<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[deformer object priority]]></title><description><![CDATA[<p dir="auto">hi,<br />
if deformer object have priority? or can  i add priority to deformer object ?I  have some problems about priority.<br />
My work:<br />
Deformer object control polygon point,<br />
point control joint(use Xpresso,Priority: Generator 1),<br />
joint control another polygon by Skin(Priority: Generator 2).</p>
<p dir="auto">Thing look  easy and orderly,but not.when i change Deformer object  parameter,everything is ok,but  'ctrl + z'，polygon object can't  back to the original,must click object or play  <a href="http://refresh.So" target="_blank" rel="noopener noreferrer nofollow ugc">refresh.So</a>, i think maybe add priority to deformer object  is a resolvent? Or what mistakes have I made?(use python tag did't get Priority form deformer object,return None )</p>
]]></description><link>http://developers.maxon.net/forum/topic/11122/deformer-object-priority</link><generator>RSS for Node</generator><lastBuildDate>Sat, 10 Oct 2026 13:53:38 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/11122.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 03 Nov 2018 04:18:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to deformer object priority on Tue, 06 Nov 2018 02:46:55 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for your answer！<a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/m_adam">@<bdi>m_adam</bdi></a><br />
Although  object go back normal  after  i  clicked  'Redraw' (I guess that's the reason）,it isn't make sure problem is 'refresh the viewport'. 'refresh the viewport'  can  also  fix  Priority error result .<br />
'Shift Priority Tag'  just effective  <a href="http://Expression.It" target="_blank" rel="noopener noreferrer nofollow ugc">Expression.It</a> can't help.<br />
After asking questions，i  try to use Python Tag to replace 'Spline Deformer Object' ,because Python Tag have Priority.Fortunately，even though it looks very complicated, but everything become ok!</p>
]]></description><link>http://developers.maxon.net/forum/post/56285</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56285</guid><dc:creator><![CDATA[mike]]></dc:creator><pubDate>Tue, 06 Nov 2018 02:46:55 GMT</pubDate></item><item><title><![CDATA[Reply to deformer object priority on Mon, 05 Nov 2018 12:07:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/mike">@<bdi>mike</bdi></a>,<br />
No worries at all since, but please make sure to read and apply the rules defined on the following topics:</p>
<ul>
<li><a href="https://developers.maxon.net/forum/topic/11004/q-a-new-functionality" target="_blank" rel="noopener noreferrer nofollow ugc">Q&amp;A Functionality</a>.</li>
</ul>
<p dir="auto">Regarding your question, you can make use of the Shift Priority Tags. You can find more information on the priority <a href="https://help.maxon.net/us/#TTARGETEXPRESSION-OBASELIST" target="_blank" rel="noopener noreferrer nofollow ugc">in the c4d help</a>.</p>
<p dir="auto">But C4D also offer the <a href="https://help.maxon.net/us/#TGROUPPRIORITY" target="_blank" rel="noopener noreferrer nofollow ugc">Shift Priority Tag</a>.<br />
Finally, note in some case it can be a limitation of the viewport which not refresh properly while data are correctly set.<br />
And you need to manually refresh the viewport.</p>
<p dir="auto">Hope it solves your issue, if you have any question please let me know!<br />
Cheers,<br />
Maxime!</p>
]]></description><link>http://developers.maxon.net/forum/post/56281</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56281</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Mon, 05 Nov 2018 12:07:07 GMT</pubDate></item></channel></rss>
