<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[External Compositing Tag not working with generated objects by ObjectData Plugin]]></title><description><![CDATA[<p dir="auto">Hi All,<br />
I'm on my first plugin, and by no means a true Python developer.<br />
my plugin is relatively simple :  it gets a cloner from a LINK box in the GUI, and creates a null for each clone, with a compositing tag attached, and gets the matrix of each clone from the GetCache() and applies it to each null, making them follow the clones.</p>
<p dir="auto">It all works fine on the viewport, but if i export an AEC file, the nulls are all static, and not following changes caused by effectors, like position or rotation etc. it DOES work on the viewport as you scrub the timeline in C4D though.</p>
<p dir="auto">i'm creating the Nulls during the GetVirtualObjects() function, and changing their Matrix on the Execute() function.</p>
<p dir="auto">Any ideas?</p>
<p dir="auto">Cheers,<br />
Eddie</p>
]]></description><link>http://developers.maxon.net/forum/topic/12764/external-compositing-tag-not-working-with-generated-objects-by-objectdata-plugin</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 09:31:37 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/12764.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Jul 2020 16:52:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to External Compositing Tag not working with generated objects by ObjectData Plugin on Tue, 06 Jul 2021 18:56:19 GMT]]></title><description><![CDATA[<p dir="auto">ok, my apologies.  i guess my question is at what point to i check for dirty, and at what point do i insert the nulls?</p>
]]></description><link>http://developers.maxon.net/forum/post/67072</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/67072</guid><dc:creator><![CDATA[Eduardo Oliveira]]></dc:creator><pubDate>Tue, 06 Jul 2021 18:56:19 GMT</pubDate></item><item><title><![CDATA[Reply to External Compositing Tag not working with generated objects by ObjectData Plugin on Tue, 06 Jul 2021 11:49:21 GMT]]></title><description><![CDATA[<p dir="auto">Hi Eddie, thanks for getting back but I ask you to specify what is not working or is not clear in the answer marked as Solution.</p>
<p dir="auto">When posting code, I also recommend being sure that it's reduced to the bare minimum to reproduce the issue, that's properly documented and that a scene using it is attached to help us reproducing the issue rather than guessing what to do.</p>
<p dir="auto">Riccardo</p>
]]></description><link>http://developers.maxon.net/forum/post/67068</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/67068</guid><dc:creator><![CDATA[r_gigante]]></dc:creator><pubDate>Tue, 06 Jul 2021 11:49:21 GMT</pubDate></item><item><title><![CDATA[Reply to External Compositing Tag not working with generated objects by ObjectData Plugin on Mon, 05 Jul 2021 19:56:13 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the reply -  sorry to resurrect this post, but I am still struggling to put your advice to use. since I am mostly writing this plugin to learn, I'll go ahead and just paste the code in here ( please be gentle)</p>
<p dir="auto">class CloneStalker (plugins.ObjectData):<br />
def  <strong>init</strong> (self):<br />
self.SetOptimizeCache(True)</p>
<pre><code>def Init(self, node):
    # Parameter initialization
    self.InitAttr(node, float, [c4d.CL_STALKER_MAX_NULLS])
    node[c4d.CL_STALKER_MAX_NULLS] = 100.0
    pd = c4d.PriorityData()
    if pd is None:
        raise MemoryError("Failed to create a priority data.")
    pd.SetPriorityValue(c4d.PRIORITYVALUE_MODE, 4)
    pd.SetPriorityValue(c4d.PRIORITYVALUE_PRIORITY, 100)
    node[c4d.EXPRESSION_PRIORITY] = pd
def CheckDirty(self, op, doc):
    frame = doc.GetTime().GetFrame(doc.GetFps())
    if frame != lastFrame:
        lastFrame = frame
        op.SetDirty(c4d.DIRTYFLAGS_DATA)
def AddToExecution(self, op, list) :
    list.Add(op, c4d.EXECUTIONPRIORITY_GENERATOR, 400)
def GetVirtualObjects(self, op, hh):
    cloner = op[c4d.CL_STALKER_TARGET]
    def GetStalkers(bname,tgt):
        allChild = tgt.GetChildren()
        stalkerChilds = []
        if allChild != None:
            for i in allChild:
                childname = i[c4d.ID_BASELIST_NAME]
                bnamelenght = len(bname)
                subname = childname[0:bnamelenght]
                if subname == bname:
                    stalkerChilds.append(i)
        return stalkerChilds
    if cloner != None:
        modata=mo.GeGetMoData(cloner)
        if modata != None:
            cache =  cloner.GetDeformCache()
            if cache is None:
                cache = cloner.GetCache()
            clones = cache.GetChildren()
            name = str(cloner[c4d.ID_BASELIST_NAME]) + ".Cloner Stalker"
            child_basename = op[c4d.ID_BASELIST_NAME].replace(".Cloner Stalker", ".Stalker.")
            if cloner.GetNext() != op:
                op.InsertAfter(cloner)
            null= c4d.BaseObject(c4d.Onull)
            null[c4d.NULLOBJECT_DISPLAY]=0
            null[c4d.ID_BASELIST_NAME] = name
            parent=op
            md = mo.GeGetMoData(cloner)
            marr = md.GetArray(c4d.MODATA_MATRIX)
            count = md.GetCount()
            Selection = []
            maxNulls = op[c4d.CL_STALKER_MAX_NULLS]
            lastChild = None
            child = GetStalkers(child_basename,op)
            if mo.GeGetMoDataSelection(cloner) == None:
                for i in range(count):
                    Selection.append(i)
                selected=Selection
            if  mo.GeGetMoDataSelection(cloner)!= None:
                Selection = mo.GeGetMoDataSelection(cloner).GetAll(count)
                selected=[i for i,x in enumerate(Selection) if x==1]
            if op[c4d.ID_BASELIST_NAME]!=name:
                if len(child)&gt;0:
                    for i in child:
                        old_name =i[c4d.ID_BASELIST_NAME]
                        index_name = old_name[len(child_basename):len(old_name)]
                        n_name = cloner[c4d.ID_BASELIST_NAME] + ".Stalker." + index_name
                        i[c4d.ID_BASELIST_NAME] = n_name
                        print (n_name)
                op[c4d.ID_BASELIST_NAME] = name
                parent=op
            op.SetMg(cloner.GetMg())
            if len(child)&lt;len(selected) and len(child) &lt; maxNulls:
                currChilds=[]
                for i in child:
                    child_name = i[c4d.ID_BASELIST_NAME]
                    nameLenght = len(child_name)
                    index = int(child_name[len(child_basename):nameLenght])
                    currChilds.append(index)
                new = [item for item in selected if item not in currChilds]
                for i in new:
                    obj= c4d.BaseObject(c4d.Onull)
                    obj[c4d.ID_BASELIST_NAME] = child_basename + str(i)
                    obj[c4d.NULLOBJECT_DISPLAY]=3
                    obj[c4d.NULLOBJECT_RADIUS]=50
                    extCompTag = c4d.BaseTag(465000402)
                    matrix = clones[i].GetMg()
                    obj.SetMg(matrix)
                    obj.InsertTag(extCompTag)
                    if len(child)&gt;0:
                        lastChild = child[(len(child)-1)]
                    doc.InsertObject(obj,parent,lastChild)
                    if len(child)==maxNulls:
                        break
            if len(child)&gt;len(selected) or len(child)&gt;maxNulls:
                for i in child:
                    index = child_name[len(child_basename):nameLenght]
                    if not int(index) in selected:
                        i.Remove()
                while len(child)&gt;maxNulls:
                    lastChild.Remove()
def Execute(self, op, doc, bt, priority, flags) :
        stalkerChilds = []
            for i in allChild:
    parent=op
    Selection = []
    if cloner != None:
        if modata != None:
            if cache is None:
                    Selection.append(i)
                    selected=Selection
            for x in selected:
                matrix = clones[x].GetMg()
                ch_name = child_basename + str(x)
                obj=c4d.documents.BaseDocument.SearchObject(doc,ch_name)
                obj.SetMg(matrix)
                print (clones[x].IsDirty(1))
    return c4d.EXECUTIONRESULT_OK
</code></pre>
<p dir="auto">Please feel free to advise what i am doing wrong here, and what shuold i be doing instead.</p>
<p dir="auto">many thanks for your patience.<br />
cheers<br />
Eddie</p>
]]></description><link>http://developers.maxon.net/forum/post/67063</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/67063</guid><dc:creator><![CDATA[Eduardo Oliveira]]></dc:creator><pubDate>Mon, 05 Jul 2021 19:56:13 GMT</pubDate></item><item><title><![CDATA[Reply to External Compositing Tag not working with generated objects by ObjectData Plugin on Sat, 25 Jul 2020 07:52:13 GMT]]></title><description><![CDATA[<p dir="auto">Hi Eddy, welcome for the Forum and thanks for reaching out us.</p>
<p dir="auto">With regard to your issue, I think the problem is how you handle your <code>ObjectData</code> cache and when if update it during the scene evaluation. In the code below beside checking for my object cache existence and for my object's parameters changes I also check if the cloner's cache has changed when the <code>ObjectData::GetVirtualObjects</code> is called.</p>
<pre><code>class PC_12764 (plugins.ObjectData):
	_clonerDirty = 0
		cloner = op[1002]
		res = c4d.BaseObject(c4d.Onull)
		if cloner is None:
			return res
		clonerCache = cloner.GetCache()
		if clonerCache is None:
			return res
		firstClonerItem = clonerCache.GetDown()
		if firstClonerItem is None:
			return res
		# check cloner cache dirty count
		clonerDirty = False
		if self._clonerDirty != cloner.GetDirty(c4d.DIRTYFLAGS_CACHE):
			clonerDirty = True
			self._clonerDirty = cloner.GetDirty(c4d.DIRTYFLAGS_CACHE)
		# return object cache taking in account cloner cache
		dirty = op.CheckCache(hh) or op.IsDirty(c4d.DIRTY_DATA) or clonerDirty
		if not dirty :
			return op.GetCache(hh)
		while firstClonerItem is not None:
			child = c4d.BaseObject(c4d.Onull)
			child.SetMg(firstClonerItem.GetMg())
			child.InsertUnder(res)
			firstClonerItem = firstClonerItem.GetNext()
		return res
</code></pre>
<p dir="auto">This approach, without using the <code>ObjectData::Execute()</code> gives ,in the end, consistent results when exporting a <em>.aec</em> file using a External Compositing Tag as in the scene attached.</p>
<h4>AEC file except</h4>
<pre><code class="language-text">...
NULL2 "Null"
  NULLTYPE 1
  SIZEX 200
  SIZEY 100
  ANCHOR 3
  ORIENTATION 1
  COLOR 1 0 0
  SHOWFROM 1
  SHOWTO 10
  KEY 1 200 200 200 0 0 0 0 0 0
  KEY 2 202.036 195.61 204.755 0 0 0 0 0 0
  KEY 3 206.929 185.058 216.184 0 0 0 0 0 0
  KEY 4 212.786 172.427 229.866 0 0 0 0 0 0
  KEY 5 217.679 161.875 241.295 0 0 0 0 0 0
  KEY 6 219.714 157.485 246.051 0 0 0 0 0 0
  KEY 7 217.679 161.875 241.295 0 0 0 0 0 0
  KEY 8 212.786 172.427 229.866 0 0 0 0 0 0
  KEY 9 206.929 185.058 216.184 0 0 0 0 0 0
  KEY 10 202.036 195.61 204.755 0 0 0 0 0 0
NULL2 "Null"
  NULLTYPE 1
  SIZEX 200
  SIZEY 100
  ANCHOR 3
  ORIENTATION 1
  COLOR 1 0 0
  SHOWFROM 1
  SHOWTO 10
  KEY 1 0 200 200 0 0 0 0 0 0
  KEY 2 0.427 201.541 196.343 0 0 0 0 0 0
  KEY 3 1.453 205.246 187.554 0 0 0 0 0 0
  KEY 4 2.681 209.681 177.032 0 0 0 0 0 0
  KEY 5 3.707 213.385 168.242 0 0 0 0 0 0
  KEY 6 4.134 214.927 164.585 0 0 0 0 0 0
  KEY 7 3.707 213.385 168.242 0 0 0 0 0 0
  KEY 8 2.681 209.681 177.032 0 0 0 0 0 0
  KEY 9 1.453 205.246 187.554 0 0 0 0 0 0
  KEY 10 0.427 201.541 196.343 0 0 0 0 0 0
</code></pre>
<h4>Scene file</h4>
<p dir="auto"><a href="https://developers.maxon.net/forum/assets/uploads/files/1595663381115-pc_12764.c4d" target="_blank" rel="noopener noreferrer nofollow ugc">PC_12764.c4d</a></p>
]]></description><link>http://developers.maxon.net/forum/post/63782</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/63782</guid><dc:creator><![CDATA[r_gigante]]></dc:creator><pubDate>Sat, 25 Jul 2020 07:52:13 GMT</pubDate></item></channel></rss>
