<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cycle drop-down with thumbnails]]></title><description><![CDATA[<p dir="auto"><em>On 17/08/2018 at 06:44, <strong>xxxxxxxx</strong> wrote:</em></p>
<p dir="auto">Is there a way for creating thumbnails in plugin's UI, similar to C4D's noise thumbnails?</p>
<p dir="auto"><img src="https://i.imgur.com/49UklKD.jpg" alt="" class=" img-fluid img-markdown" /></p>
]]></description><link>http://developers.maxon.net/forum/topic/10920/14375_cycle-dropdown-with-thumbnails</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 22:47:17 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/10920.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 01 Sep 2018 10:57:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cycle drop-down with thumbnails on Sat, 01 Sep 2018 10:57:11 GMT]]></title><description><![CDATA[<p dir="auto"><em>On 20/08/2018 at 10:12, <strong>xxxxxxxx</strong> wrote:</em></p>
<p dir="auto">Hi,</p>
<p dir="auto">there are basically two ways to achieve something like this, depending on the type of plugin you are implementing.</p>
<p dir="auto">In a <a href="https://developers.maxon.net/docs/py/2023_2/modules/c4d.plugins/BaseData/CommandData/index.html?highlight=commanddata" target="_blank" rel="noopener noreferrer nofollow ugc">CommandData</a> you would attach a <a href="https://developers.maxon.net/docs/py/2023_2/modules/c4d.gui/GeDialog/index.html?highlight=gedialog" target="_blank" rel="noopener noreferrer nofollow ugc">GeDialog</a> and use a <a href="https://developers.maxon.net/docs/py/2023_2/modules/c4d.gui/BaseCustomGui/BitmapButtonCustomGui/index.html?highlight=bitmapbuttoncustomgui" target="_blank" rel="noopener noreferrer nofollow ugc">BitmapButtonCustomGui</a> to display the thumbnails. Instead of BitmapButtons you could of course also implement your own <a href="https://developers.maxon.net/docs/py/2023_2/modules/c4d.gui/GeUserArea/index.html?highlight=geuserarea" target="_blank" rel="noopener noreferrer nofollow ugc">GeUserArea</a>.</p>
<p dir="auto">In <a href="https://developers.maxon.net/docs/py/2023_2/modules/c4d.plugins/BaseData/NodeData/index.html?highlight=nodedata" target="_blank" rel="noopener noreferrer nofollow ugc">NodeData</a> derived plugins (<a href="https://developers.maxon.net/docs/py/2023_2/modules/c4d.plugins/BaseData/NodeData/ObjectData/index.html?highlight=objectdata" target="_blank" rel="noopener noreferrer nofollow ugc">ObjectData</a>, <a href="https://developers.maxon.net/docs/py/2023_2/modules/c4d.plugins/BaseData/NodeData/TagData/index.html?highlight=tagdata" target="_blank" rel="noopener noreferrer nofollow ugc">TagData</a>,...) it's a bit different, as a GeDialog needs to be attached to a CommandData. You could still use above approach by calling such a command in reaction to a button press, though. Then your dialog would probably need to be asynchronous and should update to display the thumbnails for the currently selected object or tag (or whatever).</p>
<p dir="auto">The other approach here would be the implementation of a CustomGui, which could then be used directly in the description of the implemented object or tag. But this is only possible in C++.</p>
]]></description><link>http://developers.maxon.net/forum/post/55457</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/55457</guid><dc:creator><![CDATA[Helper]]></dc:creator><pubDate>Sat, 01 Sep 2018 10:57:11 GMT</pubDate></item></channel></rss>
