<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to Center the Axis of Objects]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a> , thank you a lot!<br />
When i tried to fix my code i used Mike Udin's example, but i couldn't understand why this code didn't work with multiple objects. I've got next message: "AttributeError: 'NoneType' object has no attribute 'GetAllPoints'".</p>
<p dir="auto">I supposed my script to set selected objects' axis points in the center for each other. After that the script should create a null between all axis points.</p>
<pre><code>import c4d
    ps = op.GetAllPoints() #Points in Local coordinates List
    m = op.GetMg() #Object Global Matrix
    center = op.GetMp() #Local coordinates center: https://tinyurl.com/wed88cn
    rad = op.GetRad() # Geometry radius: https://tinyurl.com/tb6vn64
    center -= c4d.Vector(0,rad.y,0) #Move down axis to lowest point. Comment this line to keep axis in a center
    center *= m #Convert to Global coordinates center
    new_m = c4d.Matrix(m) #Copy matrix
    new_m.off = center #Change its center
    loc_m = ~new_m * m #Get local matrix
    op.SetAllPoints([loc_m.Mul(p) for p in ps])
    op.SetMg(new_m)
    op.Message(c4d.MSG_UPDATE)
if name == 'main':
</code></pre>
<p dir="auto">edit: This topic has been forked from <a href="https://developers.maxon.net/forum/topic/13742" target="_blank" rel="noopener noreferrer nofollow ugc">How to fix the bug of objects position in script</a> by <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a></p>
]]></description><link>http://developers.maxon.net/forum/topic/13745/how-to-center-the-axis-of-objects</link><generator>RSS for Node</generator><lastBuildDate>Thu, 19 Nov 2026 06:28:52 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/13745.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Dec 2021 16:09:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to Center the Axis of Objects on Fri, 31 Dec 2021 11:15:06 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/roman">@<bdi>roman</bdi></a>,</p>
<p dir="auto">I have forked this topic since this a new question. Please refer to the <a href="https://plugincafe.maxon.net/guidlines_cp" target="_blank" rel="noopener noreferrer nofollow ugc">Forum Guidelines</a> for details on forum procedures.</p>
<p dir="auto">The error message <code>AttributeError: 'NoneType' object has no attribute 'GetAllPoints'.</code> likely stems from you having no object selected when trying to run the script you posted. This is because the script simply assumes that <code>op</code> is populated, i.e., some kind of <code>BaseObject</code>, and even further it assumes that it is not only a <code>BaseObject</code> but also a <code>PointObject</code>. Both assumptions can prove false, as the user can have no selection, then <code>op</code> is <code>None</code>, or a selection which is not a <code>PointObject</code>, e.g., some parametric object.</p>
<p dir="auto">Your code will also not work for what you wanted to do regarding the last thread, as this new code only applies to a singular object. Your code is also a bit complicated for my taste, it could be done more cleanly like this:</p>
<pre><code># Get the origin of the bounding box of the object, i.e., where
# the axis should be.
origin = node.GetMp()
# The global matrix of the object.
mg = node.GetMg()
# The delta between where the axis is and where it should be
delta = c4d.Matrix(off=origin)
# Move all points by the inverse of that delta.
node.SetAllPoints([(p * ~delta) for p in node.GetAllPoints()])
# Set the new node position
node.SetMg(mg * delta)
</code></pre>
<p dir="auto">I have provided an example solution in the context of your last topic. The major insight here is that you have to do things then in two steps. First you go over all selcted objects to set their layers and try to move their axis. And after that you can calaculate the position of the null. Please also note that:</p>
<ol>
<li>Moving the axis of an object can be quite the can of worms when you start touching orientation or scale, as you then also have to update tangent tags, normal tags and other data.</li>
<li>The provided code is an example and might still contain bugs you must fix yourself. We cannot provide full solutions.</li>
</ol>
<p dir="auto">Cheers,<br />
Ferdinand</p>
<p dir="auto">The result:<br />
<img src="https://developers.maxon.net/forum/assets/uploads/files/1640948064379-origin.gif" alt="origin.gif" class=" img-fluid img-markdown" /></p>
<p dir="auto">The test scene:<br />
<a href="https://developers.maxon.net/forum/assets/uploads/files/1640948081221-test_scene.c4d" target="_blank" rel="noopener noreferrer nofollow ugc">test_scene.c4d</a></p>
<p dir="auto">The code:</p>
    # Start an undo stack item.
    doc.StartUndo()
    # Add a new top-level layer
    newLayer = c4d.documents.LayerObject()
    layerRoot = doc.GetLayerObjectRoot()
    newLayer.InsertUnder(layerRoot)
    doc.AddUndo(c4d.UNDOTYPE_NEWOBJ, newLayer)
    # Let the user name the new layer
    newName = c4d.gui.RenameDialog(newLayer.GetName())
    newLayer[c4d.ID_BASELIST_NAME] = newName
    # Get the selected objects.
    selectedObjects = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_NONE)
    # Iterate over the selected objects to change their layer and the layer
    # of the attached materials and optionally center their axis.
    for node in selectedObjects:
        # Attempt to center the axis for editable objects.
        if isinstance(node, c4d.PointObject):
            mg = node.GetMg()
            # Move all points by the inverse that delta.
            doc.AddUndo(c4d.UNDOTYPE_CHANGE, node)
            # Move the object by that delta.
        # Set the layer of the current node.
        node[c4d.ID_LAYER_LINK] = newLayer
        # Get all materials attached with material tags to the node.
        isTex = lambda node: node.IsInstanceOf(c4d.Ttexture)
        for material in [t.GetMaterial() for t in node.GetTags() if isTex(t)]:
            doc.AddUndo(c4d.UNDOTYPE_CHANGE, material)
            material[c4d.ID_LAYER_LINK] = newLayer
    # Compute the mean global offset for all objects in the selection.
    meanOffset = (sum((n.GetMg().off for n in selectedObjects)) *
                  (1. / len(selectedObjects)))
    # Create a null object at that offset to parent the selected objects to.
    newLayerNull = c4d.BaseObject(c4d.Onull)
    newLayerNull[c4d.ID_LAYER_LINK] = newLayer
    newLayerNull[c4d.ID_BASELIST_NAME] = newName
    newLayerNull.SetMg(c4d.Matrix(off=meanOffset))
    doc.InsertObject(newLayerNull)
    doc.AddUndo(c4d.UNDOTYPE_NEWOBJ, newLayerNull)
    # Loop again over all selected objects to parent them to the new null
    # object.
        # Get the global matrix of the node and then remove it from the scene.
        mg = node.GetMg()
        node.Remove()
        # Attach the node to its new parent and set its global matrix to the
        # stored value.
        node.InsertUnder(newLayerNull)
        node.SetMg(mg)
    # Close the undo item and push an update event to Cinema 4D.
    doc.EndUndo()
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/68252</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/68252</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Fri, 31 Dec 2021 11:15:06 GMT</pubDate></item><item><title><![CDATA[Reply to How to Center the Axis of Objects on Wed, 29 Dec 2021 14:36:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a></p>
<p dir="auto">Script add a null in center of world coordinates. I want to change it, i described what i want to do in pictures.</p>
<p dir="auto"><img src="https://developers.maxon.net/forum/assets/uploads/files/1640787678173-1-resized.jpg" alt="1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">I added Mike's code, because i wanted to make 2 options for <strong>Step 2</strong>:</p>
<ul>
<li>First option  — script add axis poins of selected objects in center.</li>
<li>Second option  — script add axis poins of selected objects in center but in the lowest position in Y coordinate. Mike's script could do this but just for one object. If i select objects more than one i get a message: "AttributeError: 'NoneType' object has no attribute 'GetAllPoints'".</li>
</ul>
<p dir="auto">I'm sorry for my English...</p>
]]></description><link>http://developers.maxon.net/forum/post/68245</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/68245</guid><dc:creator><![CDATA[ROMAN]]></dc:creator><pubDate>Wed, 29 Dec 2021 14:36:53 GMT</pubDate></item><item><title><![CDATA[Reply to How to Center the Axis of Objects on Wed, 29 Dec 2021 11:38:34 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/roman">@<bdi>roman</bdi></a>,</p>
<p dir="auto">I struggle a bit with understanding how your answer and the posted code is relevant for the rest of the posting. It is not that I would not understand what the code is supposed to do, I just do not understand how transforming the vertices of a point object is relevant for the rest of the posting.</p>
<p dir="auto">If the problem of this topic is not solved for you, I must ask you to explain the remaining problems again.</p>
Ferdinand</p>
]]></description><link>http://developers.maxon.net/forum/post/68243</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/68243</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Wed, 29 Dec 2021 11:38:34 GMT</pubDate></item></channel></rss>
