<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[retrieve data from multiple cloners in python]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I'm sorry if I'm posting a repeated topic. I am trying to get color data from multiple mo-graph in python to send out to a micro controller for realtime animation.<br />
I am explaining what I've done so far<br />
I have 90 linear cloners of cubes (there are 30 of them in each cloner). I want to get color data from each clone and send the rgb color to the controller. After a couple of hours searching I came to this conclusion to make a blank 2D list, append each cloner as an object to the list and therefore, I can have an ID to retrieve the data from. from my one week experience in C4D and python, I wrote this code. I set 2 cloners as user data. this it absolutely not working. If any one has done sth similar to what I want to do, his/her help would be much appreciated.</p>
<pre><code>import c4d
from c4d.modules import mograph as mo
from c4d import utils
    n = 2
    m = 33
    Matrix = &lsqb;&lsqb;0] * m for i in range(n)]
    Obj1 = op[c4d.ID_USERDATA,2]
    Obj2 = op[c4d.ID_USERDATA,1]
    count = len(Obj1)
    print count
    for j in range (32):
       Matrix[j][0] = Obj1
       Matrix[j][1] = Obj2
    md = mo.GeGetMoData(op)
    if md==None: return False
    cnt = md.GetCount()
    marr = md.GetArray(c4d.MODATA_MATRIX)
    carr = md.GetArray(c4d.MODATA_COLOR)
    print carr
    for i in reversed(xrange(0, cnt)):
       md.SetArray(c4d.MODATA_COLOR, carr, True)
       md.SetArray(c4d.MODATA_WEIGHT, warr, True)
</code></pre>
]]></description><link>http://developers.maxon.net/forum/topic/11500/retrieve-data-from-multiple-cloners-in-python</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 09:56:52 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/11500.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Apr 2019 20:22:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to retrieve data from multiple cloners in python on Tue, 23 Apr 2019 16:59:13 GMT]]></title><description><![CDATA[<p dir="auto">Thank you <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/m_adam">@<bdi>m_adam</bdi></a> it's really helpful! I was going to a wrong direction. I chose to do a project that has every new aspect to explore :)) I will for sure disturb you in future with my questions. I appreciate your suggestions.</p>
<p dir="auto">Parvin</p>
]]></description><link>http://developers.maxon.net/forum/post/58084</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/58084</guid><dc:creator><![CDATA[Parvin]]></dc:creator><pubDate>Tue, 23 Apr 2019 16:59:13 GMT</pubDate></item><item><title><![CDATA[Reply to retrieve data from multiple cloners in python on Tue, 23 Apr 2019 16:31:40 GMT]]></title><description><![CDATA[<p dir="auto">I don't think effector is the best way to achieve that at least your effector could retrieve data only for the current generator/object it's currently sampling, so one object per time. So an effector does not have an idea of the whole picture.</p>
<p dir="auto">The best way would be either to have a GeDialog that will monitor the scene and send the data (but that involve to make a plugin, it's not complicated but its an external file and not directly embedded within a C4D file)<br />
Another solution could be to do a scripting tag, with the correct priority (so it's executed after mograph generation) which will retrieve all data you need. You could add an InExclude UserData to this tag so could drag and drop the cloner in the list and use this as an ID.</p>
<p dir="auto">Anyway I adapted the example to make it work, with simple cloner (no nested), so the op object of the main method should be a cloner and it will tell you the color for each clone.</p>
<pre><code>"""
Copyright: MAXON Computer GmbH
Author: Maxime Adam
Description:
    - Retrieves the color or each clone using two ways.
    - First one by accessing directly the Mograph Data.
    - Second one by accessing the polygon cache representation of the Mograph Cloner.
Class/method highlighted:
    - c4d.modules.mograph.GeGetMoData()
    - c4d.modules.mograph.MoData
    - MoData.GetArray()
    - BaseObject.GetCache()
    - BaseObject.GetDeformCache()
Compatible:
    - Win / Mac
    - R16, R17, R18, R19, R20
def RetrieveColorWithMoData(op):
    if not op.CheckType(1018544):
        raise TypeError("objects is not a cloner.")
    # Retrieves the modata
    md = c4d.modules.mograph.GeGetMoData(op)
    if md is None:
        return []
    # Retrieves the clone offset and the color array
    offset = op[c4d.MG_LINEAR_OFFSET]
    colorList = md.GetArray(c4d.MODATA_COLOR)
    # Appends the color list taking in account the offset (aka skip the first elements)
    return colorList[offset:]
def DeformedPolygonCacheIterator(op):
    A Python Generator to iterate over all PolygonCache of passed BaseObject
    :param op: The BaseObject to retrieves all PolygonObject cache.
    if not isinstance(op, c4d.BaseObject):
        raise TypeError("Expected a BaseObject or derived class got {0}".format(op.__class__.__name__))
    # Try to retrieves the deformed cache of the object
    temp = op.GetDeformCache()
    if temp is not None:
        # If there is a deformed cache we iterate over him, a deformed cache can also contain deformed cache
        # e.g. in case of a nested deformer
        for obj in DeformedPolygonCacheIterator(temp):
            yield obj
    # Try to retrieves the cache of the Object
    temp = op.GetCache()
        # If there is a cache iterate over its, a cache can also contain deformed cache
        # e.g. an instance, have a cache of its linked object but if this object is deformed, then you have a deformed cache as well
            yield obj
    # If op is not a generator / modifier
    if not op.GetBit(c4d.BIT_CONTROLOBJECT):
        # If op is a PolygonObject we return it
        if op.IsInstanceOf(c4d.Opolygon):
            yield op
    # Then finally iterates over the child of the current object to retrieves all objects
    # e.g. in a cloner set to Instance mode, all clones is a new object.
    temp = op.GetDown()
    while temp:
            yield obj
        temp = temp.GetNext()
def RetrieveColorWithCache(op):
    # Iterates the polygon cache of a cloner (does work only, in case of simple instance mode)
    finalList = []
    # Iterates overs each polygon object cache
    for i, obj in enumerate(DeformedPolygonCacheIterator(op)):
        # Adds the object information in the last list
        finalList.append(obj[c4d.ID_BASEOBJECT_COLOR])
    return finalList
    # Checks if there is a selected object, and this selected object get a child object.
    if not op:
        raise RuntimeError("Failed to retrieves op")
    # Checks if selected object and child objects are cloner objects.
        raise TypeError("objects is not cloner.")
    print RetrieveColorWithMoData(op)
    print RetrieveColorWithCache(op)
</code></pre>
<p dir="auto">With that's said I think you have everything you need to build your stuff, at least for reading a cloner object.</p>
<p dir="auto">The project looks cool, so even if it seems complicated don't give up and don't hesitate to ask questions ! <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /><br />
Cheers,<br />
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/58082</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/58082</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Tue, 23 Apr 2019 16:31:40 GMT</pubDate></item><item><title><![CDATA[Reply to retrieve data from multiple cloners in python on Tue, 23 Apr 2019 16:07:41 GMT]]></title><description><![CDATA[<p dir="auto">I have 90 strut shaping a sphere in this scene. each strut is a linear cloner of cubes and they represent LED strips. I want to animate the light in realtime. So, I am trying to animate the sphere with effectors and change the color, then send the color data through Lumos Library to a Raspberry Pi to animate light. I'm awfully new to C4D and Python in C4D.<br />
I know I have to give address to each cube and link it with the address I have for the LED pixel. But that goes way further. what I'm struggling with now is capturing data of each cloner.</p>
<p dir="auto">Thanks for your patience,<br />
Parvin</p>
]]></description><link>http://developers.maxon.net/forum/post/58081</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/58081</guid><dc:creator><![CDATA[Parvin]]></dc:creator><pubDate>Tue, 23 Apr 2019 16:07:41 GMT</pubDate></item><item><title><![CDATA[Reply to retrieve data from multiple cloners in python on Tue, 23 Apr 2019 15:58:31 GMT]]></title><description><![CDATA[<p dir="auto">Then I'm afraid I still don't understand the final result, please be more explicit about what you are trying to achieve, what the expected behavior. In your first post, you said it's not working, but now I do have a scene example so please tell me what you want to achieve within the scene.</p>
<p dir="auto">Cheers,<br />
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/58080</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/58080</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Tue, 23 Apr 2019 15:58:31 GMT</pubDate></item><item><title><![CDATA[Reply to retrieve data from multiple cloners in python on Tue, 23 Apr 2019 15:25:02 GMT]]></title><description><![CDATA[<p dir="auto">Oh I see. I take that note for python effector, thanks. I think I explained it in a very wrong way because as I see you have a cloner as the child of other cloner. In my example, I have 90 different cloners. I will attach my example.</p>
<p dir="auto">P</p>
<p dir="auto"><a href="https://developers.maxon.net/forum/assets/uploads/files/1556033075689-90-strut_animation.c4d" target="_blank" rel="noopener noreferrer nofollow ugc">90 strut_Animation.c4d</a></p>
]]></description><link>http://developers.maxon.net/forum/post/58079</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/58079</guid><dc:creator><![CDATA[Parvin]]></dc:creator><pubDate>Tue, 23 Apr 2019 15:25:02 GMT</pubDate></item><item><title><![CDATA[Reply to retrieve data from multiple cloners in python on Tue, 23 Apr 2019 15:03:20 GMT]]></title><description><![CDATA[<p dir="auto">Hoo sorry, I overlooked the fact that you are directly in a python effector and not in the script manager (in fact I missed to ask you, please next time try to say us, in which context you are executing python).</p>
<p dir="auto">So I should have mentioned that the selected object should be the topmost cloner (the cloner of the cloner).<br />
So with that's said, with my previous scrip use "gen" instead of op in main and it's fixed see <a href="https://developers.maxon.net/docs/py/2023_2/manuals/introduction/python_effector.html?highlight=effector" target="_blank" rel="noopener noreferrer nofollow ugc">Python Effector</a>.<br />
Here is the example <a href="https://developers.maxon.net/forum/assets/uploads/files/1556031694145-cloner.c4d" target="_blank" rel="noopener noreferrer nofollow ugc">cloner.c4d</a></p>
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/58078</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/58078</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Tue, 23 Apr 2019 15:03:20 GMT</pubDate></item><item><title><![CDATA[Reply to retrieve data from multiple cloners in python on Tue, 23 Apr 2019 14:20:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/m_adam">@<bdi>m_adam</bdi></a> when I ran the code you posted, I got the error "Failed to retrieves op and its child". I am calling each function in the main to realize what each of them is doing. But I think all of them are linked to one another.<br />
So my main question is that when you say I need to select my objects in order, how should I exactly do this? I put the Python Effector in the effectors list for each 90 cloners that I have, and I assumed this would work.</p>
<p dir="auto">Thanks,<br />
Parvin</p>
]]></description><link>http://developers.maxon.net/forum/post/58077</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/58077</guid><dc:creator><![CDATA[Parvin]]></dc:creator><pubDate>Tue, 23 Apr 2019 14:20:55 GMT</pubDate></item><item><title><![CDATA[Reply to retrieve data from multiple cloners in python on Tue, 23 Apr 2019 13:37:57 GMT]]></title><description><![CDATA[<p dir="auto">Wow! thanks Adam. I have to take my time to process all the useful information you gave me. I will reply on this post if I have further questions.</p>
]]></description><link>http://developers.maxon.net/forum/post/58074</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/58074</guid><dc:creator><![CDATA[Parvin]]></dc:creator><pubDate>Tue, 23 Apr 2019 13:37:57 GMT</pubDate></item><item><title><![CDATA[Reply to retrieve data from multiple cloners in python on Tue, 23 Apr 2019 13:39:06 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/parvin">@<bdi>Parvin</bdi></a>, first of all, welcome in the plugincafe community!</p>
<p dir="auto">Regarding your requestion, a cloner is simply a generator that will copy objects in its cache (like any generator), so in order to access the correct data, you should first access the cache of the first cloner then here you can iterates the cloner and query them for their color like so.</p>
<pre><code>"""
Author: Maxime Adam
Description:
    - MoData.GetArray()
Compatible:
    - Win / Mac
    # Retrieving internal cache of the first cloner to access each cloner and query them.
    cacheMainClone = op.GetCache()
    if cacheMainClone is None:
        raise RuntimeError("Failed to retrieves the cached cloner.")
    # Cloner object creates a null, with all their clones. So we dive into this null, and it should be a cloner object
    clonerCache = cacheMainClone.GetDown()
    if not clonerCache.CheckType(1018544):
        raise TypeError("objects are not cloners.")
    # Iterates each cloner and retrieves the data for each one
    finalList = []
    while clonerCache:
        md = c4d.modules.mograph.GeGetMoData(clonerCache)
        if md is None:
            continue
        offset = clonerCache[c4d.MG_LINEAR_OFFSET]
        finalList.append(colorList[offset:])
        # Process the next cloner
        clonerCache = clonerCache.GetNext()
    return finalList
            yield obj
            yield obj
            yield op
    temp = op.GetDown()
    while temp:
            yield obj
    childClonerCnt = op.GetDown()[c4d.MG_LINEAR_COUNT]
    finalList = []
        # For each new list we add a new list
        d = float(i) / float(childClonerCnt)
        if float(d) == int(d):
            finalList.append([])
        finalList[-1].append(obj[c4d.ID_BASEOBJECT_COLOR])
    return finalList
    if not op or not op.GetDown():
        raise RuntimeError("Failed to retrieves op and its child.")
    if not op.CheckType(1018544) or not op.GetDown().CheckType(1018544):
</code></pre>
<p dir="auto">Don't worry since it's your first topic, in order to setup correctly your next topics (I've done it for this one) please read and apply:</p>
<ul>
<li><a href="https://developers.maxon.net/forum/topic/11004/q-a-new-functionality" target="_blank" rel="noopener noreferrer nofollow ugc">Q&amp;A New Functionality</a>.</li>
<li><a href="https://developers.maxon.net/forum/topic/10953/how-to-post-questions" target="_blank" rel="noopener noreferrer nofollow ugc">How to Post Questions</a>.</li>
</ul>
<p dir="auto">Of course, if you have any question, please let me know.<br />
Cheers,<br />
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/58073</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/58073</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Tue, 23 Apr 2019 13:39:06 GMT</pubDate></item></channel></rss>
