<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sampling effect channel shaders]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">I have a BaseLink containing a BaseShader that is used as a distribution map on my object, it's not in a material. I usually can sample it fine when using color, texture or a surface like checkerboard. Now I'm trying to sample Effects shaders, having mixed bad results.</p>
<p dir="auto">The Vertex Map shader always returns zero, even inverted. I can check the vertex map is ok because there's a material using the same Vertex Map tag on the mesh. When I assign the this tag to my shader, I wish I would get the same result I see pained on the mesh.</p>
<p dir="auto">Using the Spline shader give me some warnings when Sample is called (CRITICAL: Stop: Having more than one strong reference to a block which is going to be reallocated is unsafe and CRITICAL: Stop: Could not determine old block size and therefore cannot resize). Then it crashes C4D.</p>
<p dir="auto">Is that anything different I need to do to initialize those effect shaders before sampling?</p>
<p dir="auto">Thanks,<br />
Roger</p>
]]></description><link>http://developers.maxon.net/forum/topic/11051/sampling-effect-channel-shaders</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 15:26:06 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/11051.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Oct 2018 19:51:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Sampling effect channel shaders on Wed, 30 Jan 2019 01:23:00 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Riccardo, I think we reached the bottom of this issue.</p>
<p dir="auto">I just finished implementing a workaround, getting the tag associated with the shader, it's polygon, points and uvw tag, then paint each face with the average vertex value in a bitmap using GeClipMat. Working really good!</p>
<p dir="auto">Best,<br />
Roger</p>
]]></description><link>http://developers.maxon.net/forum/post/57015</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/57015</guid><dc:creator><![CDATA[rsodre]]></dc:creator><pubDate>Wed, 30 Jan 2019 01:23:00 GMT</pubDate></item><item><title><![CDATA[Reply to Sampling effect channel shaders on Tue, 29 Jan 2019 13:35:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi Roger,</p>
<p dir="auto">although I see your concern, in the current API there are no means to know beforehand if a certain shader requires a valid  VolumeData instance to be passed within the ChannelData instance to deliver a "proper" sampling.<br />
Being the VolumeData pointer equal to <em>nullptr</em>  in the ChannelData constructor, there's actually nothing back when the BaseShader::Sample() methods are invoked without a valid VolumeData being passed.</p>
<p dir="auto">Last but not least, also <a href="https://developers.maxon.net/docs/cpp/2023_2/class_base_shader.html#a37f5181b411f6025ed4e4c68e60e2f90" target="_blank" rel="noopener noreferrer nofollow ugc">BaseShader::GetRenderInfo()</a> isn't of any help in this case.</p>
<p dir="auto">Best, Riccardo</p>
]]></description><link>http://developers.maxon.net/forum/post/57008</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/57008</guid><dc:creator><![CDATA[r_gigante]]></dc:creator><pubDate>Tue, 29 Jan 2019 13:35:51 GMT</pubDate></item><item><title><![CDATA[Reply to Sampling effect channel shaders on Mon, 28 Jan 2019 17:27:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/r_gigante">@<bdi>r_gigante</bdi></a> said in <a href="https://developers.maxon.net/forum/post/56984" target="_blank" rel="noopener noreferrer nofollow ugc">Sampling effect channel shaders</a>:</p>
<blockquote>
<p dir="auto">With regard to "previewing" a Vertex Map in viewport you're not actually seeing the output generated by the VertexMap shader but the actual data belonging to VertexMap Tag where the VolumeData information is no needed at all.</p>
</blockquote>
<p dir="auto">Sure, makes complete sense. There's no shader involved at this point, only the tag.<br />
I will study a workaround using the VertexMapTag data.</p>
<p dir="auto">There's just one unanswered question to close this topic...<br />
Is there a way to check if a specific shader needs VolumeData?<br />
Would be nice to warn the user when the selected shader will not work within this feature.</p>
]]></description><link>http://developers.maxon.net/forum/post/56995</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56995</guid><dc:creator><![CDATA[rsodre]]></dc:creator><pubDate>Mon, 28 Jan 2019 17:27:47 GMT</pubDate></item><item><title><![CDATA[Reply to Sampling effect channel shaders on Mon, 28 Jan 2019 13:44:48 GMT]]></title><description><![CDATA[<p dir="auto">Hi Roger, thanks for following up.</p>
<p dir="auto">Finally, despite the naming similarity, <a href="https://developers.maxon.net/docs/cpp/2023_2/class_volume_builder.html" target="_blank" rel="noopener noreferrer nofollow ugc">VolumeBuilder</a>, <a href="VolumeToolsInterface" target="_blank" rel="noopener noreferrer nofollow ugc">PointsToVolume</a> and <a href="https://developers.maxon.net/docs/cpp/2023_2/classmaxon_1_1_volume_tools_interface.html#a67725a2d1f2d1073e6edc7de9044a251" target="_blank" rel="noopener noreferrer nofollow ugc">MeshToVolume</a> have nothing to do with <a href="https://developers.maxon.net/docs/cpp/2023_2/struct_volume_data.html" target="_blank" rel="noopener noreferrer nofollow ugc">VolumeData</a>.<br />
While the first three are indeed related to the new Volume-based modeling workflow introduced in R20, the latter, present in Cinema since time, has relevance in the context of rendering and is responsible for storing all the scene data information ready to be dispatched to a rendering engine.</p>
]]></description><link>http://developers.maxon.net/forum/post/56984</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56984</guid><dc:creator><![CDATA[r_gigante]]></dc:creator><pubDate>Mon, 28 Jan 2019 13:44:48 GMT</pubDate></item><item><title><![CDATA[Reply to Sampling effect channel shaders on Wed, 23 Jan 2019 04:16:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/r_gigante">@<bdi>r_gigante</bdi></a> , sorry to uncover this old topic, but this issue remains pending on my desk, and I would like to close it for good. There's a couple of questions about the Vertex Map shader that remained unanswered:</p>
<blockquote>
<p dir="auto">How can we see the preview of the Vertex Map shader in the viewport if there's no VolumeData available at this point?<br />
Is there a way to check if a specific shader needs VolumeData? Would be nice to warn the user that a shader (like Vertex Map) cannot be used if selected.</p>
</blockquote>
<p dir="auto">I don't know anything about VolumeData, never used it. But I see hints on the documentation like <code>VolumeBuilder</code>, <code>PointsToVolume</code> and <code>MeshToVolume</code> without any context on why they exist and how they are useful, and that makes me have a slight hope of sampling that shader.</p>
<p dir="auto">It's hard to accept that the colors I see over my mesh on the viewport are impossible to access. That would be really helpful on our plugin workflow.</p>
]]></description><link>http://developers.maxon.net/forum/post/56921</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56921</guid><dc:creator><![CDATA[rsodre]]></dc:creator><pubDate>Wed, 23 Jan 2019 04:16:06 GMT</pubDate></item><item><title><![CDATA[Reply to Sampling effect channel shaders on Fri, 19 Oct 2018 14:31:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/r_gigante">@<bdi>r_gigante</bdi></a> Good timing! I just finished my implementation based on your example, now it's working fine, thanks.</p>
<p dir="auto">I found out the crash was caused by using Sample inside a parallel_for. Enclosing he Sample() call with a maxon::SpinLock::Lock() and Unlock() fixed it.</p>
<p dir="auto">And I was not using TransformColor(), so the sampled values were not consistent with the material.</p>
<p dir="auto">I have just a couple of questions before closing this.</p>
<p dir="auto">How can we see the preview of the Vertex Map shader in the viewport if there's no VolumeData available at this point?</p>
<p dir="auto">Is there a way to check if a specific shader needs VolumeData? Would be nice to warn the user that a shader (like Vertex Map) cannot be used if selected.</p>
]]></description><link>http://developers.maxon.net/forum/post/56096</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56096</guid><dc:creator><![CDATA[rsodre]]></dc:creator><pubDate>Fri, 19 Oct 2018 14:31:42 GMT</pubDate></item><item><title><![CDATA[Reply to Sampling effect channel shaders on Fri, 19 Oct 2018 13:57:55 GMT]]></title><description><![CDATA[<p dir="auto">Hi roger, can I consider this topic as solved or do you need any further investigation?</p>
<p dir="auto">If solved, please mark the thread as solved OR, in the three-bullet menu of a post, click on "Mark this post as the correct answer".</p>
]]></description><link>http://developers.maxon.net/forum/post/56094</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/56094</guid><dc:creator><![CDATA[r_gigante]]></dc:creator><pubDate>Fri, 19 Oct 2018 13:57:55 GMT</pubDate></item><item><title><![CDATA[Reply to Sampling effect channel shaders on Tue, 09 Oct 2018 17:04:30 GMT]]></title><description><![CDATA[<p dir="auto">Hi Roger, thanks for following up.</p>
<p dir="auto">With regard to the Spline Shader I confirm that it can be properly sampled without specifying the VolumeData (which is instead needed by VertexMap Shader)</p>
<p dir="auto">The following test code works flawlessly on my side</p>
<pre><code>EXECUTIONRESULT PC_11051_TagData::Execute (BaseTag *tag, BaseDocument *doc, BaseObject *op, BaseThread *bt, Int32 priority, EXECUTIONFLAGS flags)
  if (!tag || !doc || !op || !bt)
    return EXECUTIONRESULT::OUTOFMEMORY;
  // allocate and init the InitRenderStruct
  InitRenderStruct irs(doc);
  // check the color space
  COLORSPACETRANSFORMATION transform = COLORSPACETRANSFORMATION::NONE;
  // check if linear workflow is enabled
  if (irs.linear_workflow)
    transform = COLORSPACETRANSFORMATION::LINEAR_TO_SRGB;
  // find for the attached TextureTag and the related material
  TextureTag* opTTag = (TextureTag*)op-&gt;GetTag(Ttexture);
  if (!opTTag)
    return EXECUTIONRESULT::OK;
  BaseMaterial* opMat = opTTag-&gt;GetMaterial();
  if (!opMat)
  // look for the material BaseContainer and the BaseList2D associated to the color param
  BaseContainer* activeMatBC = opMat-&gt;GetDataInstance();
  if (!activeMatBC)
  BaseList2D* activeMatColorBL = activeMatBC-&gt;GetLink(MATERIAL_COLOR_SHADER, doc);
  if (!activeMatColorBL)
  // cast to BaseShader
  BaseShader* activeMatColorBS = (BaseShader*)activeMatColorBL;
  // define the ChannelData and set the u/v coords for sampling
  ChannelData chData;
  chData.p = Vector(0.5, 0.5, 0);
  // call the InitRender before executing sampling
  const INITRENDERRESULT res = activeMatColorBS-&gt;InitRender(irs);
  if (res != INITRENDERRESULT::OK)
  // sample
  const Vector sampledValue = activeMatColorBS-&gt;Sample(&amp;chData);
  // correct based on the color space transformation
  const Vector transformedColor = TransformColor(sampledValue, transform).Clamp01();
  // just print
  DiagnosticOutput("Shader '@' sample at [@,@]: @ / @", maxon::String(activeMatColorBL-&gt;GetName()), chData.p.x, chData.p.y, sampledValue, transformedColor);
  // call the FreeRender to release allocated memory used for sampling
  activeMatColorBS-&gt;FreeRender();
</code></pre>
<p dir="auto">The "same" code used inside a PythonTag works as well</p>
<pre><code>def main():
        # look for an attached TextureTag
        textureTag = op.GetObject().GetTag(c4d.Ttexture)
        if textureTag is None:
        # look for the referred material
        mat = textureTag.GetMaterial()
        if mat is None:
        # look for the shader in the color param
        shd = mat[c4d.MATERIAL_COLOR_SHADER]
        if shd is None:
        # init, sample and free
        initRS = c4d.modules.render.InitRenderStruct()
        c4d.INITRENDERRESULT_OK == shd.InitRender(initRS)
        chanData = c4d.modules.render.ChannelData()
        chanData.p = c4d.Vector(0.5,0.5,0)
        print "Shader '",shd.GetName(),"' sample at [",chanData.p.x,",",chanData.p.y,"]: ", shd.Sample(chanData)
        shd.FreeRender()
</code></pre>
<p dir="auto">Finally a screenshot of the test scene<br />
<img src="https://developers.maxon.net/forum/assets/uploads/files/1539104614334-20ea149b-fdf9-432e-97d9-15b91a5eaa46-image-resized.png" alt="0_1539104613530_20ea149b-fdf9-432e-97d9-15b91a5eaa46-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Hoping it helps, don't hesitate to get back for any further help.</p>
<p dir="auto">Riccardo</p>
]]></description><link>http://developers.maxon.net/forum/post/55952</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/55952</guid><dc:creator><![CDATA[r_gigante]]></dc:creator><pubDate>Tue, 09 Oct 2018 17:04:30 GMT</pubDate></item><item><title><![CDATA[Reply to Sampling effect channel shaders on Mon, 08 Oct 2018 18:18:25 GMT]]></title><description><![CDATA[<p dir="auto">Hi Riccardo,</p>
<p dir="auto">I'm sure calling InitRender/FreeRender, and I can sample textures, so I think that's not the issue.</p>
<p dir="auto">My shader is not in a VideoPost, it's in a tag. I need to sample before rendering, during expression Execute(), is there any way to get a VolumeData in that context?</p>
<p dir="auto">Does the Spline effect shader also needs a VolumeData? I wonder why... That's a shader that i think users will use often, and having this limitation would be a turn down.</p>
Roger</p>
]]></description><link>http://developers.maxon.net/forum/post/55935</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/55935</guid><dc:creator><![CDATA[rsodre]]></dc:creator><pubDate>Mon, 08 Oct 2018 18:18:25 GMT</pubDate></item><item><title><![CDATA[Reply to Sampling effect channel shaders on Mon, 08 Oct 2018 10:42:29 GMT]]></title><description><![CDATA[<p dir="auto">Hi rsodre, thanks for writing us and sorry for coming late here.</p>
<p dir="auto">With regard to your question, I'm actually missing one relevant information: are you inside a VideoPostData context? Or what?</p>
<p dir="auto">In order to use <a href="https://developers.maxon.net/docs/cpp/2023_2/class_base_shader.html#ac6d8b6a2c792a7d87c66fd0c86cff739" target="_blank" rel="noopener noreferrer nofollow ugc">BaseShader::Sample()</a> it's requested to pass a properly-filled <a href="https://developers.maxon.net/docs/cpp/2023_2/struct_init_render_struct.html" target="_blank" rel="noopener noreferrer nofollow ugc">InitRenderStruct</a> as well as to fire <a href="https://developers.maxon.net/docs/cpp/2023_2/class_base_shader.html#a54009333771e55f85a7d60ce9cae2397" target="_blank" rel="noopener noreferrer nofollow ugc">InitRender</a>/<a href="https://developers.maxon.net/docs/cpp/2023_2/class_base_shader.html#a8739de89fb22262c02a9d43f3b9318b3" target="_blank" rel="noopener noreferrer nofollow ugc">FreeRender</a> as shown in this <a href="https://developers.maxon.net/docs/cpp/2023_2/page_manual_baseshader.html#page_manual_baseshader_use" target="_blank" rel="noopener noreferrer nofollow ugc">page</a> of our documentation.</p>
<p dir="auto">Along the notes above, while certain shaders do not (e.g. texture maps), sampling other type of shaders (e.g. VertexMap) requires the InitRenderStruct passed to be provided with a <a href="https://developers.maxon.net/docs/cpp/2023_2/struct_volume_data.html" target="_blank" rel="noopener noreferrer nofollow ugc">VolumeData</a> data member (InitRenderStruct::vd) properly populated. That said, only in the context of VideoPostData proper VolumeData information can be obtained and further reused inside your sampling functionality.</p>
<p dir="auto">Looking forward to hear about your context, give best.<br />
Riccardo</p>
]]></description><link>http://developers.maxon.net/forum/post/55932</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/55932</guid><dc:creator><![CDATA[r_gigante]]></dc:creator><pubDate>Mon, 08 Oct 2018 10:42:29 GMT</pubDate></item></channel></rss>
