<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Changing the Color field&#x27;s color mode]]></title><description><![CDATA[<p dir="auto">Hi! Is it possible to change with a Python script the color field's color mode option (sRGB, Render, Display, Raw), when the project is set to use OpenColorIO color management?</p>
<p dir="auto"><img src="https://developers.maxon.net/forum/assets/uploads/files/1668600223900-c4d_color_preview.jpg" alt="c4d_color_preview.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">This would be a very beneficial feature. For example I have a Python plug-in that works like a color palette and it has 16 indiviual color field's. Cinema 4D sets color field to sRGB color mode by default and it is very cumbersome to change the color mode in every color field individually (from sRGB to Raw).</p>
<p dir="auto">Cheers,<br />
Arttu</p>
]]></description><link>http://developers.maxon.net/forum/topic/14269/changing-the-color-field-s-color-mode</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 01:04:20 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/14269.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Nov 2022 15:28:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Changing the Color field&#x27;s color mode on Thu, 17 Nov 2022 17:14:24 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a>,</p>
<p dir="auto">Thanks for the reply and the information. Ok, it is an UX/UI thing.</p>
<p dir="auto">I know that the color value is just a <code>Vector</code> and the original value doesn't change when toggling between modes (sRGB, Render, Display and Raw). It's just confusing for the end user that by default C4D is displaying colors in sRGB mode (when using OCIO), especially when the given vector for the color is anyways in raw format.</p>
<p dir="auto">But as you said, it's UX/UI thing and I should do a feature request in Maxon's Support Center that it would be nice to be able to change the default mode for the color field.</p>
<p dir="auto">Thanks for the link to the OCIO article, really useful information!</p>
Arttu</p>
]]></description><link>http://developers.maxon.net/forum/post/70205</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/70205</guid><dc:creator><![CDATA[aturtur]]></dc:creator><pubDate>Thu, 17 Nov 2022 17:14:24 GMT</pubDate></item><item><title><![CDATA[Reply to Changing the Color field&#x27;s color mode on Mon, 21 Nov 2022 09:41:10 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/aturtur">@<bdi>aturtur</bdi></a>,</p>
<p dir="auto">Thank you for reaching out to us. What you want to do ist not possible, even in C++.</p>
<p dir="auto">We (Maxon) never expose GUIs but the data structures behind them. E.g., we do not expose the Object Manager but the things (<code>BaseObject</code>, <code>BaseTag</code>, etc.) the Object Manager is displaying. The same applies here, for the public API this is just a <code>Vector</code>, it has no access to the custom GUI that is used here to display this (color) vector. You cannot change the OCIO input mode or things like the color space (RGB, HSL, etc.).</p>
<p dir="auto">FYI: Even if you could change the mode, it would have zero effect on how you must get/set color parameters when a document is in OCIO mode. All operations are always in OCIO <em>Render Space</em>. I have shown in the <a href="https://developers.maxon.net/docs/cpp/2023_2/article_ocio.html#article_ocio_getset_colors" target="_blank" rel="noopener noreferrer nofollow ugc">C++ OCIO Manual how to emulate what the color chooser GUI does</a>, but you cannot do this in Python at the moment, as <code>OcioConverter</code> has not been wrapped for Python.</p>
Ferdinand</p>
]]></description><link>http://developers.maxon.net/forum/post/70199</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/70199</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Mon, 21 Nov 2022 09:41:10 GMT</pubDate></item></channel></rss>
