<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[how to extract thumbnail image from .c4d file without Cinema 4D installed?]]></title><description><![CDATA[<p dir="auto">My goal is to create software that can display thumbnails of .c4d files, regardless of whether the user has Cinema 4D installed.</p>
<p dir="auto">Perhaps I can obtain the relevant functions from the Cinema 4D SDK to launch a .c4d scene in the background and capture a screenshot. However, I believe this approach might be too expansive for many files.</p>
<p dir="auto">Here are the steps I attempted: I copied a .c4d file to a brand new computer and used the win_thumbnail.dll from my original computer to update the registry on this new computer. After that, the .c4d file display the thumbnail correctly.</p>
<p dir="auto">Does the .c4d file already contain a pre-generated thumbnail, and how can I retrieve it?</p>
<p dir="auto">thanks for your help.</p>
]]></description><link>http://developers.maxon.net/forum/topic/14736/how-to-extract-thumbnail-image-from-c4d-file-without-cinema-4d-installed</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 09:01:22 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/14736.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Jun 2023 17:32:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to how to extract thumbnail image from .c4d file without Cinema 4D installed? on Thu, 10 Aug 2023 05:45:05 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/saotome_rui">@<bdi>saotome_rui</bdi></a> ,</p>
<p dir="auto">without further questions or postings, we will consider this topic as solved by Friday, the 11th of august 2023 and flag it accordingly.</p>
<p dir="auto">Thank you for your understanding,<br />
Maxon SDK Group</p>
]]></description><link>http://developers.maxon.net/forum/post/72213</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72213</guid><dc:creator><![CDATA[jana]]></dc:creator><pubDate>Thu, 10 Aug 2023 05:45:05 GMT</pubDate></item><item><title><![CDATA[Reply to how to extract thumbnail image from .c4d file without Cinema 4D installed? on Wed, 07 Jun 2023 18:20:27 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/saotome_rui">@<bdi>saotome_rui</bdi></a>,</p>
<p dir="auto">Welcome to the Plugin Café forum and the Cinema 4D development community, it is great to have you with us!</p>
<h4>Getting Started</h4>
<p dir="auto">Before creating your next postings, we would recommend making yourself accustomed with our <a href="https://plugincafe.maxon.net/guidlines_cp" target="_blank" rel="noopener noreferrer nofollow ugc">Forum and Support Guidelines</a>, as they line out details about the Maxon SDK Group support procedures. Of special importance are:</p>
<ul>
<li><a href="https://plugincafe.maxon.net/guidlines_cp#support-scope" target="_blank" rel="noopener noreferrer nofollow ugc">Support Procedures: Scope of Support</a>: Lines out the things we will do and what we will not do.</li>
<li><a href="https://plugincafe.maxon.net/guidlines_cp#support-data" target="_blank" rel="noopener noreferrer nofollow ugc">Support Procedures: Confidential Data</a>: Most questions should be accompanied by code but code cannot always be shared publicly. This section explains how to share code confidentially with Maxon.</li>
<li><a href="https://plugincafe.maxon.net/guidlines_cp#forum" target="_blank" rel="noopener noreferrer nofollow ugc">Forum Structure and Features</a>: Lines out how the forum works.</li>
<li><a href="https://plugincafe.maxon.net/guidlines_cp#question" target="_blank" rel="noopener noreferrer nofollow ugc">Structure of a Question</a>: Lines out how to ask a good technical question. It is not mandatory to follow this exactly, but you should follow the idea of keeping things short and mentioning your primary question in a clear manner.</li>
</ul>
<h4>About your First Question</h4>
<p dir="auto">I have moved your question to the Cineware forum, since you said</p>
<blockquote>
</blockquote>
<p dir="auto">Using the Cinema 4D API always requires a Cinema 4D installation, be it the C++ or Python API. The <code>C++ Cineware API</code>[URL-REMOVED] is the API to use when you want to read and write Cinema 4D documents without a Cinema 4D installation. With the Cineware API you can use <a href="https://developers.maxon.net/docs/cw/22_004/classcineware_1_1_base_document.html#a7df57389432a3ace9e65fad5eba0c3ea" target="_blank" rel="noopener noreferrer nofollow ugc">BaseDocument::GetDocPreviewBitmap</a> to get a thumbnail for a document. I would recommend that you try to get started and then come back in case you have a concrete project setup, design, or coding problem.</p>
<p dir="auto">If C++ is not an option for you, you can try your luck with one of the OS thumbnail handlers with Python/C# etc., but that would be out of scope of support, as we cannot disclose details about the binary format of Cinema 4D files.</p>
<p dir="auto">Cheers,<br />
Ferdinand</p>
<hr />
<p dir="auto">[URL-REMOVED] <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/maxon">@<bdi>maxon</bdi></a>: This section contained a non-resolving link which has been removed.</p>
]]></description><link>http://developers.maxon.net/forum/post/71690</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71690</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Wed, 07 Jun 2023 18:20:27 GMT</pubDate></item></channel></rss>
