<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Quicktab SDK Example]]></title><description><![CDATA[<p dir="auto">Dear Developpers,</p>
<p dir="auto">I am trying to implement a Quicktab Gui into my Plugin. While i get some User interface that is somehow usable, I see some content getting mixed up in the gui after multi selecting some tabs.</p>
<p dir="auto">It might be a simple thing as an ID not matching, but I am a little bit lost hence its basically just the <a href="https://github.com/PluginCafe/cinema4d_py_sdk_extended/blob/master/scripts/03_application_development/gui/dialog/customgui_quicktab_r19.py" target="_blank" rel="noopener noreferrer nofollow ugc">SDK example</a> i use.</p>
<p dir="auto"><img src="https://developers.maxon.net/forum/assets/uploads/files/1679423158471-quicktabgui.png" alt="quicktabgui.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">as you can see FFFF is deselected but shown<br />
DDDD and CCCC are switched up ....<br />
and no its not just a row shuffle .. deselecting DDD hides CCC<br />
deselecting more result in more gui disintegration ...</p>
<p dir="auto">Can you confirm that applying more content results in some weird stuff? Or what is your hunch .,... where to look ?</p>
<p dir="auto">Thank you for your time.<br />
cheers mogh</p>
<p dir="auto">only little was added .... rest is basically the SDK example ....</p>
<pre><code>class CustomGroup(c4d.gui.SubDialog):
    """A SubDialog to display the passed string, its used as example for the actual content of a Tab"""
    def __init__(self, material, parts):
        self._material = material
        self._parts = '\n'.join(parts)
    def CreateLayout(self):
        self.AddStaticText(CUSTOM_GROUP_ID_TEXT_BASE + 1 , flags=c4d.BFH_LEFT | c4d.BFV_TOP | c4d.BFH_FIT | c4d.BFV_FIT, name=self._material)
        self.AddStaticText(CUSTOM_GROUP_ID_TEXT_BASE + 2 , flags=c4d.BFH_LEFT | c4d.BFV_TOP | c4d.BFH_FIT | c4d.BFV_FIT, name=CUSTOM_GROUP_ID_TEXT_BASE)
        self.AddMultiLineEditText(CUSTOM_GROUP_ID_TEXT_BASE + 3, flags=c4d.BFH_LEFT | c4d.BFV_TOP | c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, initw=0, inith=0, style=c4d.DR_MULTILINE_WORDWRAP)
        self.SetString(CUSTOM_GROUP_ID_TEXT_BASE + 3, value=self._parts)
        #for i, parts in enumerate(self._parts):
        #    self.AddStaticText(CUSTOM_GROUP_ID_TEXT_BASE + i, c4d.BFH_SCALEFIT, name=parts)
    def Populate(self):
        directory, _ = os.path.split(__file__)
        poart_json_file = os.path.join(directory, "default_asignment.json")
        material_ids, materials_dict = read_parts_json(poart_json_file)
        self.FlushAllTabs() # clear the GUI
        print( str( material_ids))
        print("-"*80)
        for material_id in materials_dict:
            part_list = materials_dict[material_id]
            #print( str(material_id), str(part_list) )
            ### Tabs
            tab_Content = CustomGroup(str(material_id), part_list)
            self.AppendTab(str(material_id), tab_Content, False)</code></pre>
]]></description><link>http://developers.maxon.net/forum/topic/14465/quicktab-sdk-example</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 08:42:52 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/14465.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Mar 2023 18:21:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Quicktab SDK Example on Wed, 29 Mar 2023 09:06:28 GMT]]></title><description><![CDATA[<p dir="auto">While rethinking about it last night, it may not be that slow if on user interaction you just flush the main group and re-attach already existing dialog.</p>
<p dir="auto">So you need to modify your `def _DrawQuickTabGroup(self)`` method like so to only display visible dialog:</p>
<pre><code>    def _DrawQuickTabGroup(self, onlyVisible=True):
        """ Creates and draws all the SubDialog for each tab,
            take care it does not hide these according to a selection state.
        Returns:
            True if success otherwise False.
        # Checks if the quicktab is defined
        if self._quickTab is None:
            return False
        activeIds, activeNames = self.GetActiveTabs()
        # Flush the content of the group that holds all ours SubDialogs
        self.LayoutFlushGroup(ID_MAINGROUP)
        #self.GroupBorderSpace(left=5, top=5, right=5, bottom=5)
        # Iterates over the number of tab to create and attach the correct SubDialog
        for tabId, (tabName, tabGui) in enumerate(self._tabList.items()):
            toDisplay = tabId in activeIds
            if not toDisplay:
                continue
            self.AddSubDialog(ID_QUICKTAB_BASE_GROUP + tabId, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 0)
            self.AttachSubDialog(tabGui, ID_QUICKTAB_BASE_GROUP + tabId)
        self.LayoutChanged(ID_MAINGROUP)
</code></pre>
<p dir="auto">Then in the <code>Command</code> message instead of calling <code>DisplayCorrectGroup</code> you should call <code>_DrawQuickTabGroup</code> like so:</p>
<pre><code>    def Command(self, id, msg):
        if id == ID_QUICKTAB_BAR and self._quickTab:
            self._DrawQuickTabGroup()
</code></pre>
<p dir="auto">Regarding your question and classic Tab, find an example in <a href="https://developers.maxon.net/forum/topic/12922/remove-a-gedialog-tab-group/2" target="_blank" rel="noopener noreferrer nofollow ugc">Remove a GeDialog Tab Group</a> but as you can see this is also not possible to remove a tab without redrawing everything .</p>
<p dir="auto">Cheers,<br />
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/71119</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71119</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Wed, 29 Mar 2023 09:06:28 GMT</pubDate></item><item><title><![CDATA[Reply to Quicktab SDK Example on Wed, 29 Mar 2023 09:29:08 GMT]]></title><description><![CDATA[<p dir="auto">Ok Maxime, thanks for the heads up,</p>
<p dir="auto">I might just display all all the time ....<br />
<s>or build a Classic Tab version ... (is there an example ?)</s></p>
<p dir="auto">Barebone classic Tab:</p>
<pre><code>import c4d
DEBUG = True
DEFAULT_FLAGS = c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT
DEFAULT_SPACE = (5, 5, 5, 5)
DEFAULT_BORDER_STYLE = c4d.BORDER_NONE
DEFAULT_TEXT_FLAGS = c4d.BFV_CENTER | c4d.BFV_FIT | c4d.BFH_CENTER | c4d.BFH_FIT
class MyDialog(c4d.gui.GeDialog):
        if self.GroupBegin(id=950,  flags=c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT):
            self.GroupBorderNoTitle(borderstyle=DEFAULT_BORDER_STYLE)
            if self.TabGroupBegin(id=1000, flags=c4d.BFH_LEFT | c4d.BFH_SCALEFIT | c4d.BFV_CENTER | c4d.BFV_SCALEFIT, tabtype=c4d.TAB_TABS):
                if self.GroupBegin(id=1001, cols=1, rows=1, flags=c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, title="Tab 1"):
                    self.AddStaticText(id=2001, flags=DEFAULT_TEXT_FLAGS, name="some content 1")
                    self.GroupEnd()
                if self.GroupBegin(id=1002, cols=1, rows=1, flags=c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, title="Tab 2"):
                    self.AddStaticText(id=2002, flags=DEFAULT_TEXT_FLAGS, name="some content 2")
                    self.GroupEnd()
                if self.GroupBegin(id=1003, cols=1, rows=1, flags=c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, title="Tab 3 long name for test"):
                    self.AddStaticText(id=2003, flags=DEFAULT_TEXT_FLAGS, name="some content 3")
                    self.GroupEnd()
                self.GroupEnd()    # tab group
            self.GroupEnd() # main window
    if DEBUG:
        c4d.CallCommand(13957)  # clear console
    diag = MyDialog()
    diag.Open(dlgtype=c4d.DLG_TYPE_MODAL_RESIZEABLE, defaultw=960, defaulth=600)
</code></pre>
<p dir="auto">kind regards ...<br />
mogh</p>
]]></description><link>http://developers.maxon.net/forum/post/71118</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71118</guid><dc:creator><![CDATA[mogh]]></dc:creator><pubDate>Wed, 29 Mar 2023 09:29:08 GMT</pubDate></item><item><title><![CDATA[Reply to Quicktab SDK Example on Tue, 28 Mar 2023 14:06:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/mogh">@<bdi>mogh</bdi></a> sorry for the delay, I can indeed confirm the bug and reported it so far I don't have any other workaround than flushing the whole group and re-add everything, which can be very slow.</p>
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/71112</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71112</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Tue, 28 Mar 2023 14:06:42 GMT</pubDate></item><item><title><![CDATA[Reply to Quicktab SDK Example on Tue, 28 Mar 2023 07:55:20 GMT]]></title><description><![CDATA[<p dir="auto">Here is my latest Example Code, I will check for R2023.1 on Monday.<br />
selecting FFFF and DDDD results in GUI weirdness ... on R20</p>
<p dir="auto"><strong>Update</strong>: Also on 2023.1 I get this UI glitch ... selecting KKKKK / LLLLLL (last ones)</p>
<p dir="auto"><strong>Update 2</strong>: fiddled a little bit with the IDs (the class has an offset now so the ids are unique) and <code>Layoutchange()</code> no updated on the glitch when selecting the KKKK + X elements.</p>
<p dir="auto"><img src="https://developers.maxon.net/forum/assets/uploads/files/1679899946044-2023-03-27-window_000269.png" alt="2023-03-27-Window_000269.png" class=" img-fluid img-markdown" /></p>
<pre><code>import c4d # pyright: ignore[reportMissingImports]
import json
import os
from collections import OrderedDict
DEBUG = True
# Ids used in our Dialog
ID_MAINGROUP = 1000  # ID used for the Group that holds all the other group representing the tab content
ID_QUICKTAB_BAR = 1001  # ID for the quicktab customGui
ID_LOADDEFAULT_MAT_ASIGN = 1003
ID_CREATE_MATERIALS = 1004
BUTTON_PRINT_TEXT = 1005  # ID used for the Print text Button
BUTTON_PRINT_SELECTED = 1006  # ID used for the Print Selected Button
BUTTON_FLUSH_ALL = 1007  # ID used for the Flush All Button
BUTTON_ADD = 1008  # ID used for the Add Button
BUTTON_REMOVE = 1009  # ID used for the Remove Button
# Id used in our SubDialog
ID_QUICKTAB_BASE_GROUP = 5000
# Defines the ID for the string to be displayed
CUSTOM_GROUP_ID_TEXT_BASE = 4000
DEFAULT_BORDER_STYLE =c4d.BORDER_NONE
LAYOUT_DEBUG = True
if LAYOUT_DEBUG is True:
    DEFAULT_BORDER_STYLE = c4d.BORDER_BLACK
GENERATOR_START_ID = 2000
def plusone_id():
    n = GENERATOR_START_ID
    while n &lt; GENERATOR_START_ID+999:
        yield n
        n += 1
some_json = '{"AAAAAAA 85": ["a part_num_1","a part_num_2","a part_num_3"],"BBBBB 40": ["b part_num_4","b part_num_5"],"CCCCCCC": ["c part_num_6","c part_num_7","c part_num_8","c part_num_9"],"DDDDDD": ["d part_num_6","d part_num_7","d part_num_8","d part_num_9"],"FFFFF": ["f Plane"],"GGGGGGG": ["g part_num_6","g part_num_7","g part_num_8","g part_num_9"],"HHHHHHHH": ["h part_num_6","h part_num_7","h part_num_8","h part_num_9"],"IIIIII": ["i part_num_6","i part_num_7","i part_num_8","i part_num_9"],"JJJJJJJJJ": ["j part_num_6","j part_num_7","j part_num_8","j part_num_9"],"KKKKKKKK": ["k part_num_6","k part_num_7","k part_num_8","k part_num_9"],"LLLLLLLLL": ["l part_num_6","l part_num_7","l part_num_8","l part_num_9"],"MMMMMM": ["m part_num_6","m part_num_7","m part_num_8","m part_num_9"]}'
### Json
def read_parts_json(json_file_path):
    #with open(json_file_path) as f: data = json.load(f)
    data = json.loads(some_json)
    materials = {}
    for material_id, part_numbers in data.items():
        materials[material_id] = part_numbers
    material_ids = list(data.keys())
    return material_ids, materials
    def __init__(self, material, parts, offset):
        self.gui_id = CUSTOM_GROUP_ID_TEXT_BASE + offset
        self.GroupBegin(self.gui_id + 4, flags=c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, cols=1, rows=2, title=self.gui_id)
        self.GroupBorder(DEFAULT_BORDER_STYLE)
        self.AddStaticText(self.gui_id + 1 , flags=c4d.BFH_LEFT | c4d.BFV_TOP | c4d.BFH_FIT | c4d.BFV_FIT, name=self._material)
        #self.AddStaticText(self.gui_id + 2 , flags=c4d.BFH_LEFT | c4d.BFV_TOP | c4d.BFH_FIT | c4d.BFV_FIT, name=self.gui_id)
        self.AddMultiLineEditText(self.gui_id + 3, flags=c4d.BFH_LEFT | c4d.BFV_TOP | c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, initw=0, inith=0, style=0)
        self.SetString(self.gui_id + 3, value=self._parts)
        self.GroupEnd()
        #    self.AddStaticText(self.gui_id + i, c4d.BFH_SCALEFIT, name=parts)
    def __init__(self, items=[]):
        # this is from the linkbox example from ferdinand
        super(MyDialog, self).__init__()
        # will be link box
        self._items = []
        self._doc = None
        self._hasCreateLayout = False
        self.Items = items
        self._quickTab = None  # Stores the quicktab custom GUI
        self._tabList = OrderedDict()  # Stores the TabName and the SubDialog that represents each tab of the QuickTab
    def _DrawQuickTabGroup(self):
        Returns:
            return False
        # Notifies the content of the MainGroup has changed
    def GetActiveTabs(self):
        """Retrieves two list of currently selected tabs from the self._quickTab.
        Returns:
            list(int), list(name): The first list, contains tabs Id (from self._quickTab the dict) and the second list contains all names of the selected tabs.
            return False, False
        returnIds = []
        returnNames = []
            if self._quickTab.IsSelected(tabId):
                returnIds.append(tabId)
                returnNames.append(tabName)
        return returnIds, returnNames
    def DisplayCorrectGroup(self):
        """Hides all unused groups and display the correct one.
        Returns:
        # Retrieves the selected tab
        print("Display Correct Group")
        print(activeIds)
        # Iterates each CustomGui and defines if they are hidden or not
        for tabId in range(len(self._tabList)):
            #print("activeIds: ", activeIds, "current: ", ID_QUICKTAB_BASE_GROUP, tabId, " -&gt; toDisplay: ", toDisplay)
            self.HideElement(ID_QUICKTAB_BASE_GROUP + tabId, not toDisplay)
    def AppendTab(self, tabName, content, active=True):
        """Appends a tab to the current quicktab with the associated content to be displayed.
        Args:
            tabName (str): The name the tab should have.
            content (c4d.gui.SubDialog): The SubDialog to be drawn/linked when the tab is selected.
            active (bool, optional): If True, the inserted tab will be selected. Defaults to True.
        Returns:
            return False
        # Adds the tab entry n the quicktab
        self._quickTab.AppendString(len(self._tabList), tabName, active)
        # Updates our current tabList with tabName and the Subdialog to be linked
        self._tabList.update({tabName: content})
        """ I uncommented below because it resulted in a lot of gui calls
            It seems to work fine just calling self.DisplayCorrectGroup() at the right places
            not inside here hence this functionis called for each tab
        # Retrieves the current selected tab
        #previousActiveId, previousActiveName = self.GetActiveTabs()
        # Draws the quicktab SubDialog (in order to have the new one drawn)
        #self._DrawQuickTabGroup()
        # Defines the just added tab according state
        #self._quickTab.Select(len(self._tabList) - 1, active)
        # Defines previous active tab
        #for tabId in previousActiveId: self._quickTab.Select(tabId, True)
        # Display only the selected tab and hides all others
        #self.DisplayCorrectGroup()
    def FlushAllTabs(self):
        """Removes all tabs and their content from the GUI.
        Returns:
            return False
        # Removes all the tabs
        self._quickTab.ClearStrings()
        # Removes all the customGui
            self.RemoveElement(ID_QUICKTAB_BASE_GROUP + tabId)
        # Reinitializes the stored tablist to an empty dict
    def RemoveTab(self, tabNameToRemove):
        """Removes a tab by its name
        Args:
            tabNameToRemove (str): The tab to remove.
        Returns:
            return False
        # Copies the tabList
        newDict = OrderedDict(self._tabList)
        # Checks if the entry exist
        if tabNameToRemove not in newDict:
        # Removes the entry we want to delete
        del newDict[tabNameToRemove]
        # Removes all groups
        self.FlushAllTabs()
        # Re-adds all the one from our copy
        for tabName, tabGui in newDict.items():
            self.AppendTab(tabName, tabGui)
        """This Method is called automatically when Cinema 4D Create the Layout (display) of the Dialog."""
        # Creates a QuickTab Custom Gui
        bc = c4d.BaseContainer()
        bc.SetInt32(c4d.QUICKTAB_BAR, 0) # (0=off, 1=on, 2=non-bold, 3=special separator look)
        bc.SetString(c4d.QUICKTAB_BARTITLE, "Title")
        bc.SetBool(c4d.QUICKTAB_SPRINGINGFOLDERS, True) # if we can get link fields usefull
        bc.SetBool(c4d.QUICKTAB_SHOWSINGLE, False)
        bc.SetBool(c4d.QUICKTAB_NOMULTISELECT, False)
        bc.SetBool(c4d.QUICKTAB_SEPARATOR, True)
        self.GroupBegin(next(plusone_id()), c4d.BFH_SCALEFIT | c4d.BFV_TOP | c4d.BFV_FIT, 0, 0, 'ID_QUICKTAB_BAR', 0)
        #self.GroupBorderNoTitle(borderstyle=DEFAULT_BORDER_STYLE)
        self._quickTab = self.AddCustomGui(ID_QUICKTAB_BAR, c4d.CUSTOMGUI_QUICKTAB, 'the tabs', c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 0, bc)
        #self.AddStaticText(id=next(plusone_id()), flags=c4d.BFV_CENTER | c4d.BFV_SCALE | c4d.BFH_CENTER | c4d.BFH_SCALE, name="tabs")
        #print("layout cusrom gui: ", self._quickTab)
        self.GroupEnd()
        # Creates a group that will contain all the group representing each tab
        self.GroupBegin(ID_MAINGROUP, flags=c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, cols=10, rows=10, title='ID_MAINGROUP')
        self.AddStaticText(id=next(plusone_id()), flags=c4d.BFV_CENTER | c4d.BFV_SCALE | c4d.BFH_CENTER | c4d.BFH_SCALE, name="main")
        self.GroupEnd()
        # dummy group to spread vertically
        if self.GroupBegin(id=next(plusone_id()),  flags=c4d.BFH_FIT | c4d.BFV_FIT): #cols=1, rows=1,
            self.GroupBorderSpace(left=0, top=0, right=0, bottom=0)
            self.AddStaticText(id=next(plusone_id()), flags=c4d.BFV_CENTER | c4d.BFV_SCALE | c4d.BFH_CENTER | c4d.BFH_SCALE, name="")
            self.GroupEnd()
        # Creates a group with button in order to do some operation with the QuickTab CustomGUI
        if self.GroupBegin(next(plusone_id()), c4d.BFH_SCALEFIT | c4d.BFV_BOTTOM, 4, 1, '', 0):
            self.AddButton(ID_LOADDEFAULT_MAT_ASIGN, c4d.BFH_SCALEFIT, name="Populate")
            self.AddButton(BUTTON_PRINT_TEXT, c4d.BFH_SCALEFIT, name="Print text")
            self.AddButton(BUTTON_PRINT_SELECTED, c4d.BFH_SCALEFIT, name="Print Selected")
            self.AddButton(BUTTON_FLUSH_ALL, c4d.BFH_SCALEFIT, name="Flush All")
            #self.AddButton(BUTTON_ADD, c4d.BFH_SCALEFIT, name="Add")
            #self.AddButton(BUTTON_REMOVE, c4d.BFH_SCALEFIT, name="Remove")
            self.GroupEnd()
    def InitValues(self):
        """This Method is called automatically after the GUI is initialized."""
        # Creates the first Tab
        #cg1 = CustomGroup(["This is the first Tab", "Just dummy text here"])
        #self.AppendTab("First Tab", cg1, True)
        # Creates the second Tab
        #cg2 = CustomGroup(["This is the second Tab", "Just another dummy text here"])
        #self.AppendTab("Second Tab", cg2, False)
        #return True
        return super(MyDialog, self).InitValues()
        """This Method is called automatically when the user clicks on a gadget and/or changes its value this function will be called.
         It is also called when a string menu item is selected.
        Args:
            id: The ID of the gadget that triggered the event.
            msg: The original message container
        Returns:
            False if there was an error, otherwise True.
        # If the user interacts with the quicktab, we make sure to display the CustomGUI linked to the active one
            print("user interacted with tab")
        # Displays all the Tab name
        if id == BUTTON_PRINT_TEXT:
            print([key for key in self._tabList])
        # Displays the ID and name of the selected tab
        if id == BUTTON_PRINT_SELECTED:
            print(self.GetActiveTabs())
        # Removes all tabs
        if id == BUTTON_FLUSH_ALL:
            self.FlushAllTabs()
        # Adds a new Tab to the quicktab
        if id == BUTTON_ADD:
            cg3 = CustomGroup(["This is the third Tab"])
            self.AppendTab("Third Tab", cg3, True)
        # Removes the first tab of the quicktab
        if id == BUTTON_REMOVE:
            self.RemoveTab("First Tab")
        if id == ID_LOADDEFAULT_MAT_ASIGN:
            self.Populate()
    def Populate(self):
        print("-"*80)
        offset=0
            ### Tabs
            tab_Content = CustomGroup(str(material_id), part_list, offset)
            self.AppendTab(str(material_id), tab_Content, True)
            offset += 10
        print("-"*80)
# Main function
    if DEBUG:
    # Initializes a QuickTabDialogExample Dialog
    diag = MyDialog()
    # Opens the Dialog in modal mode
# Execute main()
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/71086</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71086</guid><dc:creator><![CDATA[mogh]]></dc:creator><pubDate>Tue, 28 Mar 2023 07:55:20 GMT</pubDate></item><item><title><![CDATA[Reply to Quicktab SDK Example on Sun, 26 Mar 2023 13:02:37 GMT]]></title><description><![CDATA[<p dir="auto">Hi Maxime,</p>
<p dir="auto">GUI disintegration mostly happening when selecting first and last Tab ...</p>
<p dir="auto"><img src="https://developers.maxon.net/forum/assets/uploads/files/1679829385917-tabs_gui_dissintegration_2.png" alt="tabs_gui_dissintegration_2.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://developers.maxon.net/forum/assets/uploads/files/1679829385898-tabs_gui_dissintegration.png" alt="tabs_gui_dissintegration.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I am troubleshooting this thing for 5 hours now and the outcome seems to stay the same, I slim-lined the code to draw less gui refreshs, printed the ids / tab names/ and content in several places, but the code and underlying list do not indicate  CCCC on ID 10 - So it seems only the TABs are wrong not the data structure ...</p>
<pre><code># json list
['KKKKKKKK', 'BBBBB 40', 'LLLLLLLLL', 'HHHHHHHH', 'GGGGGGG', 'IIIIII', 'JJJJJJJJJ', 'CCCCCCC', 'AAAAAAA 85', 'FFFFF', 'DDDDDD']
#AppendTab
_tabList:
{'KKKKKKKK': &lt;__main__.CustomGroup object at 0x000001FBD74848B8&gt;, 'BBBBB 40': &lt;__main__.CustomGroup object at 0x000001FBD7484948&gt;, 'LLLLLLLLL': &lt;__main__.CustomGroup object at 0x000001FBD7484A68&gt;, 'HHHHHHHH': &lt;__main__.CustomGroup object at 0x000001FBD74849D8&gt;, 'GGGGGGG': &lt;__main__.CustomGroup object at 0x000001FBD7484990&gt;, 'IIIIII': &lt;__main__.CustomGroup object at 0x000001FBD7484A20&gt;, 'JJJJJJJJJ': &lt;__main__.CustomGroup object at 0x000001FBD7C23C60&gt;, 'CCCCCCC': &lt;__main__.CustomGroup object at 0x000001FBDF91FCA8&gt;, 'AAAAAAA 85': &lt;__main__.CustomGroup object at 0x000001FBD7C23CF0&gt;, 'FFFFF': &lt;__main__.CustomGroup object at 0x000001FBDF91FC60&gt;, 'DDDDDD': &lt;__main__.CustomGroup object at 0x000001FBD7C23D80&gt;}
#_DrawQuickTabGroup
(0, 'KKKKKKKK', ' layout inserted subdialog id-&gt; ', 4000)
(1, 'BBBBB 40', ' layout inserted subdialog id-&gt; ', 4001)
(2, 'LLLLLLLLL', ' layout inserted subdialog id-&gt; ', 4002)
(3, 'HHHHHHHH', ' layout inserted subdialog id-&gt; ', 4003)
(4, 'GGGGGGG', ' layout inserted subdialog id-&gt; ', 4004)
(5, 'IIIIII', ' layout inserted subdialog id-&gt; ', 4005)
(6, 'JJJJJJJJJ', ' layout inserted subdialog id-&gt; ', 4006)
(7, 'CCCCCCC', ' layout inserted subdialog id-&gt; ', 4007)
(8, 'AAAAAAA 85', ' layout inserted subdialog id-&gt; ', 4008)
(9, 'FFFFF', ' layout inserted subdialog id-&gt; ', 4009)
(10, 'DDDDDD', ' layout inserted subdialog id-&gt; ', 4010)
# GetActiveTabs for loop
(0, 'KKKKKKKK')
(1, 'BBBBB 40')
(2, 'LLLLLLLLL')
(3, 'HHHHHHHH')
(4, 'GGGGGGG')
(5, 'IIIIII')
(6, 'JJJJJJJJJ')
(7, 'CCCCCCC')
(8, 'AAAAAAA 85')
(9, 'FFFFF')
(10, 'DDDDDD')
('GetActiveTabs id: ', [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10])
('GetActiveTabs names: ', ['KKKKKKKK', 'BBBBB 40', 'LLLLLLLLL', 'HHHHHHHH', 'GGGGGGG', 'IIIIII', 'JJJJJJJJJ', 'CCCCCCC', 'AAAAAAA 85', 'FFFFF', 'DDDDDD'])
</code></pre>
<p dir="auto"><s>a few moments ago I tested briefly <code>OrderedDict()</code> and tuple with no change in outcome ...</s></p>
<p dir="auto"><strong>EDIT:</strong>  ok so i missed the flushing, changing every {} to <code>self._tabList = OrderedDict()</code> seems top work - The GUI Problems  (screenshot) remain ...</p>
<p dir="auto"><s>I had the idea to link to # instead of names but that is not what the SDK example does it takes the names ?</s></p>
<p dir="auto">I am at 2023.1 at work and in my free time on R20.059<br />
I checked 2023.1 before I pester you here because I know you will limit support otherwise <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f937.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--shrug" style="height:23px;width:auto;vertical-align:middle" title=":shrug:" alt="🤷" /></p>
<p dir="auto">thank you for your time.<br />
mogh</p>
]]></description><link>http://developers.maxon.net/forum/post/71085</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71085</guid><dc:creator><![CDATA[mogh]]></dc:creator><pubDate>Sun, 26 Mar 2023 13:02:37 GMT</pubDate></item><item><title><![CDATA[Reply to Quicktab SDK Example on Thu, 23 Mar 2023 17:30:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi can you illustrate what "GUI disintegration" means with a picture. as with the latest 2023.1 I can't spot any issue.</p>
<p dir="auto">May I ask which version of Cinema 4D are you using and most important which Python version? You taged this topic as R20 and 2023 and R20 would mean Python 2.7, but you need to be careful since dictionary in python are guarantee to be ordered only since Python 3.6.</p>
<p dir="auto">Which I think is what cause your issue since with Cinema 4D 2023.1 I wasn't able to reproduce the "switch between CCCC and DDDD". So if you want to support version as old as R20 you will need a different data structure like tuple. For more information see <a href="https://stackoverflow.com/a/23418520" target="_blank" rel="noopener noreferrer nofollow ugc">Default ordered dictionaries in Python 2.7.x</a>.</p>
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/71067</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71067</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Thu, 23 Mar 2023 17:30:42 GMT</pubDate></item><item><title><![CDATA[Reply to Quicktab SDK Example on Wed, 22 Mar 2023 19:35:14 GMT]]></title><description><![CDATA[<p dir="auto">I am sorry, I do not want to come across as lacy but it is more or less the sdk example thats why I asked so sparse.</p>
<p dir="auto">I numerated the IDS from top to bottom that solved the FFFFF unchecking but there is still GUI disintegration and the switch between CCCC and DDDD</p>
<p dir="auto">The occasional supper and so is the prework for the link boxes I want to integrate (copied from ferdinands <a href="https://developers.maxon.net/forum/topic/14256/python-plugin-gui-tutorial?_=1679513480262" target="_blank" rel="noopener noreferrer nofollow ugc">recent GUI example</a> here in the forum)</p>
<p dir="auto">kind regards mogh</p>
<pre><code>"""
Copyright: MAXON Computer GmbH
Author: Maxime Adam
Description:
    - Creates a Modal Dialog displaying a different SubDialog according to the selected entry of the QuickTab.
    - Demonstrates how to add, flushes, remove tab interactively.
Class/method highlighted:
    - c4d.gui.QuickTabCustomGui
    - QuickTabCustomGui.ClearStrings()
    - QuickTabCustomGui.AppendString()
    - c4d.gui.GeDialog
    - GeDialog.CreateLayout()
    - GeDialog.InitValues()
    - GeDialog.Command()
    - GeDialog.HideElement()
    - GeDialog.RemoveElement()
    - c4d.gui.SubDialog
import json
import os
DEBUG = True
ID_QUICKTAB_BASE_GROUP = 1002  # Base ID for each SubDialog
CUSTOM_GROUP_ID_TEXT_BASE = 4000  # Defines the ID for the string to be displayed
LAYOUT_DEBUG = True
def plusone_id():
        yield n
        n += 1
somne_json = '{"AAAAAAA 85": ["a part_number_1","a part_number_2","a part_number_3"],"BBBBB 40": ["b part_number_4","b part_number_5"],"CCCCCCC": ["c part_number_6","c part_number_7","c part_number_8","c part_number_9"],"DDDDDD": ["d part_number_6","d part_number_7","d part_number_8","d part_number_9"],"FFFFF": ["f Plane"],"GGGGGGG": ["g part_number_6","g part_number_7","g part_number_8","g part_number_9"],"HHHHHHHH": ["h part_number_6","h part_number_7","h part_number_8","h part_number_9"],"IIIIII": ["i part_number_6","i part_number_7","i part_number_8","i part_number_9"],"JJJJJJJJJ": ["j part_number_6","j part_number_7","j part_number_8","j part_number_9"],"KKKKKKKK": ["k part_number_6","k part_number_7","k part_number_8","k part_number_9"],"LLLLLLLLL": ["l part_number_6","l part_number_7","l part_number_8","l part_number_9"]}'
### Json
    data = json.loads(somne_json)
    materials = {}
        self.AddMultiLineEditText(CUSTOM_GROUP_ID_TEXT_BASE + 3, flags=c4d.BFH_LEFT | c4d.BFV_TOP | c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, initw=0, inith=0, style=0)
        # will be link box
        self._items = []
        self._doc = None
        self.Items = items
        self._tabList = {}  # Stores the TabName and the SubDialog that represents each tab of the QuickTab
        """Creates and draws all the SubDialog for each tab, take care it does not hide these according to a selection state.
        Returns:
            return False
        Returns:
            return False, False
        returnIds = []
        returnNames = []
        Returns:
        Args:
        Returns:
            return False
        self._quickTab.AppendString(len(self._tabList), tabName, False)
        Returns:
            return False
        self._tabList = {}
        Args:
        Returns:
            return False
        newDict = dict(self._tabList)
        self.FlushAllTabs()
        #bc.SetInt32(c4d.QUICKTAB_BAR, 0) # (0=off, 1=on, 2=non-bold, 3=special separator look)
        bc.SetBool(c4d.QUICKTAB_BAR, False)
        #bc.SetBool(c4d.QUICKTAB_SPRINGINGFOLDERS, True) # if we can get link fields usefull
        bc.SetBool(c4d.QUICKTAB_SHOWSINGLE, True)
        self.GroupBegin(next(plusone_id()), c4d.BFH_SCALEFIT | c4d.BFV_TOP | c4d.BFV_FIT, 0, 0, '', 0)
        self._quickTab = self.AddCustomGui(ID_QUICKTAB_BAR, c4d.CUSTOMGUI_QUICKTAB, '', c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 0, bc)
        self.GroupEnd()
        self.GroupBegin(ID_MAINGROUP, flags=c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, cols=10, rows=10, title='')
        self.GroupEnd()
            self.GroupEnd()
        if self.GroupBegin(next(plusone_id()), c4d.BFH_SCALEFIT | c4d.BFV_BOTTOM, 6, 1, '', 0):
            self.GroupEnd()
        #return True
        Args:
        Returns:
        # Removes all tabs
            self.FlushAllTabs()
            self.Populate()
    def Populate(self):
        print("-"*80)
            ### Tabs
        print("-"*80)
# Main function
    if DEBUG:
    diag = MyDialog()
    diag.Open(dlgtype=c4d.DLG_TYPE_MODAL_RESIZEABLE, defaultw=400, defaulth=400)
# Execute main()
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/71050</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71050</guid><dc:creator><![CDATA[mogh]]></dc:creator><pubDate>Wed, 22 Mar 2023 19:35:14 GMT</pubDate></item><item><title><![CDATA[Reply to Quicktab SDK Example on Wed, 22 Mar 2023 15:11:49 GMT]]></title><description><![CDATA[<p dir="auto">Hi there is nothing preventing for more "tabs", since your code is far from being complete it will be very hard for us to help you, so please share your code.</p>
<p dir="auto">As a hint I would check for Ids, as it is most likely the cause.<br />
Cheers,<br />
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/71043</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71043</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Wed, 22 Mar 2023 15:11:49 GMT</pubDate></item></channel></rss>
