<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bug R23? Viewport Render Aborts with Physical Renderer]]></title><description><![CDATA[<p dir="auto">Hi I did a small ObjectPlugin Test,</p>
<p dir="auto">I created a temp_doc and loaded a file into with textures.<br />
The textures do not work in this examples because file size is too big to upload here.<br />
I created a container(null) put the clone of a specific polygon object in the temp_doc into this null and returned the null.<br />
Just to test if it returnes at least the polygon-object without materials.</p>
<p dir="auto">When I render in viewport Standard, Redshift and Corona are rendering, just Physical Renderer aborts the rendering.<br />
This is just in versions R23 and below I guess.</p>
<p dir="auto">Here is the code:</p>
<pre><code>import c4d
from c4d import plugins, bitmaps
import os
PLUGIN_ID = 1234567  # Just for testing
class Testcity(plugins.ObjectData):
    def __init__(self):
        self.SetOptimizeCache(True)
    def Init(self, op):
    def GetVirtualObjects(self, op, hh):
        model = os.path.join(model_path, "build_0.c4d")
        new_doc = c4d.documents.BaseDocument()
        c4d.documents.MergeDocument(new_doc, model, loadflags=c4d.SCENEFILTER_OBJECTS | c4d.SCENEFILTER_MATERIALS)
        model = new_doc.GetFirstObject().GetDown().GetDown().GetClone()
        null = c4d.BaseObject(c4d.Onull)
        model.InsertUnder(null)
        return null
    path, file = os.path.split(__file__)
    file = "icon.tif"
    new_path = os.path.join(path, "res", file)
    model_path = os.path.join(path, "res", "models", "models", "0_Standard", "build_0")
    bitmap = bitmaps.BaseBitmap()
    bitmap.InitWith(new_path)
    plugins.RegisterObjectPlugin(id=PLUGIN_ID, str="testcity", g=Testcity, description="testcity", icon=bitmap,
                                 info=c4d.OBJECT_GENERATOR)
</code></pre>
<p dir="auto">PluginFile<br />
<a href="https://developers.maxon.net/forum/assets/uploads/files/1686997024018-testcity.zip" target="_blank" rel="noopener noreferrer nofollow ugc">testcity.zip</a></p>
]]></description><link>http://developers.maxon.net/forum/topic/14789/bug-r23-viewport-render-aborts-with-physical-renderer</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 22:36:59 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/14789.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 17 Jun 2023 10:19:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bug R23? Viewport Render Aborts with Physical Renderer on Thu, 10 Aug 2023 07:56:58 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/thomasb">@<bdi>ThomasB</bdi></a> ,</p>
<p dir="auto">without further questions or postings, we will consider this topic as solved by Friday, the 11th of august 2023 and flag it accordingly.</p>
<p dir="auto">Thank you for your understanding,<br />
Maxon SDK Group</p>
]]></description><link>http://developers.maxon.net/forum/post/72219</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72219</guid><dc:creator><![CDATA[jana]]></dc:creator><pubDate>Thu, 10 Aug 2023 07:56:58 GMT</pubDate></item><item><title><![CDATA[Reply to Bug R23? Viewport Render Aborts with Physical Renderer on Tue, 20 Jun 2023 00:30:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a><br />
thank you ferdinand the plugin is just a small example of the original. the orginal is much more complicated and with textures.<br />
so thank you for this hint, with broken mat references.</p>
<p dir="auto">I am aware of that, that it always loads the document. I was unsure about that too. So your CacheMethod handles that...right.</p>
<p dir="auto">So first I did this all in the Message() Method in the main Thread the doc creation and so forth...after the user chose a model and pressed <a href="http://refresh.So" target="_blank" rel="noopener noreferrer nofollow ugc">refresh.So</a> I just switched because it did not work so there must be a bug in my old version. I loaded the doc into a membervariable like you in the CachMethod.....hmmm</p>
<p dir="auto">Well thank you so far Ferdinad...</p>
]]></description><link>http://developers.maxon.net/forum/post/71824</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71824</guid><dc:creator><![CDATA[ThomasB]]></dc:creator><pubDate>Tue, 20 Jun 2023 00:30:08 GMT</pubDate></item><item><title><![CDATA[Reply to Bug R23? Viewport Render Aborts with Physical Renderer on Mon, 19 Jun 2023 18:39:56 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/thomasb">@<bdi>ThomasB</bdi></a>,</p>
<p dir="auto">Thank you for reaching out to us. This is not a bug, at least not a big one. You clone from a document with materials but do not include these materials in the document. Your cache then contains a broken material reference. Just CTSO your object and you will see that it contains such unresolving material link.</p>
<p dir="auto">That Physical does not render generators which contain unresolving material references in their caches is probably strictly speaking a bug. But generators should not include any form of material reference in their caches. Because that requires the object managing its own materials which tends to end up in a mess. In your <code>GetVirtualObjects</code> (GVO), you cannot insert materials into the document the node is contained in due to threading restrictions.</p>
<p dir="auto">Also you loading a document in <code>GVO</code> is a really bad idea. Imagine a user having 100 of your city-objects in a scene with 100 keyframes each. That means 10,000 file access operations, which could be one, yikes! But we are also not on the MT in GVO so the method is executed in parallel, which easily could lead to access violations when two objects are trying to read the same file at the same time.</p>
<p dir="auto">Cheers,<br />
Ferdinand</p>
<p dir="auto">File: <a href="https://developers.maxon.net/forum/assets/uploads/files/1687199874829-testcity.zip" target="_blank" rel="noopener noreferrer nofollow ugc">testcity.zip</a></p>
<p dir="auto">Result: I just modified your source file and removed all material links there and your plugin will render in the viewport with Physical.</p>
<p dir="auto"><img src="https://developers.maxon.net/forum/assets/uploads/files/1687199665610-c5ada9c6-e7c7-4e16-a7f7-accc5eaf1198-image-resized.png" alt="c5ada9c6-e7c7-4e16-a7f7-accc5eaf1198-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Code:</p>
<pre><code class="language-py">import os
class Testcity(c4d.plugins.ObjectData):
    ROOT, _ = os.path.split(__file__)
    # The files to load.
    FILE_PATHS = {
        "build_0": os.path.join(
            ROOT, "res", "models", "models", "0_Standard", "build_0", "build_0.c4d")
    # And the cache.
    DOCUMENT_CACHE = {}
    @classmethod
    def CheckDocumentCache(cls):
        """Rebuilds the document cache.
        if isinstance(cls.DOCUMENT_CACHE, dict) and len(cls.DOCUMENT_CACHE) &gt; 1:
            isDirty = False
            for key, value in cls.DOCUMENT_CACHE.items():
                if not isinstance(value, c4d.documents.BaseDocument) or not value.IsAlive():
                    isDirty = True
                    break
            if not isDirty:
        for key, value in cls.FILE_PATHS.items():
            if not os.path.exists(value):
                raise OSError(f"File path '{value}' does not exist.")
            cls.DOCUMENT_CACHE[key] = c4d.documents.LoadDocument(value, c4d.SCENEFILTER_OBJECTS)
    def __init__(self):
    def Init(self, node):
        self.CheckDocumentCache()
        doc = self.DOCUMENT_CACHE.get("build_0", None)
        if not doc or not doc.IsAlive():
            return c4d.BaseObject(c4d.Onull)
        # When doing such chained calls which can fail use error handling.
        try:
            clone = doc.GetFirstObject().GetDown().GetDown().GetClone()
        except:
        # Something went really wrong, either #doc is not what we think it is or we cannot even
        # allocate a null object anymore. Indicate a memory error by returning #False.
        if None in (clone, null):
            return False
        clone.InsertUnder(null)
        return null
    file = "icon.tif"
    bitmap = c4d.bitmaps.BaseBitmap()
    c4d.plugins.RegisterObjectPlugin(
        id=PLUGIN_ID, str="testcity", g=Testcity, description="otestcity", icon=bitmap,
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/71820</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71820</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Mon, 19 Jun 2023 18:39:56 GMT</pubDate></item></channel></rss>
