<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Getting MoData in GVO of a ObjectData Plugin]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I'm trying to get the positions of the mograph matrix object in my ObjectData plugin and i'm having trouble with checking if it's cache is dirty and updating.</p>
<p dir="auto">I'm using GetAndCheckHierarchyClone to tell if the cache is dirty, which is working, but for some reason it's saying that the cache is dirty twice.</p>
<p dir="auto">Also when it does say the cache is dirty, I go to read the Matrix Array, and it returns outdated data.</p>
<p dir="auto">Am I missing a step somewhere?</p>
<p dir="auto">I'm developing on Mac OSX with C4D R18.</p>
<p dir="auto">Here's my code (shortened for clarity and no error checking):</p>
<pre><code class="language-cpp">BaseObject* GetVirtualObjects(BaseObject* op, HierarchyHelp* hh)
    GeData     myData;
    Bool       dirty;
    BaseObject *outObject, *inObject, *hClone;
    outObject = BaseObject::Alloc(Ocube);
    dirty = false;
    hClone = nullptr;
    inObject = op-&gt;GetDown();
    hClone = op-&gt;GetAndCheckHierarchyClone(hh, inObject, HIERARCHYCLONEFLAGS_ASIS, &amp;dirty, nullptr, false);
    if (!dirty) {
        blDelete(outObject);
        return hClone;
    maxon::BaseArray&lt;Vector&gt; pointList;
    MoData *md;
    GetMoDataMessage mdm;
    mdm.modata = nullptr;
    mdm.index = 0; // Get first set of modata
    BaseTag *mct = hClone-&gt;GetTag(ID_MOBAKETAG); // check for cache
    BaseTag *mdt = hClone-&gt;GetTag(ID_MOTAGDATA); // get mograph tag
    if (!mct &amp;&amp; !mdt) // we need at least one
        return nullptr;
    if (mct) // check cache first
        mct-&gt;Message(MSG_GET_MODATA, &amp;mdm);
    if (!mdm.modata) // if cache didn't work, or if there is no cache
        mdt-&gt;Message(MSG_GET_MODATA, &amp;mdm);
    if (mdm.user_owned)
        md = mdm.Release();
    else
        md = mdm.modata;
    MDArray&lt;Matrix&gt; marr = md-&gt;GetMatrixArray(MODATA_MATRIX);
    for (Int32 x = 0; x &lt; md-&gt;GetCount(); x++)
        pointList.Append(marr[x].off);
    if (mdm.user_owned)
        MoData::Free(md);
    GePrint( String::IntToString( pointList.GetCount() ) );
    return outObject;
</code></pre>
]]></description><link>http://developers.maxon.net/forum/topic/11094/getting-modata-in-gvo-of-a-objectdata-plugin</link><generator>RSS for Node</generator><lastBuildDate>Tue, 13 Oct 2026 18:18:06 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/11094.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 24 Oct 2018 18:41:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Getting MoData in GVO of a ObjectData Plugin on Thu, 15 Nov 2018 17:36:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/m_adam">@<bdi>m_adam</bdi></a> thanks so much for all your help on this!</p>
]]></description><link>http://developers.maxon.net/forum/post/56391</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56391</guid><dc:creator><![CDATA[codysorgenfrey]]></dc:creator><pubDate>Thu, 15 Nov 2018 17:36:46 GMT</pubDate></item><item><title><![CDATA[Reply to Getting MoData in GVO of a ObjectData Plugin on Thu, 15 Nov 2018 13:49:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi @codysorgenfrey.<br />
Thanks a lot for writing to us. Actually Touching the matrix object, clean the cache of its. Since Matrix object is a bit special and only consist of a kind of cached version. If there is no cache (which is what happens when you touch an object), the matrix object rebuilds itself. So we end up with an infinite dirtiness issue.</p>
<p dir="auto">With that's said here a working example for handling matrix object. Note that we have to check the dirtiness manually.</p>
<pre><code>class ModataGvoObject : public ObjectData
	INSTANCEOF(ModataGvoObject, ObjectData)
private:
	UInt32 previousDirty;
public:
		// Create a Null master
		BaseObject* outObject = BaseObject::Alloc(Onull);
		if(!outObject)
			return nullptr;
		// Get the cache
		BaseObject* matrixObj = op-&gt;GetDown();
		if(!matrixObj || !matrixObj-&gt;IsInstanceOf(1018545)) // 1018545 = Matrix Object
			return outObject;
		// Calculate dirtyCount
		UInt32 newDirty = 0;
		newDirty += matrixObj-&gt;GetDirty(DIRTYFLAGS::MATRIX | DIRTYFLAGS::DATA | DIRTYFLAGS::CACHE);
		newDirty += matrixObj-&gt;GetHDirty(HDIRTYFLAGS::OBJECT | HDIRTYFLAGS::OBJECT_HIERARCHY | HDIRTYFLAGS::OBJECT_MATRIX);
		if(previousDirty == newDirty)
			return op-&gt;GetCache(hh);
		// Get the Matrix as a poly (We could have call CurrentState To object also)
		BaseObject* clone = op-&gt;GetHierarchyClone(hh, matrixObj, HIERARCHYCLONEFLAGS::ASPOLY, nullptr, nullptr);
		// Hide the matrix object (handle are still drawn if matrix object is selected)
		previousDirty = newDirty;
		matrixObj-&gt;SetBit(BIT_IGNOREDRAW);
		// Get ptCount and Point Array
		Int32 ptCount = ToPoly(clone)-&gt;GetPointCount() / 4;
		const Vector* padr = ToPoint(clone)-&gt;GetPointR();
		Dpoint    *d = (Dpoint *) padr;
		// iterate over the point and create null at the pt matrix
		for(Int32 x = 0; x &lt; ptCount; x++)
			BaseObject* n = BaseObject::Alloc(Onull);
			if(!n)
				return outObject;
			// Get the Correct World Matrix
			Matrix result(d[x].m.off + matrixObj-&gt;GetMl().off, d[x].m.sqmat.v1 + matrixObj-&gt;GetMl().sqmat.v1, d[x].m.sqmat.v2 + matrixObj-&gt;GetMl().sqmat.v2, d[x].m.sqmat.v3 + matrixObj-&gt;GetMl().sqmat.v3);
			n-&gt;SetMg(result);
			n-&gt;InsertUnder(outObject);
			pointList.Append(d[x].GetPos());
		ApplicationOutput("@", pointList.GetCount());
		return outObject;
</code></pre>
<p dir="auto">Cheers,<br />
Maxime</p>
]]></description><link>http://developers.maxon.net/forum/post/56389</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56389</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Thu, 15 Nov 2018 13:49:59 GMT</pubDate></item><item><title><![CDATA[Reply to Getting MoData in GVO of a ObjectData Plugin on Wed, 14 Nov 2018 02:13:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/m_adam">@<bdi>m_adam</bdi></a> I'm finally getting around to implementing this fix, and it's working really well except for it's alway rebuilding the cache, GetAndCheckHeirarchyClone is always saying the input object is dirty.</p>
<p dir="auto">Is this how it's supposed to work?</p>
]]></description><link>http://developers.maxon.net/forum/post/56359</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56359</guid><dc:creator><![CDATA[codysorgenfrey]]></dc:creator><pubDate>Wed, 14 Nov 2018 02:13:44 GMT</pubDate></item><item><title><![CDATA[Reply to Getting MoData in GVO of a ObjectData Plugin on Fri, 09 Nov 2018 08:11:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/codysorgenfrey">@<bdi>codysorgenfrey</bdi></a> please if your thread has been solved please mark the answers as the correct answers or at least mark the topic as solved.<br />
For more information please read the <a href="https://developers.maxon.net/forum/topic/11004/q-a-new-functionality" target="_blank" rel="noopener noreferrer nofollow ugc">Q&amp;A New Functionality</a>.</p>
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/56322</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56322</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Fri, 09 Nov 2018 08:11:39 GMT</pubDate></item><item><title><![CDATA[Reply to Getting MoData in GVO of a ObjectData Plugin on Fri, 09 Nov 2018 01:33:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/m_adam">@<bdi>m_adam</bdi></a> Thanks for the thorough response! This solution actually fits my needs better anyways.</p>
]]></description><link>http://developers.maxon.net/forum/post/56320</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56320</guid><dc:creator><![CDATA[codysorgenfrey]]></dc:creator><pubDate>Fri, 09 Nov 2018 01:33:34 GMT</pubDate></item><item><title><![CDATA[Reply to Getting MoData in GVO of a ObjectData Plugin on Wed, 07 Nov 2018 10:27:29 GMT]]></title><description><![CDATA[<p dir="auto">Hi @codysorgenfrey.<br />
First of all, I would like to present my apologies for the time your topic took to get at least a constructive answer.</p>
<p dir="auto">Since matrix object is a bit special MoData are often out of data. It is not an issue for you, here is another solution.<br />
If you want to read the point position of a matrix, you should convert it into a polygonObject and read Dpoint.<br />
The con of that is you are losing the Modata (flags, etc, but deformer/effector are still working of course).</p>
<pre><code>BaseObject* GetVirtualObjects (BaseObject* op, HierarchyHelp* hh)
    if (!outObject)
        return nullptr;
    // Get the cache
    if (!matrixObj || !matrixObj-&gt;IsInstanceOf(1018545)) // 1018545 = Matrix Object
        return outObject;
    // Get the Matrix as a poly, it do not proper touch the Matrix Object, so you have to do it manually
    Bool dirty;
    BaseObject* clone = op-&gt;GetAndCheckHierarchyClone(hh, matrixObj, HIERARCHYCLONEFLAGS::ASPOLY, &amp;dirty, nullptr, false);
    if(!dirty)
        return outObject;
    // Touch the original matrix in order to hide it in viewport
    matrixObj-&gt;Touch();
        if(!n)
            return outObject;
    return outObject;
</code></pre>
<p dir="auto">Note in this example it only works with 1 matrice object, and as you can see you need to manually touch the object and I assume the result of GetAndCheckHierarchyClone is the result of the Matrix Object itself.<br />
If you have multiple objects and a matrice is within, it may be worth doing the cache system yourself, please take a look at <a href="https://developers.maxon.net/docs/cpp/2023_2/page_manual_baseobject.html#page_manual_baseobject_edit_generating" target="_blank" rel="noopener noreferrer nofollow ugc">BaseObject Manual - Generating</a> for more information.</p>
<p dir="auto">If you have any question, please let me know.<br />
Cheers,<br />
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/56313</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56313</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Wed, 07 Nov 2018 10:27:29 GMT</pubDate></item><item><title><![CDATA[Reply to Getting MoData in GVO of a ObjectData Plugin on Tue, 06 Nov 2018 14:27:30 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/codysorgenfrey">@<bdi>codysorgenfrey</bdi></a>, just to inform you I've made some progress and I'm currently in discussion with the development team about your topic.</p>
<p dir="auto">Hopefully, I will be able to provide you a concrete solution in short delay. Anyway thanks a lot for your patience.<br />
Cheers,<br />
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/56303</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56303</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Tue, 06 Nov 2018 14:27:30 GMT</pubDate></item><item><title><![CDATA[Reply to Getting MoData in GVO of a ObjectData Plugin on Tue, 30 Oct 2018 17:31:15 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/codysorgenfrey">@<bdi>codysorgenfrey</bdi></a> while I was able to reproduce the issue. I'm still investigating it. Sadly due to the Devktchen, I won't be able to work on it the whole week.<br />
At least, what I can't tell is the fact that touching the matrix object which prohibits the tag to be refreshed.</p>
<p dir="auto">Regarding MSG_MOGRAPH_REEVALUATE I'm doubtful but it's something I have to investigate also thanks for your finding, patience anyway.</p>
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/56233</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56233</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Tue, 30 Oct 2018 17:31:15 GMT</pubDate></item><item><title><![CDATA[Reply to Getting MoData in GVO of a ObjectData Plugin on Mon, 29 Oct 2018 18:54:54 GMT]]></title><description><![CDATA[<p dir="auto">So interesting find today. I think in order to get updates on the cache of a mograph matrix object I need to respond to MSG_MOGRAPH_REEVAULATE. Is this correct?</p>
<p dir="auto">It seems to be the only way to get notified of when the mograph cache is updated, especially when using effectors.</p>
]]></description><link>http://developers.maxon.net/forum/post/56223</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56223</guid><dc:creator><![CDATA[codysorgenfrey]]></dc:creator><pubDate>Mon, 29 Oct 2018 18:54:54 GMT</pubDate></item><item><title><![CDATA[Reply to Getting MoData in GVO of a ObjectData Plugin on Fri, 26 Oct 2018 16:18:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/m_adam">@<bdi>m_adam</bdi></a> Thanks for the update. I'm in no hurry as I can work on other parts of the project while I wait. I look forward to your investigation!</p>
]]></description><link>http://developers.maxon.net/forum/post/56182</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56182</guid><dc:creator><![CDATA[codysorgenfrey]]></dc:creator><pubDate>Fri, 26 Oct 2018 16:18:52 GMT</pubDate></item><item><title><![CDATA[Reply to Getting MoData in GVO of a ObjectData Plugin on Fri, 26 Oct 2018 13:48:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/codysorgenfrey">@<bdi>codysorgenfrey</bdi></a> even if your topic is older than a day and we try to answers as soon as possible.<br />
Your question needs some investigation, and with the DevKitchen we are pretty busy. But you can be sure if I didn't find some time to tackle today I will do Monday! <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /></p>
<p dir="auto">Maybe you can find valid answers in this topic <a href="https://developers.maxon.net/forum/topic/8650/11316_modata-arrays--mograph-cache-tag-problem-solved" target="_blank" rel="noopener noreferrer nofollow ugc">https://developers.maxon.net/forum/topic/8650/11316_modata-arrays--mograph-cache-tag-problem-solved</a> But as I see you already use mdm.Release So I'm doubtful.</p>
<p dir="auto">Thanks for your patience.<br />
Cheers,<br />
Maxime.</p>
]]></description><link>http://developers.maxon.net/forum/post/56179</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56179</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Fri, 26 Oct 2018 13:48:12 GMT</pubDate></item><item><title><![CDATA[Reply to Getting MoData in GVO of a ObjectData Plugin on Wed, 24 Oct 2018 21:57:07 GMT]]></title><description><![CDATA[<p dir="auto">Also the mograph cache tag never returns modata, even when it's present and baked.</p>
]]></description><link>http://developers.maxon.net/forum/post/56138</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56138</guid><dc:creator><![CDATA[codysorgenfrey]]></dc:creator><pubDate>Wed, 24 Oct 2018 21:57:07 GMT</pubDate></item></channel></rss>
