<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Compiling for R20]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I'm trying to recompile my C4D plugin for R20 (Windows), and I'm having some issues.</p>
<p dir="auto">Previously, I would first compile a static library for cinema.framework, and then add it<br />
to my plugin project solution.  But now, I can't even compile cinema.framework.</p>
<p dir="auto">I understand things have changed, and I've read this:<br />
<a href="https://developers.maxon.net/docs/cpp/2023_2/page_maxonapi_getting_started_introduction.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://developers.maxon.net/docs/cpp/2023_2/page_maxonapi_getting_started_introduction.html</a></p>
<p dir="auto">And downloaded the Project Tool:<br />
[URL-REMOVED]</p>
<p dir="auto">I ran it on this directory:<br />
\frameworks\cinema.framework\project</p>
<p dir="auto">I was assuming the project tool would create a solution file (.sln) for me, which I could<br />
loade into VS 2015, and then compile a static library, but it only creates a .vcxproj file.</p>
<p dir="auto">Trying to load this .vcxproj into VS 2015 only gives me errors, and nothing gets loaded. So, I'm a bit confused and don't know where to go from here.  Thanks.</p>
<p dir="auto">Using:<br />
Windows 7, 64-bit<br />
Visual Studio 2015 Community<br />
C++</p>
<hr />
<p dir="auto">[URL-REMOVED] <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/maxon">@<bdi>maxon</bdi></a>: This section contained a non-resolving link which has been removed.</p>
]]></description><link>http://developers.maxon.net/forum/topic/11015/compiling-for-r20</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 08:54:29 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/11015.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Sep 2018 18:40:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Compiling for R20 on Thu, 20 Sep 2018 10:00:27 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">glad you were able to solve your problem. We'll take this as a hint and see if we can improve our documentation in this regard.</p>
<p dir="auto">Cheers,<br />
Andreas</p>
]]></description><link>http://developers.maxon.net/forum/post/55770</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/55770</guid><dc:creator><![CDATA[a_block]]></dc:creator><pubDate>Thu, 20 Sep 2018 10:00:27 GMT</pubDate></item><item><title><![CDATA[Reply to Compiling for R20 on Wed, 19 Sep 2018 20:06:28 GMT]]></title><description><![CDATA[<p dir="auto">I solved my problem here:<br />
<a href="https://developers.maxon.net/forum/topic/10967/compiling-the-cinema-4d-r20-c-sdk-examples" target="_blank" rel="noopener noreferrer nofollow ugc">https://developers.maxon.net/forum/topic/10967/compiling-the-cinema-4d-r20-c-sdk-examples</a></p>
<p dir="auto">I didn't realize I had to run the Project Tool on the <strong>entire</strong> SDK directory.</p>
<p dir="auto">Maybe that thread should be a sticky at the top of the forums, because it makes more sense than the docs.</p>
]]></description><link>http://developers.maxon.net/forum/post/55761</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/55761</guid><dc:creator><![CDATA[rootbender]]></dc:creator><pubDate>Wed, 19 Sep 2018 20:06:28 GMT</pubDate></item></channel></rss>
