<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Dynamic elements in a CYCLE, CYCLE empty after loading document?]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">In a <code>ShaderData</code>, I am using <code>GetDDescription()</code> to add elements to a <code>LONG CYCLE</code> description using this code:</p>
<pre><code class="language-cpp">struct CycleElementData
	Int32 elementId; ///&lt; Element id
	maxon::String name; ///&lt; Element name
	/// \brief Construct from element ID and name
	CycleElementData(Int32 t_elementId, const maxon::String&amp; t_name) : elementId(t_elementId), name(t_name)
	/// \brief Copy constuctor
	CycleElementData(const CycleElementData&amp; src) : elementId(src.elementId), name(src.name)
Bool AddCycleElements(GeListNode* node, Description* descr, Int32 myDescId, maxon::BaseArray&lt;CycleElementData&gt;&amp; elements, Bool addSeparator)
    const DescID* const singleId = descr-&gt;GetSingleDescID();
    if (IsSingleID(myDescId, singleId))
        BaseContainer* descSettings = descr-&gt;GetParameterI(myDescId, nullptr);
        if (!descSettings)
            return false;
        // Build BaseContainer with cycle elements
        BaseContainer cycleElements = descSettings-&gt;GetContainer(DESC_CYCLE);
        if (addSeparator)
            cycleElements.SetString(-1, ""_s);
        for (maxon::BaseArray&lt;CycleElementData&gt;::ConstIterator it = elements.Begin(); it != elements.End(); ++it)
            const CycleElementData&amp; currentElement = *it;
            cycleElements.SetString(currentElement.elementId, currentElement.name);
        descSettings-&gt;SetContainer(DESC_CYCLE, cycleElements);
        return true;
    return true;
// Later...
maxon::BaseArray&lt;CycleElementData&gt; shaderModes;
shaderModes.Append(CycleElementData(123456, "Some mode"_s)) iferr_ignore();
shaderModes.Append(CycleElementData(654321, "Some other mode"_s)) iferr_ignore();
AddCycleElements(node, description, MYSHADER_MODES, shaderModes, true);
</code></pre>
<p dir="auto">So far, it seems to work fine. The additional entries appear in the <code>LONG CYCLE</code> in the shader's UI. I can also select them, and it works.</p>
<p dir="auto">However, when I save the scene, and then load it again, nothing is selected in the <code>LONG CYCLE</code>. I have to re-select the desired entry again. I guess, this is because the additional entries don't exist yet, when the scene is loaded, and are added later when the shader's <code>GetDDescription()</code> is called. So what might be the solution?</p>
<p dir="auto">Greetings &amp; thanks in advance for help,<br />
Frank</p>
]]></description><link>http://developers.maxon.net/forum/topic/13139/dynamic-elements-in-a-cycle-cycle-empty-after-loading-document</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 04:08:28 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/13139.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 Jan 2021 15:14:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Dynamic elements in a CYCLE, CYCLE empty after loading document? on Wed, 31 Mar 2021 14:37:39 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, Maxime! Looks like I have it running flawlessly now.</p>
<blockquote>
<p dir="auto">good work on Terraform looks solid!<br />
Thank you! It is pretty solid, yes <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
</blockquote>
<p dir="auto">Cheers &amp; happy Easter,<br />
Frank</p>
]]></description><link>http://developers.maxon.net/forum/post/66230</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/66230</guid><dc:creator><![CDATA[fwilleke80]]></dc:creator><pubDate>Wed, 31 Mar 2021 14:37:39 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic elements in a CYCLE, CYCLE empty after loading document? on Tue, 30 Mar 2021 10:33:49 GMT]]></title><description><![CDATA[<p dir="auto">Hi sorry for the long waiting.</p>
<p dir="auto">As demonstrated in the code snippet from <a href="https://developers.maxon.net/docs/cpp/2023_2/page_manual_description.html#page_manual_description_content_iterate" target="_blank" rel="noopener noreferrer nofollow ugc">Description - Iterate</a>. I think in your GetDDescription, once the description is saved you should call SetParameter with the correct value.<br />
This value can only be known by yourself. So you have to store the cycle value within the Hyperfile by overriding Write. Then when Cinema 4D loads the object the Read is called, here you can save in the previous value saved for the cycle. And finally in the GetDDescription, since Read would have been already called, you can call SetParameter with the correct value.</p>
<p dir="auto">Hope this clarifies a bit, and good work on Terraform looks solid! <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /><br />
Cheers,<br />
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/66214</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/66214</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Tue, 30 Mar 2021 10:33:49 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic elements in a CYCLE, CYCLE empty after loading document? on Wed, 27 Jan 2021 08:38:10 GMT]]></title><description><![CDATA[<p dir="auto">Ah, ok, yes that sounds reasonable. When would I do that? In Read(), Write(), and CopyTo()? And what exactly would I do? Simple getting the value and immediately setting it again probably wouldn’t change anything.</p>
]]></description><link>http://developers.maxon.net/forum/post/65666</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/65666</guid><dc:creator><![CDATA[fwilleke80]]></dc:creator><pubDate>Wed, 27 Jan 2021 08:38:10 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic elements in a CYCLE, CYCLE empty after loading document? on Wed, 27 Jan 2021 08:29:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/fwilleke80">@<bdi>fwilleke80</bdi></a> said in <a href="https://developers.maxon.net/forum/post/65646" target="_blank" rel="noopener noreferrer nofollow ugc">Dynamic elements in a CYCLE, CYCLE empty after loading document?</a>:</p>
<blockquote>
<p dir="auto">However, when I save the scene, and then load it again, nothing is selected in the LONG CYCLE.</p>
</blockquote>
<p dir="auto">What might happens is that the value is correctly set, but since the Cycle is not yet populated, the value is then reset.<br />
So that's why a SetParameter, may be required once cycle data are loaded.</p>
<p dir="auto">Cheers,<br />
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/65665</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/65665</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Wed, 27 Jan 2021 08:29:19 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic elements in a CYCLE, CYCLE empty after loading document? on Tue, 26 Jan 2021 15:22:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/m_adam">@<bdi>m_adam</bdi></a> said in <a href="https://developers.maxon.net/forum/post/65652" target="_blank" rel="noopener noreferrer nofollow ugc">Dynamic elements in a CYCLE, CYCLE empty after loading document?</a>:</p>
<blockquote>
<p dir="auto">Within the GetDDescription, once you populated the cycle, be sure also to call SetParameter to actually set the value (be sure to store the currently active value by overriding NodeData::Write/NodeDataRead)</p>
</blockquote>
<p dir="auto">What exactly do you mean? Why should I do that?</p>
<p dir="auto">Do be clear: Just because the user links an object that adds extra items to the <code>CYCLE</code> doesn't mean any of those extra items should be automatically selected. They should just be available in the <code>CYCLE</code>.</p>
]]></description><link>http://developers.maxon.net/forum/post/65655</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/65655</guid><dc:creator><![CDATA[fwilleke80]]></dc:creator><pubDate>Tue, 26 Jan 2021 15:22:35 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic elements in a CYCLE, CYCLE empty after loading document? on Tue, 26 Jan 2021 11:26:32 GMT]]></title><description><![CDATA[<p dir="auto">Hi Adam, happy new year to you, too!</p>
<p dir="auto">Since it works now, for some reason, I am pretty happy with what I have. However, since it might interest other plugin developers, I'll share more code. Maybe you have some tipps about improvements or potentially dangerous stuff, too.</p>
<p dir="auto">The idea is that the shader has a <code>LINK</code> field where the user can link an object (which is also part of my plugin). The object can (but doesn't have to) provide a list of "custom outputs" that will be added to the shader's <code>CYCLE</code>. In the screenshot below it's the "Difference Map".</p>
<p dir="auto">When a rendering is started, the shader will request the according data from the linked object during <code>InitRender()</code>. But that's not part of this thread <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";-)" alt="😉" /></p>
<p dir="auto"><img src="https://developers.maxon.net/forum/assets/uploads/files/1611657778308-screenshot-2021-01-26-at-11.42.45.png" alt="Screenshot 2021-01-26 at 11.42.45.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The shader's <code>GetDDescription()</code>:</p>
<pre><code class="language-cpp">Bool TerrainOperatorShader::GetDDescription(GeListNode *node, Description *description, DESCFLAGS_DESC &amp;flags)
	iferr_scope_handler
		GePrint(err.GetMessage());
		return false;
	if (!description-&gt;LoadDescription(node-&gt;GetType()))
		return false;
	flags |= DESCFLAGS_DESC::LOADED;
	BaseDocument* doc = node-&gt;GetDocument();
	const BaseContainer&amp; dataRef = static_cast&lt;BaseShader*&gt;(node)-&gt;GetDataInstanceRef();
	// Hide or show attributes, depending on shader mode
	const Bool slopeMode = dataRef.GetInt32(XTERRAINOPERATORSHADER_DATA) == XTERRAINOPERATORSHADER_DATA_SLOPE;
	TF4D::GUI::ShowDescription(node, description, XTERRAINOPERATORSHADER_SLOPE_DIRECTION_ENABLE, slopeMode);
	TF4D::GUI::ShowDescription(node, description, XTERRAINOPERATORSHADER_SLOPE_DIRECTION, slopeMode);
	// Get linked object
	BaseObject *linkedObject = dataRef.GetObjectLink(XTERRAINOPERATORSHADER_OPERATORLINK, doc);
	if (linkedObject)
		// Get linked object's NodeData
		TF4D::BaseTerrainOperatorData* linkedOperator = linkedObject-&gt;GetNodeData&lt;TF4D::BaseTerrainOperatorData&gt;();
		// Get list of custom outputs (these are the elements to add to the CYCLE)
		maxon::BaseArray&lt;TF4D::GUI::CycleElementData&gt; customOutputs;
		if (linkedOperator-&gt;GetCustomOperatorOutputs(customOutputs))
			if (!TF4D::GUI::AddCycleElements(node, description, XTERRAINOPERATORSHADER_DATA, customOutputs, true))
				iferr_throw(maxon::UnexpectedError(MAXON_SOURCE_LOCATION, "Could not add LONG CYCLE elements!"_s));
	return SUPER::GetDDescription(node, description, flags);
</code></pre>
<p dir="auto">The linked object's <code>NodeData</code>'s <code>GetCustomOperatorOutputs()</code>:</p>
<pre><code class="language-cpp">Bool ErosionOperator::GetCustomOperatorOutputs(maxon::BaseArray&lt;TF4D::GUI::CycleElementData&gt;&amp; customOperatorOutputs) const
	iferr_scope_handler
		return false;
	customOperatorOutputs.Reset();
	// GetCustomOutputName() simply returns a maxon::String
	customOperatorOutputs.Append(TF4D::GUI::CycleElementData(TF4D_CUSTOMOUTPUT_EROSION_DIFFERENCE, GetCustomOutputName(TF4D_CUSTOMOUTPUT_EROSION_DIFFERENCE))) iferr_return;
	return true;
</code></pre>
Frank</p>
<p dir="auto">Ah, damn. Now I've spoiled that I'm working on erosion for Terraform4D <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
]]></description><link>http://developers.maxon.net/forum/post/65653</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/65653</guid><dc:creator><![CDATA[fwilleke80]]></dc:creator><pubDate>Tue, 26 Jan 2021 11:26:32 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic elements in a CYCLE, CYCLE empty after loading document? on Tue, 26 Jan 2021 10:21:33 GMT]]></title><description><![CDATA[<p dir="auto">Hi Franck, first of all, Happy new year!<br />
Glad that it somehow works.</p>
<p dir="auto">The biggest issue is we don't have all your code, so we need to do some guesswork.</p>
<p dir="auto">We don't know when ad how you are populating your BaseArray. Since it may be based on some other stuff from the scene, these other things may not be loaded yet.</p>
<p dir="auto">We don't have your GetDDescription code, but be sure that <a href="https://developers.maxon.net/docs/cpp/2023_2/class_description.html#aaee7b9f84dd3ea6f9af9f8db4b207914" target="_blank" rel="noopener noreferrer nofollow ugc">LoadDescription</a> is called and you return <code>DESCFLAGS_DESC::LOADED</code> Overwise your change may simply be overwritten. For more information see <a href="https://developers.maxon.net/docs/cpp/2023_2/page_manual_description.html#page_manual_description_access" target="_blank" rel="noopener noreferrer nofollow ugc">Description Manual - Access</a>.</p>
<p dir="auto">Hope this help,<br />
Cheers,<br />
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/65652</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/65652</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Tue, 26 Jan 2021 10:21:33 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic elements in a CYCLE, CYCLE empty after loading document? on Mon, 25 Jan 2021 16:25:54 GMT]]></title><description><![CDATA[<p dir="auto">OK, after taking a little break and then getting back to the code, it magically works. I didn't change anything. So, I change my question to: Are there any pitfalls with dynamic CYCLE elements, or dynamic description elements in general, when loading a scene?</p>
]]></description><link>http://developers.maxon.net/forum/post/65647</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/65647</guid><dc:creator><![CDATA[fwilleke80]]></dc:creator><pubDate>Mon, 25 Jan 2021 16:25:54 GMT</pubDate></item></channel></rss>
