<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to get list of all MyPlugin instances?]]></title><description><![CDATA[<p dir="auto"><em>On 04/08/2018 at 05:32, <strong>xxxxxxxx</strong> wrote:</em></p>
Cinema 4D Version:   19 <br />
Platform:   Windows  ;   <br />
Language(s) :     C++  ;</p>
<p dir="auto">---------<br />
At first, I thought that it's a very simple task.. My mistake.:-/</p>
<p dir="auto">What I tried to do is to create global storage and save link to plugin instance every time it's being created:<br />
<strong>&lt; &lt;&lt;Main.cpp&gt;&gt;&gt;</strong></p>
<pre><code>def PLUGIN_ID = 1234321
class MyTagPlugin: TagData {
MyTagPlugin::MyTagPlugin()
GePrint("---MyTag constructor---");
Bool MyTagPlugin::Init(GeListNode *node)
    GePrint("init...");
    pluginStorage = GetActiveDocument()-&gt;GetDataInstance()-&gt;GetContainer(PLUGIN_ID);
//    ERROR SECTION
    index = bc.GetInt32(0,0)+1;
    pluginStorage.SetInt32(0,index);
    pluginStorage.SetLink(index, (BaseTag* )node);
Bool PluginMessage(Int32 id, void *data)
    if(id==C4DPL_COMMANDLINEARGS)
        GePrint("Creating plugin storage");
        GetActiveDocument()-&gt;GetDataIstance()-&gt;SetContainer(PLUGIN_ID, BaseContainer());
</code></pre>
<p dir="auto"><strong>&lt; &lt;&lt;Output&gt;&gt;&gt;</strong></p>
<pre><code>Creating plugin storage
init...
init...
</code></pre>
<p dir="auto">Why Constructor and Init functions of my plugin are fired twice when each instance of it created and twice every time when I change any parameter of MyTag?</p>
<p dir="auto">What event or function should I use instead, to catch the moment of MyTag creation?</p>
]]></description><link>http://developers.maxon.net/forum/topic/10900/14349_how-to-get-list-of-all-myplugin-instances</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 18:30:08 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/10900.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 01 Sep 2018 10:54:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to get list of all MyPlugin instances? on Sat, 01 Sep 2018 10:54:14 GMT]]></title><description><![CDATA[<p dir="auto"><em>On 24/08/2018 at 06:17, <strong>xxxxxxxx</strong> wrote:</em></p>
<p dir="auto">Hi,</p>
<p dir="auto">I'm actually not quite sure, if we still have an open question here. Please forgive.</p>
<p dir="auto">For the IES lights I'd recommend to submit the bug to our user support: <a href="https://www.maxon.net/en/support/how-can-we-help/" target="_blank" rel="noopener noreferrer nofollow ugc">How can we help?</a></p>
]]></description><link>http://developers.maxon.net/forum/post/55390</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/55390</guid><dc:creator><![CDATA[Helper]]></dc:creator><pubDate>Sat, 01 Sep 2018 10:54:14 GMT</pubDate></item><item><title><![CDATA[Reply to How to get list of all MyPlugin instances? on Sat, 01 Sep 2018 10:54:11 GMT]]></title><description><![CDATA[<p dir="auto"><em>On 18/08/2018 at 09:52, <strong>xxxxxxxx</strong> wrote:</em></p>
<p dir="auto">Hi, Andreas.</p>
<blockquote>
<p dir="auto">May I ask, why you are trying to set up such a global directory of tag instances?</p>
</blockquote>
<p dir="auto">What I wanted to create is some kind of visibility switcher that gonna let me easely show/hide different groups of objects in my scene.</p>
<p dir="auto"><img src="https://i.imgur.com/yRQvwkO.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://i.imgur.com/wvHuRvU.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://i.imgur.com/R6B9Co9.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://i.imgur.com/JE64FPz.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://i.imgur.com/DZofHOi.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://imgur.com/a/bjd73zB" target="_blank" rel="noopener noreferrer nofollow ugc">https://imgur.com/a/bjd73zB</a></p>
<p dir="auto">Each instance of MyTag "knows" 4 things:<br />
1)parameter number (i mean [c4d.ID_USERDATA,param_num] of controller object)<br />
2)active parameter value<br />
3)active layer<br />
4)inactive layer</p>
<p dir="auto">I'm creating controller object which contains different parameters, and when value of some parameter is changed, python script sends message to all instances of MyTag with number of parameter that was changed and it's new value. <strong>(* )</strong><br />
If (new_value==active_value) then (layer=active_layer), else (layer=inactive_layer)</p>
<p dir="auto">&gt;  <strong>(* )</strong> _That's the step where I needed whole list of MyTag-s. I avoided this problem by creating MyTag list within my python code.<br />
&gt; _</p>
<p dir="auto">----------------<br />
UPD (offtopic) :<br />
BTW, Andreas, there's definetely something wrong with photometric light sources in C4D.<br />
I wrote about it here: <a href="http://forums.cgsociety.org/showthread.php?f=47&amp;t=1511868" target="_blank" rel="noopener noreferrer nofollow ugc">http://forums.cgsociety.org/showthread.php?f=47&amp;t=1511868</a></p>
<p dir="auto">Here are some IES files to check: <a href="http://www.lighting.philips.co.uk/prof/led-lamps-and-tubes/led-bulbs/corepro-ledbulb" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.lighting.philips.co.uk/prof/led-lamps-and-tubes/led-bulbs/corepro-ledbulb</a><br />
I think it's a bug.</p>
]]></description><link>http://developers.maxon.net/forum/post/55389</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/55389</guid><dc:creator><![CDATA[Helper]]></dc:creator><pubDate>Sat, 01 Sep 2018 10:54:11 GMT</pubDate></item><item><title><![CDATA[Reply to How to get list of all MyPlugin instances? on Sat, 01 Sep 2018 10:54:09 GMT]]></title><description><![CDATA[<p dir="auto"><em>On 06/08/2018 at 02:50, <strong>xxxxxxxx</strong> wrote:</em></p>
<p dir="auto">indeed you can not rely on Init() (or the constructor) being called just once. There are several reasons for this, one for example is related to the undo system. The correct way to be informed about the creation of your tag is to listen to the (admittedly strangely named) message <a href="https://developers.maxon.net/docs/cpp/2023_2/group___m_s_g.html#ga58e4d06ecc0352d135578cbc4d4e7b5e" target="_blank" rel="noopener noreferrer nofollow ugc">MSG_MENUPREPARE</a>. This message is sent, when the user creates a new tag from the menu (and is meant to do additional preparational work, thus its name).</p>
<p dir="auto">In that regard also you use of PluginMessage(C4DPL_COMMANDLINEARGS) looks a bit strange to me. The user might be working with multiple documents in parallel later on. Or he might close the scene and open a new one. The more correct approach would be, to check the existence of your BaseContainer later on, when you actually want to access it, and then create it on the fly if needed.</p>
]]></description><link>http://developers.maxon.net/forum/post/55388</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/55388</guid><dc:creator><![CDATA[Helper]]></dc:creator><pubDate>Sat, 01 Sep 2018 10:54:09 GMT</pubDate></item></channel></rss>
