<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Drawing on MultipassBitmap&#x27;s GeClipMap crashes in R16.050]]></title><description><![CDATA[<p dir="auto">I know R16 is old history by now, but I still want to keep my plugins compatible as much as possible.<br />
I had updated the R20 version of the plugin, and wanted to port back the updates to R19. However, due to compatibility reason, the plugin is being developed with the R16 SDK.</p>
<p dir="auto">Following is an excerpt of the implementation that was ported to R16.</p>
<pre><code>	const COLORMODE colorMode = COLORMODE_ARGB;
	MultipassBitmap* multiBitmap = MultipassBitmap::Alloc(mBitmapSize, mBitmapSize, colorMode);
	MultipassBitmap* layer = multiBitmap-&gt;GetLayerNum(0);
	layer-&gt;SetParameter(MPBTYPE_NAME, "Background");
	layer-&gt;SetParameter(MPBTYPE_SAVE, true);
	layer-&gt;SetParameter(MPBTYPE_SHOW, true);
	// draw onto this layer via a ClipMap
	AutoAlloc&lt;GeClipMap&gt; clipMap;
	if (clipMap &amp;&amp; (clipMap-&gt;Init(layer) == IMAGERESULT_OK))
		viewData-&gt;mClipmap = clipMap.operator GeClipMap *();
		clipMap-&gt;BeginDraw();
		viewData-&gt;DrawBackground();
void ViewData::DrawBackground()
	Vector color(128);
	mClipmap-&gt;SetColor(SAFEINT32(color.x), SAFEINT32(color.y), SAFEINT32(color.z), 255);
	mClipmap-&gt;FillRect(0, 0, mClipmap-&gt;GetBw() - 1, mClipmap-&gt;GetBh() - 1);
</code></pre>
<p dir="auto">Building the plugin (with R16 SDK) and running it from Cinema 4D R19 yields no problem.<br />
However, when running in R16.050 it just locks up, or when ran in debug from VisualStudio it crashes when <code>FillRect</code>, or any other <code>GeClipMap</code> drawing function is performed.</p>
<p dir="auto">Now, I understand no support can be given for R16, but I just wanted to make sure it was a problem then (which has been fixed since). Or if I need to do something different in R16 to make it work.<br />
Have not yet tested with R17 or R18 to know where the boundary "works / does not work" actually is.</p>
]]></description><link>http://developers.maxon.net/forum/topic/11403/drawing-on-multipassbitmap-s-geclipmap-crashes-in-r16-050</link><generator>RSS for Node</generator><lastBuildDate>Tue, 13 Oct 2026 20:02:26 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/11403.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Mar 2019 15:49:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Drawing on MultipassBitmap&#x27;s GeClipMap crashes in R16.050 on Fri, 17 Jan 2020 14:51:50 GMT]]></title><description><![CDATA[<p dir="auto">Just for future reference ...</p>
<p dir="auto">The topic's tag indicates this to be "solved" when it definitely isn't.<br />
But as this is a R16 issue only I guess no further time will be taken to figure out why this issue exists in R16 and not in newer releases. Also, there is currently no workaround as far as I know. The only thing one can do is check for the current C4D version running and avoid writing to a <code>MultipassBitmap</code>.</p>
]]></description><link>http://developers.maxon.net/forum/post/61116</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/61116</guid><dc:creator><![CDATA[C4DS]]></dc:creator><pubDate>Fri, 17 Jan 2020 14:51:50 GMT</pubDate></item><item><title><![CDATA[Reply to Drawing on MultipassBitmap&#x27;s GeClipMap crashes in R16.050 on Fri, 15 Mar 2019 08:19:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/martinweber">@<bdi>martinweber</bdi></a><br />
Never actually cared trying <code>Clear()</code> as this is a <code>BaseBitmap</code> method, and not <code>GeClipMap</code>.<br />
But I tried now just to check, and while it doesn't crash Visual Studio reports that it triggered a breakpoint. No crash, but not a good thing either.<br />
And so does calling <code>SetPen()</code> or <code>Line()</code>.<br />
Unfortunately, the output is left empty. I have tried using a simple RGB colormode, instead of the original ARGB ... hoping the issue might have something to do with the alpha channel. But same issue no matter the colormode.</p>
<p dir="auto">Seems I am unable to draw on a <code>MultipassBitmap</code> in R16.</p>
]]></description><link>http://developers.maxon.net/forum/post/57667</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/57667</guid><dc:creator><![CDATA[C4DS]]></dc:creator><pubDate>Fri, 15 Mar 2019 08:19:35 GMT</pubDate></item><item><title><![CDATA[Reply to Drawing on MultipassBitmap&#x27;s GeClipMap crashes in R16.050 on Fri, 15 Mar 2019 07:34:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/c4ds">@<bdi>C4DS</bdi></a> I see. Does Clear() work?</p>
<p dir="auto">I am curious as we have a use case where we would go with GeClipMap as well.</p>
]]></description><link>http://developers.maxon.net/forum/post/57666</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/57666</guid><dc:creator><![CDATA[martinweber]]></dc:creator><pubDate>Fri, 15 Mar 2019 07:34:57 GMT</pubDate></item><item><title><![CDATA[Reply to Drawing on MultipassBitmap&#x27;s GeClipMap crashes in R16.050 on Thu, 14 Mar 2019 20:14:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/martinweber">@<bdi>martinweber</bdi></a> said in <a href="https://developers.maxon.net/forum/post/57649" target="_blank" rel="noopener noreferrer nofollow ugc">Drawing on MultipassBitmap's GeClipMap crashes in R16.050</a>:</p>
<blockquote>
<p dir="auto">Just some ideas and guesses:</p>
</blockquote>
<p dir="auto">Thanks Martin.</p>
<ul>
<li>I do check if layer is nullptr, but hadn't included this in the provided code snippet, in order to keep it as short as possible.</li>
<li>Tried to cast the layer to basebitmap before using it to initialize a GeClipMap. Still same problem.</li>
<li>Using <code>operator GeClipMap *()</code> is something I picked up from ... (cannot remember). I confirm that simply assigning the clipmap to viewData-&gt;mClipMap, does work as well. However, passing clipmap as parameter to DrawBackground is not an option in my situation.</li>
</ul>
<p dir="auto">Tried all of the above, but still get an exception thrown as a result of access violation writing location 0x00..03FF when performing a clipmap-&gt;FillRect.</p>
<p dir="auto">The <code>SetColor</code> is fine, and so are the <code>GetBw</code> and <code>GetBh</code>, but the actual <code>FillRect</code> throws an exception. But only on a <code>MultipassBitmap</code>. Doing exactly the same on a regular <code>BaseBitmap</code> is fine.</p>
]]></description><link>http://developers.maxon.net/forum/post/57661</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/57661</guid><dc:creator><![CDATA[C4DS]]></dc:creator><pubDate>Thu, 14 Mar 2019 20:14:39 GMT</pubDate></item><item><title><![CDATA[Reply to Drawing on MultipassBitmap&#x27;s GeClipMap crashes in R16.050 on Thu, 14 Mar 2019 13:05:41 GMT]]></title><description><![CDATA[<p dir="auto">Just some ideas and guesses:</p>
<ul>
<li>check if layer is not actually a nullptr. Might fail there already.</li>
<li>I would try a dynamic_cast&lt;BaseBitmap&gt;(layer) for layer in clipMap-&gt;Init(layer) just to be sure the right vtable is used. AutoAlloc might do something fancy there.</li>
<li>why not use viewData-&gt;mClipMap = clipMap; ? Your use of operator*() seems strange. Also, why not just use it as parameter to DrawBackground()?</li>
</ul>
<p dir="auto">Cheers,<br />
Martin</p>
]]></description><link>http://developers.maxon.net/forum/post/57649</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/57649</guid><dc:creator><![CDATA[martinweber]]></dc:creator><pubDate>Thu, 14 Mar 2019 13:05:41 GMT</pubDate></item><item><title><![CDATA[Reply to Drawing on MultipassBitmap&#x27;s GeClipMap crashes in R16.050 on Fri, 15 Mar 2019 08:21:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/a_block">@<bdi>a_block</bdi></a><br />
I don't actually have a workaround, I simply do not allow the feature to be used on pre-R16. (EDIT: should read "pre-R17")</p>
<p dir="auto">However, I don't see the point for further digging. If something didn't work in R16, there's no fix nor update to be expected.<br />
And since no problems seem to exist from R17 on, all is fine for users using R17 and above. Too bad for the R16 users, I guess.</p>
<p dir="auto">Seems it's time for me to move on and start skipping support for older versions.</p>
<p dir="auto">Thanks for taking the time to investigate.</p>
]]></description><link>http://developers.maxon.net/forum/post/57621</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/57621</guid><dc:creator><![CDATA[C4DS]]></dc:creator><pubDate>Fri, 15 Mar 2019 08:21:10 GMT</pubDate></item><item><title><![CDATA[Reply to Drawing on MultipassBitmap&#x27;s GeClipMap crashes in R16.050 on Tue, 12 Mar 2019 16:47:47 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I checked our change logs R16 to R17 and I see no mention of anything that could lead to your issue. So I would need to dig through lots of change lists in our revision control system, which I'd rather not do.<br />
Also I see no immediate issues with your snippet above.<br />
Not sure, we should dig into this further. Also because you seem to have a workaround.</p>
Andreas</p>
]]></description><link>http://developers.maxon.net/forum/post/57617</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/57617</guid><dc:creator><![CDATA[a_block]]></dc:creator><pubDate>Tue, 12 Mar 2019 16:47:47 GMT</pubDate></item><item><title><![CDATA[Reply to Drawing on MultipassBitmap&#x27;s GeClipMap crashes in R16.050 on Mon, 11 Mar 2019 16:50:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/a_block">@<bdi>a_block</bdi></a><br />
Sorry if I wasn't clear with my message.<br />
I had added new functionality in my R20 plugin, which works OK using the provided code snipped.<br />
From this I went back to earlier releases and ported the changes made in the plugin.<br />
The changes do work on R19, R18 and R17, but are an issue in R16. Tested with the same plugin, built with the R16 SDK, copying into the different releases' plugins folder.</p>
<p dir="auto">For now, I have added a check in the plugin, and avoid creating a multipassbitmap if version is prior to R17.<br />
Since nothing seems to have changed in this area, I am wondering what's the actual issue ... and if I might by accident have something working in R17 - R20.</p>
]]></description><link>http://developers.maxon.net/forum/post/57608</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/57608</guid><dc:creator><![CDATA[C4DS]]></dc:creator><pubDate>Mon, 11 Mar 2019 16:50:23 GMT</pubDate></item><item><title><![CDATA[Reply to Drawing on MultipassBitmap&#x27;s GeClipMap crashes in R16.050 on Mon, 11 Mar 2019 15:46:43 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">we are actually not aware of changes in this area.<br />
Is this some new functionality you were implementing or is this an issue, that came up by adding changes needed for R20? Or is it even a long standing issue?<br />
If you could provide us with more details at which version your problems start, it would help a lot to reduce any research needed.</p>
Andreas</p>
]]></description><link>http://developers.maxon.net/forum/post/57607</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/57607</guid><dc:creator><![CDATA[a_block]]></dc:creator><pubDate>Mon, 11 Mar 2019 15:46:43 GMT</pubDate></item></channel></rss>
