<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TranslateDescID with FieldsList]]></title><description><![CDATA[<p dir="auto">Hello everyone!<br />
I found a critical memory leaking bug with <a href="https://github.com/PluginCafe/cinema4d_py_sdk_extended/blob/c7116c37eb7bb357294d60dd009aebb7e044153f/plugins/py-dynamic_parameters_object_r18/py-dynamic_parameters_object_r18.pyp#L290" target="_blank" rel="noopener noreferrer nofollow ugc">TranslateDescID</a> and FieldsList.<br />
I have a ObjectData plugin and TagData plugin. Object plugin translates some DescId with tags one of them is a fieldlist. When i add to Objects fieldlist regular field layer like Linear, Formula etc. it works fine, but some layers makes crash: Time, Delay... When i add Time, Delay to tags fieldslists directly it works with no issue. Crush happens only with ObjectData fieldslist connected by TranslateDescID with tags.</p>
]]></description><link>http://developers.maxon.net/forum/topic/14779/translatedescid-with-fieldslist</link><generator>RSS for Node</generator><lastBuildDate>Tue, 13 Oct 2026 19:20:49 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/14779.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 15 Jun 2023 10:50:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TranslateDescID with FieldsList on Fri, 07 Jul 2023 08:39:31 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/mikeudin">@<bdi>mikeudin</bdi></a>,</p>
<p dir="auto">just as an FYI, one of our engineers pointed out that <a href="https://developers.maxon.net/docs/py/2023_2/modules/c4d/Description/index.html?highlight=checkdescid#Description.CheckDescID" target="_blank" rel="noopener noreferrer nofollow ugc">Description.CheckDescID</a> is the likely culprit for the problem and that this method should be avoided when possible due to its resource hungry nature. Instead, you would just manually define the parameter ID you mean, e.g., <code>c4d.DescID(c4d.ID_TAGFIELDS)</code>. The problem with this is of course that this statement has been made disjunct from the dynamic parameters example because I stripped that aspect away in my minimized code.</p>
<p dir="auto">The <a href="https://github.com/PluginCafe/cinema4d_py_sdk_extended/blob/master/plugins/py-dynamic_parameters_object_r18/py-dynamic_parameters_object_r18.pyp#L323" target="_blank" rel="noopener noreferrer nofollow ugc">original code example</a> says:</p>
<pre><code class="language-py"># Fills DescLever type and creator
completeId = desc.CheckDescID(descId, None)
return True, completeId, tag
</code></pre>
<p dir="auto">So, they seem to be only after filling in the data type and creator ID and not resolving multi-level IDs. Which you could also do manually when you know the parameters you want to wrap, e.g.,:</p>
<pre><code>descId: c4d.DescID = c4d.DescID(c4d.DescLevel(c4d.ID_TAGFIELDS,
                                              c4d.CUSTOMDATATYPE_FIELDLIST,
                                              c4d.MAXON_CREATOR_ID))
return True, descId, tag
</code></pre>
<p dir="auto">Cheers,<br />
Ferdinand</p>
]]></description><link>http://developers.maxon.net/forum/post/72005</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72005</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Fri, 07 Jul 2023 08:39:31 GMT</pubDate></item><item><title><![CDATA[Reply to TranslateDescID with FieldsList on Fri, 23 Jun 2023 09:08:49 GMT]]></title><description><![CDATA[<p dir="auto">Thank you <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a>!<br />
Will try to found out the workaround.</p>
]]></description><link>http://developers.maxon.net/forum/post/71863</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71863</guid><dc:creator><![CDATA[mikeudin]]></dc:creator><pubDate>Fri, 23 Jun 2023 09:08:49 GMT</pubDate></item><item><title><![CDATA[Reply to TranslateDescID with FieldsList on Thu, 22 Jun 2023 16:40:32 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/mikeudin">@<bdi>mikeudin</bdi></a>,</p>
<p dir="auto">So, I gave this a spin and there is nothing one can do from the user side to prevent this. Cinema 4D freezes and when you attach a debugger, you end up in an access violation for a string trying to construct a <code>BaseRef</code> on another string, although that is certainly not the core of the bug and more its final symptom.</p>
<p dir="auto">The crux is here the <em>Time</em> field which then indeed leads to sort of a memory leak in that Cinema 4D keeps looping between your and the variable tag, trying to copy that string and in the process allocating more and more memory. But that is not because memory is not correctly freed but because this TranslateDescID Time field setup creates an infinite recursion more or less.</p>
<p dir="auto">I filed a bug report for this but have flagged it as low priority due to the foreseeable problems that arise from mapping one fieldlist to another in this manner via <code>TranslateDescId</code>. But maybe the responsible dev will see it differently and raise the priority. I have also flagged this topic as <code>to_fix</code>.</p>
Ferdinand</p>
<p dir="auto">The minimal code to induce the problem:</p>
<pre><code class="language-py">"""
PLUGIN_ID = 1037871
class DynamicParametersObjectData(c4d.plugins.ObjectData):
    def Init(self, node):
        self.parameters = []
        self.InitAttr(node, c4d.FieldList, c4d.TEXT_ANIMATOR_FIELDS)
        node[c4d.TEXT_ANIMATOR_FIELDS] = c4d.FieldList()
    def Message(self, node, mid, _):
        if mid == c4d.MSG_MENUPREPARE:
            pTag = node.MakeTag(c4d.Tvertexmap)
            if pTag is None:
                raise MemoryError()
            pTag[c4d.ID_TAGFIELD_ENABLE] = True
    def TranslateDescID(self, node, id):
        if id[0].id == c4d.TEXT_ANIMATOR_FIELDS:
            tag = node.GetTag(c4d.Tvertexmap)
            if not tag:
                return False
            desc = tag.GetDescription(c4d.DESCFLAGS_DESC_NONE)
            if not desc:
                return False
            return True, desc.CheckDescID(c4d.DescID(c4d.ID_TAGFIELDS), None), tag
        return False
    def GetVirtualObjects(self, op, hh):
        return c4d.BaseObject(c4d.Onull)
    c4d.plugins.RegisterObjectPlugin(id=PLUGIN_ID,
                                     str="Py-DynamicParametersObject",
                                     g=DynamicParametersObjectData,
                                     description="opydynamicparametersobject",
                                     icon=c4d.bitmaps.InitResourceBitmap(c4d.Onull),
                                     info=c4d.OBJECT_GENERATOR)
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/71854</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71854</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Thu, 22 Jun 2023 16:40:32 GMT</pubDate></item><item><title><![CDATA[Reply to TranslateDescID with FieldsList on Tue, 20 Jun 2023 16:24:37 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/mikeudin">@<bdi>mikeudin</bdi></a>,</p>
<p dir="auto">just as an FYI, I am working myself through my backlog, and your case has not been forgotten. I will have a look at it next <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
Ferdinand</p>
]]></description><link>http://developers.maxon.net/forum/post/71835</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71835</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Tue, 20 Jun 2023 16:24:37 GMT</pubDate></item><item><title><![CDATA[Reply to TranslateDescID with FieldsList on Thu, 15 Jun 2023 14:27:48 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a>! Thank you for quick response!<br />
Here you have sample ObjectData plugin based on <a href="https://github.com/PluginCafe/cinema4d_py_sdk_extended/blob/master/plugins/py-dynamic_parameters_object_r18/py-dynamic_parameters_object_r18.pyp#L289" target="_blank" rel="noopener noreferrer nofollow ugc">this SDK example</a>.</p>
<p dir="auto">Fieldlist ObjectData plugin is connected with VertexTag fieldlist by TranslateDescID. When adding Time field to Object plugin it freezes Cinema 4D. Tested on MB Air M1 MacOs 12.6.6</p>
<p dir="auto">Source<br />
<a href="https://developers.maxon.net/forum/assets/uploads/files/1686838483939-fieldlist_translateid_bug.zip" target="_blank" rel="noopener noreferrer nofollow ugc">fieldlist_translateid_bug.zip</a></p>
<p dir="auto">Demo<br />
<a href="https://developers.maxon.net/forum/assets/uploads/files/1686838964931-fieldlist_bug.mov.zip" target="_blank" rel="noopener noreferrer nofollow ugc">fieldlist_bug.mov.zip</a></p>
]]></description><link>http://developers.maxon.net/forum/post/71780</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71780</guid><dc:creator><![CDATA[mikeudin]]></dc:creator><pubDate>Thu, 15 Jun 2023 14:27:48 GMT</pubDate></item><item><title><![CDATA[Reply to TranslateDescID with FieldsList on Thu, 15 Jun 2023 11:46:06 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/mikeudin">@<bdi>mikeudin</bdi></a>,</p>
<p dir="auto">Thank you for reaching out to us and reporting the bug. Without a more precise bug description we unfortunately can only do little. We will need your plugin code here and an example scene. You can share them confidentially as lined out in our <a href="https://plugincafe.maxon.net/guidlines_cp" target="_blank" rel="noopener noreferrer nofollow ugc">forum guidleines</a> under <em>Confidential Data</em>.</p>
<p dir="auto">And I am a bit curious how you conclude that this is a memory leak? A memory leak means that code compiled by a language that does not offer a managed memory environment, e.g., C++, does not free its allocated memory correctly. The result is then that the application/the system is getting slower and slower, as the application keeps allocating memory without freeing it.</p>
<p dir="auto">Later on, you talk about a <em>crush happening</em>. I assume, you mean that Cinema 4D terminates irregularly, i.e., crashes. If that is the case, please send your crash report(s) or provide them manually. You can find them under <code>/{C4D_INSTALL_PREFS}/_bugreports</code>. When Cinema 4D does crash from Python, it usually means an access violation happend, i.e., the state of memory was not what our/your code assumed it to be.</p>
<p dir="auto">I cannot say much else, as your posting is otherwise unfortunately very vague. The only thing that stands out for me is that I do not really understand what you are trying to do with your field list, and that it sounds a bit dangerous due to the lack of ownership you have there. Things like Time and Delay field layers are <code>GeListNode</code> owned by a <code>FieldList</code> or <code>FieldLayer</code>; opposed to for example a <code>Ffield</code> layer (the field layer type that refrences an object in the OM) referencing an <code>Ofield</code> in the Object Manager. So, when you then pass out such FieldLayer plus some DescID in it, I am not too surprised that Cinema 4D does crash on you.</p>
Ferdinand</p>
]]></description><link>http://developers.maxon.net/forum/post/71778</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71778</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Thu, 15 Jun 2023 11:46:06 GMT</pubDate></item></channel></rss>
