<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Loading only specific plugin versions]]></title><description><![CDATA[<p dir="auto"><em>On 30/10/2017 at 10:09, <strong>xxxxxxxx</strong> wrote:</em></p>
<p dir="auto">Hi everyone</p>
<p dir="auto">first post on here so apologies if it's in the complete wrong place.</p>
<p dir="auto">I'm using the ENV variable C4D_PLUGINS_DIR to call plugins from a different location to usual but in that location i have</p>
<p dir="auto">C4DtoA v2.0.0</p>
<p dir="auto">and</p>
<p dir="auto">C4DtoA v2.2.0</p>
<p dir="auto">is there any way of telling cinema (via some sort of variable) to only load one version? bearing in mind the version to load may change?</p>
<p dir="auto">Thanks so much<br />
Will</p>
]]></description><link>http://developers.maxon.net/forum//topic/10368/13866_loading-only-specific-plugin-versions</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Mar 2026 00:02:37 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum//topic/10368.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 May 2018 16:32:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Loading only specific plugin versions on Thu, 10 May 2018 16:32:49 GMT]]></title><description><![CDATA[<p dir="auto"><em>On 31/10/2017 at 11:26, <strong>xxxxxxxx</strong> wrote:</em></p>
<p dir="auto">Hi Yannick</p>
<p dir="auto">thanks for the fast response!</p>
<p dir="auto">ok cool, ye i thought i might have build a few folders with different versions and then edit the ENV variable to grab the right one.</p>
<p dir="auto">Thanks again Yannick!</p>
<p dir="auto">Will</p>
]]></description><link>http://developers.maxon.net/forum//post/53313</link><guid isPermaLink="true">http://developers.maxon.net/forum//post/53313</guid><dc:creator><![CDATA[Helper]]></dc:creator><pubDate>Thu, 10 May 2018 16:32:49 GMT</pubDate></item><item><title><![CDATA[Reply to Loading only specific plugin versions on Thu, 10 May 2018 16:32:49 GMT]]></title><description><![CDATA[<p dir="auto"><em>On 31/10/2017 at 03:31, <strong>xxxxxxxx</strong> wrote:</em></p>
<p dir="auto">Hi and Welcome to the Plugin Cafe forums!</p>
<p dir="auto">This is the right place for your question.</p>
<p dir="auto">I'm afraid there is no way to setup how Cinema loads plugins from  <em>C4D_PLUGINS_DIR</em>.<br />
A solution could be to change  <em>C4D_PLUGINS_DIR</em>  to point to a specific plugin version before executing the respective Cinema release.</p>
]]></description><link>http://developers.maxon.net/forum//post/53312</link><guid isPermaLink="true">http://developers.maxon.net/forum//post/53312</guid><dc:creator><![CDATA[Helper]]></dc:creator><pubDate>Thu, 10 May 2018 16:32:49 GMT</pubDate></item></channel></rss>
