the render path and jpeg get overwritten to the same file.   How do I render four separete jpeg files named Cylinder, Sphere, Cube and Figure?
#thank you for any help!
def message(id,data) :   #Button listener
    if id == c4d.MSG_DESCRIPTION_CHECKUPDATE:
        if data["descid"][1].dtype == c4d.DTYPE_BUTTON or c4d.DTYPE_LONG:
            buttonID = data["descid"][1].id
            if buttonID == 2:
               SendShotsToRender() #SEND TO RENDER
def SendShotsToRender():
    print("Send Shots To Render")
    br = c4d.documents.GetBatchRender()
    rd = doc.GetActiveRenderData()
    br.Open() #Open the render queue window
    c4d.CallCommand(465003519) # Clear render queue of old render files
    inEx = op[c4d.ID_USERDATA,4] # In/Exclude User Data
    inExCount = inEx.GetObjectCount() #how many shots in our In/Exclude
    shot = op[c4d.ID_USERDATA,1] #The currently active shot
    for i in range(0,inExCount):  #Iterate through each shot based on our shot slider in user data
        activeObj = inEx.ObjectFromIndex(doc, i) #deterimine which object is active
        render_filename = inEx.ObjectFromIndex(doc, i).GetName()  #Gets the name of the currently active object
        rd[c4d.RDATA_PATH] = render_filename  #Set the render files name
        source_file = doc.GetDocumentPath() + "/" + doc.GetDocumentName() #get the source document path
        br.AddFile(source_file,0)  #Add the source file
        br.SetRendering(c4d.BR_START) #start rendering
        #print(br.GetElementStatus(c4d.RM_FINISHED))  #Is there a way I can wait for the render to finish then delete the file update the path and add a new one?
        #br.DelFile(source_file)
        if shot != i:
                activeObj[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = True  #turn visibility On
                activeObj[c4d.ID_BASEOBJECT_VISIBILITY_RENDER] = True
                activeObj[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = False  #turn visibility Off
                activeObj[c4d.ID_BASEOBJECT_VISIBILITY_RENDER] = False
        print(i,render_filename)
        op[c4d.ID_USERDATA,4] = inEx  #write back to the IN/EXCLUDE list
</code></pre>
]]></description><link>http://developers.maxon.net/forum/topic/15280/multiple-unique-render-files-from-same-file</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 20:37:04 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/15280.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Dec 2023 06:44:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Multiple unique render files from same file? on Sat, 16 Dec 2023 18:51:56 GMT]]></title><description><![CDATA[<p dir="auto">Ok, I ran into the issue of polling the BatchRender.IsRendering.   I don't have the python skills to do multi-threading to check when a render is complete.   I was able to hack in a time.sleep function but it is very problematic for longer renders and crashes a lot.</p>
<p dir="auto">Instead I went the route of Takes though Take are a bit cumbersome to setup but it is working nicely.  I'll post the code here for anyone looking to do something similiar.   I can just RenderAllTakes command and get each object rendered with its name using a $Take render token.</p>
<pre><code>def main():
    for i in range(0 , op[c4d.ID_USERDATA,4].GetObjectCount()):  #Iterate through each shot based on our shot slider in user data
        if op[c4d.ID_USERDATA,1] == i:
            activeObj[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = False  #turn visibility On
            op[c4d.ID_USERDATA,5] = render_filename
            activeObj[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = True  #turn visibility Off
################   SEND ALL
def BuildTakes():
    #Sequencer()
    takedata = doc.GetTakeData()
    obj = doc.GetActiveObject()
    #print( Description.GetParameterI(op[c4d.ID_USERDATA,1], ar=None))
    for i in range(0,op[c4d.ID_USERDATA,4].GetObjectCount()):
        #Sequencer()
        take = takedata.AddTake(inEx.ObjectFromIndex(doc, i).GetName(), None, None)
        take.FindOrAddOverrideParam(takedata, obj                         , c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA, c4d.DTYPE_SUBCONTAINER, 1),c4d.DescLevel(1)), i ,  backupValue=None, deleteAnim=False)
        take.FindOrAddOverrideParam(takedata, inEx.ObjectFromIndex(doc, i), c4d.ID_BASEOBJECT_VISIBILITY_EDITOR, False, backupValue=None, deleteAnim=False)
        take.FindOrAddOverrideParam(takedata, inEx.ObjectFromIndex(doc, i), c4d.ID_BASEOBJECT_VISIBILITY_RENDER, False, backupValue=None, deleteAnim=False)
        #op[c4d.ID_USERDATA,1] = 0
        #Sequencer()
        #c4d.MSG_DESCRIPTION_CHECKUPDATE
    #Sequencer()
    #c4d.EventAdd()
def ClearTakes():
    tk = doc.GetTakeData()
    tk.ResetSystem()
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/73350</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/73350</guid><dc:creator><![CDATA[gsmetzer]]></dc:creator><pubDate>Sat, 16 Dec 2023 18:51:56 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple unique render files from same file? on Thu, 14 Dec 2023 21:56:50 GMT]]></title><description><![CDATA[<p dir="auto">Yes, I was able to make it work by pausing the script until IsRendering returns false.    It is working really nice, naming my jpegs correctly and is very simple to setup by just dropping the objects I want rendered into the In/Ex list.   This workflow is great when I have over 100 objects I want rendered on their own.</p>
<p dir="auto">I could use RenderDocument and the Take system but I have not developed a python way to iterate through scene objects - make object visible - assign a take with visibility settings - render with only that object visible.   I do believe it is possible and another route I could take.   I may try to develop this method as well to compare workflow but I find the Take system cumbersome for bigger jobs.</p>
<p dir="auto">Cheers,<br />
Gabriel</p>
]]></description><link>http://developers.maxon.net/forum/post/73332</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/73332</guid><dc:creator><![CDATA[gsmetzer]]></dc:creator><pubDate>Thu, 14 Dec 2023 21:56:50 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple unique render files from same file? on Thu, 14 Dec 2023 09:36:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi, within a script this will be complicated since there is no built-in way for listening to the end of a rendering in the BatchRender.</p>
<p dir="auto">But with a plugin, you could have a timer (see <a href="https://developers.maxon.net/docs/py/2024_0_0a/modules/c4d.plugins/BaseData/MessageData/index.html?highlight=timer#c4d.plugins.MessageData" target="_blank" rel="noopener noreferrer nofollow ugc">MessageData Documentation</a>) that constantly check if the BatchRender is rendering with <a href="https://developers.maxon.net/docs/py/2024_0_0a/modules/c4d.documents/BatchRender/index.html?highlight=batchrender#BatchRender.IsRendering" target="_blank" rel="noopener noreferrer nofollow ugc">BatchRender.IsRendering</a> and if it is not rendering then you can modify the file, save it and add it to the BatchRender again.<br />
You will also most likely need a CommandData plugin so this way the user can start the execution. This command data can just define a global boolean value that your Timer message always check and if the value is True, then it start the processing of a file.</p>
<p dir="auto">One stupid question, but at this point since you will need to do all the queues logic, why not directly render the document, using <a href="https://developers.maxon.net/docs/py/2024_0_0a/modules/c4d.documents/index.html?highlight=renderdocument#c4d.documents.RenderDocument" target="_blank" rel="noopener noreferrer nofollow ugc">RenderDocument</a> then you do not need a timer neither to save the doc each time.</p>
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/73325</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/73325</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Thu, 14 Dec 2023 09:36:51 GMT</pubDate></item></channel></rss>
