<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Transparency channel - Color update]]></title><description><![CDATA[<p dir="auto">Hi,<br />
In the 'Transparency' channel of a material, I need to modify the color.<br />
How to read and modify this value with Python ?<br />
I already have the material identifier.</p>
]]></description><link>http://developers.maxon.net/forum/topic/12557/transparency-channel-color-update</link><generator>RSS for Node</generator><lastBuildDate>Sun, 11 Oct 2026 11:43:47 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/12557.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 May 2020 11:20:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Transparency channel - Color update on Fri, 08 May 2020 11:51:33 GMT]]></title><description><![CDATA[<p dir="auto">I found the solution (I already had this problem but I couldn't remember the right code)</p>
<p dir="auto">mat [c4d.MATERIAL_TRANSPARENCY_COLOR] = c4d.Vector (1.0, 1.0, 1.0)   #color white<br />
mat.Update (True, True)</p>
]]></description><link>http://developers.maxon.net/forum/post/62806</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/62806</guid><dc:creator><![CDATA[Kantronin]]></dc:creator><pubDate>Fri, 08 May 2020 11:51:33 GMT</pubDate></item><item><title><![CDATA[Reply to Transparency channel - Color update on Fri, 08 May 2020 11:50:59 GMT]]></title><description><![CDATA[<p dir="auto">You can simply edit the <code>MATERIAL_TRANSPARENCY_COLOR</code> parameter.</p>
<pre><code>Mat[c4d.MATERIAL_TRANSPARENCY_COLOR]
</code></pre>
<p dir="auto">The parameter stores a <a href="https://developers.maxon.net/docs/py/2023_2/modules/c4d/Vector/index.html?highlight=vector" target="_blank" rel="noopener noreferrer nofollow ugc">c4d.Vector</a>.</p>
<p dir="auto">You find examples on how to handle materials on <a href="https://github.com/PluginCafe/cinema4d_py_sdk_extended/tree/master/scripts/04_3d_concepts/scene_elements/materials_shading" target="_blank" rel="noopener noreferrer nofollow ugc">GitHub</a>.</p>
]]></description><link>http://developers.maxon.net/forum/post/62805</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/62805</guid><dc:creator><![CDATA[PluginStudent]]></dc:creator><pubDate>Fri, 08 May 2020 11:50:59 GMT</pubDate></item></channel></rss>
